Narsil VS Anduril ???
22 posts / 0 new
mmalive
Last seen: 7 hours 51 min ago
Hey guys which one is better? And why? Please reflect. Many Thanks.
AlexGT
AlexGT's picture
Last seen: 3 hours 29 min ago
I like both but I think Anduril is an improvement, it has more features than Narsil.
DavidEF
DavidEF's picture
Last seen: 2 days 11 hours ago
Narsil was the name of the sword broken in battle. Andúril is the name given when the sword was re-forged. Therefore, Andúril has to be better, right? Crown
- The YKK Philosophy
robertsig
Last seen: 14 hours 24 min ago
DavidEF wrote:
Narsil was the name of the sword broken in battle. Andúril is the name given when the sword was re-forged. Therefore, Andúril has to be better, right? :CROWN:
Ouch, that Stings.
DavidEF
DavidEF's picture
robertsig wrote:
Ouch, that Stings.
I See What You Did There.™
beastlykings
beastlykings's picture
Last seen: 1 hour 11 min ago
I personally love Anduril. Although I will admit I didn’t play with the advanced features of Narsil while it was still on my Q8. I was in love with the smooth ramp.
Anduril builds on that, adding many new features and arguably silly, but also arguably awesome features like candle mode, lightning mode, goodnight(bedtime) mode, among others.
Narsil has other things anduril doesn’t, custom mode groupings I think? Someone else surely knows more than I do.
They both have their pros and cons for sure. But I’m an Anduril fanboy lol
klrman
klrman's picture
Last seen: 22 hours 16 min ago
I'm a fan of both.  Don't really think one is better than another,  just different.  I like the modes on Narsil and that you don't have the mess around to get maximum brightness right out of the box.  On the other hand, Anduril has some nice features with the lightning and candle modes etc.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 12 min ago
Which one is better? Whichever one you like more. UIs are heavily dependent on personal preferences.
Ryzbor
Ryzbor's picture
Last seen: 4 hours 41 min ago
It it possible to set Narsil to give 100% power on a double click from off?
Nichia E21A fanboy
lightboks
lightboks's picture
Last seen: 1 hour 53 min ago
you can set the ramping ceiling higher.
ActiveAl
ActiveAl's picture
Last seen: 1 hour 25 min ago
Absolutely, the Sofirn Q8 comes out of the box this way. I really like the NarsilM UI, but look forward to the Anduri UI with the FW3A.
ToyKeeper
ToyKeeper's picture
Yes. At least, when using the ramping UI, it’s not possible to set things any other way. If I recall correctly, the ramping UI always does double-click-to-turbo. Some lights have a ramp ceiling below 100%, like the BLF GT stops ramping at 80%… but double click always goes to full power.
The only one which doesn’t always do double-click-to-turbo is Anduril. When starting from “off”, it goes to the ramp ceiling first, and then another double click goes to turbo. The ceiling can be set to 100% though.
Mike C
Mike C's picture
Last seen: 12 hours 12 min ago
Ahh, but is it mentioned anywhere that Andúril is actually a better sword than Narsil was? If not, your logic is flawed Big Smile
Ryzbor
Ryzbor's picture
That’s the first thing I did with it ^^
Nichia E21A fanboy
mmalive
Great input guys. The reason I ask is because the Fireflies light has both versions. Trying to decide which one to buy? Any suggestions from owners of light? Thanks.
ToyKeeper
ToyKeeper's picture
The first batch of ROT66 used NarsilM. Later batches, and their other two products, used Anduril. There may still be some first-batch ROT66 lights available, but they’re not sold much any more.
Regardless of firmware, if you can get one with 219B emitters, it’s probably a good choice. It makes a very, very nice beam.
nokoff
nokoff's picture
Last seen: 3 hours 7 min ago
That’s how mine works so it’s Anduril. I reset the floor and ceiling. 1 click and then 150 clicks during the buzz/stutter and now when ramping up it ramps twice and when ramping down it ramps twice. What did I do wrong lol
Nokoff..still Made in China 山寨主義
ToyKeeper
ToyKeeper's picture
nokoff wrote:
I reset the floor and ceiling. 1 click and then 150 clicks during the buzz/stutter …
150 clicks?
It only takes one click to tell it the ceiling should be at turbo. Setting the ceiling to 150 clicks would be telling it to set the ceiling to the lowest level possible, and I’m not sure how it’ll react to that. I wouldn’t be surprised if it had a divide-by-zero error or something and went on strike.
nokoff
nokoff's picture
ToyKeeper wrote:
150 clicks?
Lol it was on strike, beam in the shape of a picket sign and everything! I have some Narsil and Anduril ROT66 and I think I jumbled something up, figured it was easier to ask than make it worse. Thanks Tk, that fixed it.
Chatika vas Paus
Last seen: 2 hours 10 min ago
I don’t know how to use Narsil. A bit because my English is weak and I do not understand the instructions. I can not navigate through the settings and change them.
Thats why I prefer Anduril. Because it has this:
Maybe if someone did a picture instruction for Narsil, I would try it again…
ToyKeeper
ToyKeeper's picture
Does this help?
Specifically, the following files:
  • NarsilM_CS_v12_Q8_2017-12-03.pdf
  • NarsilM_DE.pdf
The first has a UI table with arrows between tables. The second is a .de translation of the manual.
Chatika vas Paus
I tried to learn from NarsilM_EN.pdf and from the GT mini instructions and it seemed to me so complicated. But this table doesn’t look bad. Maybe I’ll try this weekend. Thanks TK!
