Review: Waveform Lighting A19 Centric Home/Daylight E27 bulbs (2700K, 4000K, 5000K)
17 posts / 0 new
maukka
maukka's picture
Last seen: 1 hour 10 min ago
Waveform Lighting sent me three of their A19 screw base (E27) LED bulbs for testing.
The models tested are:
Centric Home 2700K*
Centric Daylight 4000K
Centric Daylight 5000K*
The ranges also include a 3000K and 6500K model with similar specs. There’s also several other products lines including LED strips.
Waveform Lighting has to be commended for reporting the actual lighting parameters on their site with photometric reports. They do extensive testing of their own products, so this review is more of a 3rd party verification of their claims, which I’m happy to say are exactly as promised. Waveform’s site also includes several handy guides which explain various lighting parameters.
The main selling points and specs are:
-Excellent color rendering
CRI of 95+ and R9 of 80+
—TM-30-15 Rf of 90+ and Rg of 100
-Flicker free, no distracting PWM
-800 lumens at 10 watt power consumption (80 lm/W)
-AC 90-240V compatible with 50/60Hz supply frequency
-Both the American E26 and European E27 socket versions are available (E27 tested here)
-Not dimmable
-25k hour lifetime and 3 year warranty
-30 day money back guarantee
Measurements
All the bulbs exceeded their lumen output rating of 800 at lower than rated power consumption. I measured them at ~850-950 lumens at 30 minutes. The output does sag a bit as the lights heat up. The maximum external base temperature was just shy of 80 degrees Celsius. This is about 20 degrees less than the 1000 lumen LED bulbs from IKEA for example. Power consumption was a tad over 9 watts. Thus the efficiency is also better than specified at 95-105 lm/W.
I also have to note that I was very surprised at how light the bulbs were. Instead of 150 grams for an IKEA bulb, these weigh a mere 40 grams which results in undoubtedly cheaper shipping costs when ordered in large quantities. They are also much shorter and will as such fit more cramped fixtures.
The CRI data is from measurements in a 50 cm integrating sphere, but the bulb’s diffuser works very well so there’s practically no difference in tint or CRI no matter the beam angle. I didn’t do the normal beam profiling, since as is evident below, the tint isn’t really dependent on the viewing angle.
CRI data
Load IES TM-30-18 Color Rendition Reports:
2700K
4000K
5000K
Flicker
The flicker occurs at 48 kilohertz, so there’s no chance of it being visible. Snob index of 0% guarantees this. Interestingly, the modulation depth was higher on the 4000K and 5000K models.
Electrically the bulbs behave identically. They draw current in short burst (25% of the time) at near the peak of the voltage waveform. Scope data is shown from the 5000K version here, but there is no differences between the graphs. Power factor was measured at 0.62.
Cyan line: mains line voltage
Yellow line: current draw of the bulb
Violet line: power draw (voltage * current)
Verdict
To make it short and sweet, these bulbs are excellent with regard to color rendering and tint. The light is clean, slightly on the rosier side below the black body line, which is what most of us usually prefer. I usually prefer 4000K at home during the day, but this 5000K bulb with its pure white tint has to be one of the more pleasant ones I’ve tried. Of course the price of $17 may still sting if you want enough bulbs for the entire home.
Edited by: maukka on 03/05/2019 - 12:36
The_Driver
The_Driver's picture
Last seen: 23 hours 34 min ago
Wow! Those are very good!
I can also recommend the warm-by-click bulbs from the German brand Clarus. They offer “sunset dimming” with a very high CRI over the whole dimming range (2700k-1800K) and have basically a garantueed reddish tint (they use an additional red LED). They have the summer built in.
maukka
maukka's picture
They can’t but I generally just turn off individual bulbs to suit my needs. One 800 lumen bulb in a room larger than a closet is quite dim, especially when ceiling bounced or diffused some.
cetary
Last seen: 6 days 11 hours ago
Well, I have the 2700K 95 CRI 800 lumen varient on order. Still waiting for it. Looks very promising. For residential lighting, I find allot of manufacturers are out of spec. CCT with an upwards bias in color temperature. It’s great to see that isn’t the case here. The Feit bulbs are notorious for this, their 3000K are actually 3500K. GE is pretty bad about it to, around 3000K when they should be 2700K. My newer Philips 2700K A19’s are near 3100K, totally unacceptable. My newer Cree 2700K A19 also shows a 3050K color temperature. I see that blue-ification is the thing everywhere. It’s almost always out of specification CCT with a “cool” bias. There was always this thing that felt off with most LED A19 bulbs.
ToyKeeper
ToyKeeper's picture
Last seen: 55 min ago
These bulbs sound like they’re full of win. I’m tempted to order some 4000K bulbs.
The only downside I see is that they’re not dimmable. I wonder what they’d do if I hooked them up to a PWM-based dimmer anyway.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 1 day ago
Same thing here.
Will buy a pack of 6 for me, my SO, and will sell the remaining 3 to my friends.
cetary
My thoughts exactly, TK. It’s the closest thing to a 219B in a lightbulb form that I’ve seen.
Maukka, did you think about testing the 2400K bulb from Waveform? This opens up so many possibilities like their tape lights…
On another note, I got the CCT readings from some 2700K TCP bulbs in the vanity mirror in my bathroom, and they’re 3100K! Even my 3000K SST-20s are a warmer 3040K. Talk about out of spec.! There were some other people saying don’t mind the out of specification CCT, you’ll like it.. eventually. No thanks to that. If I wanted 3000K, 3500K, and so on I would’ve bought it in the first place. Sloppy manufacturing processes should not be justified.
virencelights
virencelights's picture
Last seen: 11 hours 42 min ago
a few questions here;
what kind of IKEA lamps could these go into ?.
what Watt does it have to be over?.
800 Lumens is a lot so I take it it cant be used in a desk lamp ?.
what is best?..got a link for a good IKEA e27 lamp?. desk would be good!.
_________
I got 5600k Daylight.
thanks.
Virence Custom Built; ArmyTek Viking Pro E21A 6500k 9080 Quadtrix, Jetbeam AAA 9080 E21A 9080 5700k, Jetbeam AAA Nichia HCRI Red Led.
maukka
maukka's picture
These will fit any lamp with an E27 socket. Their low power means that there probably isn’t a light fixture that couldn’t handle them. I use one of these Tertial workbench lights.
virencelights
kind thanks Maukka!.
firedome
Last seen: 7 months 2 weeks ago
Nice pictures and beam shots, thanks for the review! Thumbs Up
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
ToyKeeper
ToyKeeper's picture
Beam shots? I didn’t notice any of those…
… oh, wait. There it is. It took me a moment, but I found it. The beam shot is just under “Measurements”, to the right of the table. It’s really easy to miss if you don’t look very closely, so I highlighted it:
cetary
Got my 2700K Waveform A19 bulb, and I am very pleased. My example is closer to 2800K, but a much better match for incandescent then my Philips A19 LED. Will probably be replacing the CFLs in my place with them.
I also got the 2400K filament light from them, but it exhibits some odd behavior. It flickers on startup, but then it seems to smooth out a perciptable amount once running for about half a minute. Do you guys have any idea what this could be?
JaredM
JaredM's picture
Last seen: 1 day 18 hours ago
A day late for a Halloween resurrection.. but this was funny. Couldn’t go without giving Kudos Big Smile
Jinx
Jinx's picture
Last seen: 2 hours 1 min ago
Hope to see these easily available, it’s hard to find high CRI home lighting and it’s certainly still at a huge premium.
I’m waiting for some from V-tac to arrive that claim >95 so fingers crossed they are decent. Only 10w but cheap for what they claim to be.
Jerommel
Jerommel's picture
Wow, those lights get HOT !
80°C, 100°C Sad
But no wonder when the only exposed metal is the E27 socket..
