SunLike 3500K 95+ CRI midpower led from Seoul Semiconductors tested
66 posts / 0 new
Tally-ho
Tally-ho's picture
Last seen: 16 min 26 sec ago
Miguelito wrote:
ССТ 5000 is not good enough. Can’t underatand why every led company starting to produce new kind of leds from low CCTSad
Probably because there is a norm (IS0 3664:2009) in the graphic & art industry. “The standard dictates that when viewing prints, a light source that replicates the D50 light source should be used”.
SKV89
Last seen: 32 min 39 sec ago
clemence wrote:
djozz wrote:
Thanks. There was rumour a while ago (I hope it is not cancelled in the meantime) that in the future Nichia will come with high power Optisolis leds, if true they may prove ideal for your purpose.
Should be ready for purchase this year:
http://www.nichia.co.jp/en/product/led_sp_optisolis.html
[Clemence]
Clemence will they be compatible with your boards? With your 36 emitter board, we can get like 20k ultra hi cri lumens? Love
clemence
clemence's picture
Last seen: 2 hours 17 min ago
[Clemence]
My board? What for? With any COBs you can just plug and solder the lead. The idea of COB is you don’t need any MCPCB to mount the LED. Those tiny LEDs already internally pre-wired, soldered ready to use.
[Clemence]
SKV89
oh didnt realize they are cob
Miguelito
Last seen: 1 year 2 days ago
Many printings used Philips Master TL-D 90 Graphica 965 before led took the market. Do not know much about the norms,but D65 is also a standart I guess.
The_Driver
The_Driver's picture
Last seen: 2 days 17 min ago
Tally-ho wrote:
 I'm still using my HDS with stock Seoul SSC P4 for its very good CRI despite its poor lumens to size ratio. I mentioned its peculiar beam pattern "here":http://budgetlightforum.com/comment/1487803#comment-1487803. Once I got it, it stopped my flashlights quest for many years. I'm a bit puzzled by McGizmo's measurements about the CRI R12 = 66.1 because to my eyes it has deep and dense blue colors rendition, better than most CRI90 LEDs. -Blue colors look better than with a SST20 4000K to me.-
I used to own that light, it was my EDC for quite a few years. These days I use a Zebralight SC64c LE.
SunLike
SunLike's picture
Last seen: 1 week 4 days ago
If someone need, I just finalized draw pcb for 3030 sunlike leds
it is for 1-12pcs (12.5×99mm with 2.5mm holes) and 1-6pcs 3030 leds (22×22mm with 3mm hole)
3S4P or 2S4P or 8P
and
2S3P or 3P
Also you can cut it if you need
BelMORDOR’s Ламповщик|Lampman
https://t.me/sunlikenews
Joshk
Joshk's picture
Last seen: 22 hours 58 min ago
I would love to upgrade the 5 meters of LED strip above my desk to high CRI. I only paid $2.42 for this 5 meter strip.
But I calculate 5 meters of your SunLike LED strip would cost $392.70. Did I calculate that correctly? Is that price assembled?
SunLike
SunLike's picture
My pcb for 12pcs 3030 cost 0.5$ (50%G). 3030 leds from sunlike is about 0.6w each. Do you really need 350w (5×10×7w) led strip?
Joshk
Joshk's picture
These are running at 12v 1 amp. That’s 2.4 watt/meter. It’s about right, to maybe a little dim. 3watt/meter would probably be perfect.
SunLike
SunLike's picture
there is no 0.05w or 0.1w sunlike leds in this world, so, there is no led strip.. I could not find any pcb like I need, so, I drawed it by myself. It is not led strip, it is pcb what need heat sink. Also you can use only 2S (2pcs) leds in one board, it will about 12v, but be carefull, use resistor.
Also the same 12w will cost 17$ from me (20 leds and 10pcb boards 99mm long) or 14.5$ if if will be 22mm pcbs.
Joshk
Joshk's picture
What’s the target market for your high power led strip? Are these for grow lights?
SunLike
SunLike's picture
22mm can be used in flashlights because there is not high voltage (36v) like in COB sunlike. For growing I use another leds. But if someone already use sunlike bulbs where it is possible, he can use sunlike for plants. Eyes first, plants after =) Will go to sleep, sorry.
I drawed this 99×12.5mm for alluminium profile for led lamp 60sm, but also it can be in another size. It will be about 30-36w led lamp 60sm long.
Joshk
Joshk's picture
That’s some cool looking aluminum extrusion. Good job Thumbs Up
led4power
led4power's picture
Last seen: 2 hours 55 min ago
SunLike wrote:
If someone need, I just finalized draw pcb for 3030 sunlike leds it is for 1-12pcs (12.5x99mm with 2.5mm holes) and 1-6pcs 3030 leds (22x22mm with 3mm hole) 3S4P or 2S4P or 8P and 2S3P or 3P Also you can cut it if you need
One suggestion, it's much better practice to connect LEDs in series first, and connect those series strings in parallel.
Reason for this is LEDs Vf variance, if you connect multiple LEDs in parallel, current distribution could be unequal, LED with lowest Vf will draw highest current, and because of that if will become hotter, and Vf would drop even more, current would rise even more.. etc. I've seen this problem in LED T8 tube light, shadows and bright spots were visible because of unequal current distribution and measurements confirmed that.
With 3 (or more) LEDs connected in series first, all strings would have total Vf closer to average (more leds - more equal average total Vf among strings because of probability laws).
SunLike
SunLike's picture
I understand this situation, but:
1. seoul semico recommended to use their 3030 leds to 150mA, I recomend to use it on 85mA and I will use it with 0.5w
2. quality of leds is really good and it is almost with the same voltage.
3. when 1 led will die (shit happens) when those series strings in parallel, string will not work. If here, for example, 1 of 4 pcs will die, another 3pcs will work only 1.333 times more than 4pcs
4. in my situation it is possible to use it 3S4P and 2S4P and 1S8P
I changed price to 3030 leds on my web-site to 0.5$ and power too (now it is 0.5w, was 0.6w)
But seoul semico say that it is 150mA and 200mA max current. It is not good power to this leds, because the size of crystal not 1w. I mean it will die really fast with 150mA.
I just draw mixing 3:1, 2:1, 1:1
The_Driver
  4. in my situation it is possible to use it 3S4P and 2S4P and 1S8P ------ I changed price to 3030 leds on my web-site to 0.5$ and power too (now it is 0.5w, was 0.6w) But seoul semico say that it is 150mA and 200mA max current. It is not good power to this leds, because the size of crystal not 1w. I mean it will die really fast with 150mA.
Even "really good" LEDs (how do you know this?) have a variance in Vf from sample to sample.
When one of four LEDs dies, the other three get more current. This increases the chances that another dies (more current => more heat => Vf drecreases => more current => ...). This can continue until all four are dead.
SunLike
SunLike's picture
It is if leds works with almost 100% power. I will use only 0.5w or smaller.
Joshk
Joshk's picture
I agree with LED4Power’s suggestion and The_Driver’s opinion. It would be worthwhile to change the PCB layout. At the price point and quality your business targets, you don’t want customers noticing one LED is brighter than the others. It will make them nervous and could result in some warranty claims. I would take their advice if it were my PCB.
SunLike
SunLike's picture
I have my own approach. If you will find at least a 20% difference in brightness, I agree to give you everything what you will choose on my web-site for $ 200
Ok. I am going to do another board. about 12.5×99mm, what will work from any 18-22v power supply from notebook. I will do their 4P3S
If you know size what will be better, let me know. For example 15×99mm or etc
I am going to use NSI50350ADT4G
or NSI50350AST3G
it is 350mA
SunLike
SunLike's picture
Hello, peoples of the flat Earth!
Well done! about 6 hours (for this board)
120-240-360-480mA or etc with NSI constant Current Regulators (yes, it is not cheap)
from 18v to 25v
also you can give 12v if instead of 1 LED, you will set a jumper (wire)
also you can use led driver if you will set a jumper (wire) except CCR
12×99×1.6mm m3 holes
also you can cut up to 1.5+mm from the both sides
50%G (Grower)
G≈$
Joshk
Joshk's picture
It looks good. The CC regulators are not even necessary for good performance.
Backing up to the previous design, you see how the current is given the choice to take the path (the LED) of least resistance at every level? That’s not good.
But your new design is immune, even without the expensive regulators.
SunLike
SunLike's picture
it is not critical. because there is only ~300mA
And I am going to not parallel this boards, because I need 36-54v. I will be S, so, current will go from left to right or etc.
Also you can do not use CCRs. It is maximum universal. Also I have 5+h video. I make it when I draw this board =) It is real 6h to do this board
Joshk
Joshk's picture
On a different topic, I was curious about this:
50%G (Grower)
G≈$
Is that a price? I haven’t seen percent used like that before.
SunLike
SunLike's picture
50%G (Grower)
G≈$
Yes. It is 50perCents =)
Also it is real money in my village =)
Joshk
Joshk's picture
So 50%G is about $25?
SunLike
SunLike's picture
No =) it is 50% from 1$. It is 0.5$ or $0.50 if you like that style
Joshk
Joshk's picture
Interesting. Thanks.
Joshk
Joshk's picture
I know you don’t agree the time spent changing the PCB was necessary technically. But perhaps look at it from the business angle. This new design eliminates a possible criticism of your products. Competitors can not claim you made a mistake.
SunLike
SunLike's picture
I do not think, that 3S4P was with mistakes in design. But 4P3S was not so easy designs pcb. v1.0 was for 1 CCR 350mA, but it was impossible, 1.1 was for 4×4pcs sod123 CCRs. I do not think that 4P3S better than 3S4P. But if you like it more, now you can choose. Tomorrow I will add order to pcb manufacturer for 150-200pcs.
