Affiliate Link: https://www.banggood.com/Astrolux-MF04-XHP35-HI-Searching-LED-Flashlight-p-1289449.html?p=R4240016492493201711&custlinkid=166026
I'll post pics in a week or two. For now, here are some from banggood.com:
Specifications
Product name: | Astrolux MF04 XHP35-HI Searching LED Flashlight |
Brand: | Astrolux |
Model: | MF04 |
Emitter Type: | XHP35-HI |
Light Color: | Cool White (CW) |
Color Temperature: | 6500K |
Peak Beam Intensity: | 1460000 CD (Max.) |
Max Output: | 2700 Lumens (Max.) |
Range: | 2416 Meters (Max.) |
Mode: | Moon, Medium, High, Turbo, Strobe, SOS, Beacon |
Lumens: | 15LM, 350LM,1700LM, 2700LM, 2700LM, 2700LM, / . |
Runtime: | 300H, 25H, 3.5H, 2.5H, / , / , / . |
Battery Configurations: | 2x 18650 or 4x 18650 Li-ion Battery (Not included) ( Sumsung 30Q 20A 18650 Power Battery Recommended) |
Switch Type: | Clicky |
Switch Location: | Side of the flashlight |
Material: | Aerospace grade aluminium alloy |
Impact Resistant: | 1 Meter |
Waterproof: | IPX-7 Waterproof |
Lens: | 3MM toughened ultra-clear glass lens with anti-reflective coating |
Reflector: | Large-diameter high reflectivity aluminum reflector |
Carrying Strap: | Strap |
Color: | Black |
Weight: | 1290g without battery |
Size: | 234mmx 136mmx 54mm (Heightx Head diameterx Body diameter) |
Features:
1. High performance long-rang searching-level royal Flashlight
2. High efficiency constant current circuit and Integration optical lens
3. Large-diameter reflector cups make the light gathering ability stronger, and the light intensity is greatly improved
4. Memory function in brightness mode. When the flashlight is turned on again, the mode will stay in the mode which was last turned off
5. Intelligent temperature control design, automatically reduce lumen output when temperature is higher than 55℃ in turbo knurling design
6. Breathing switch function: Monitor working process of battery capacity and voltage
7. Added a PTZ screw hole on the head to fix standard 1/4 inch Tripod mount
8. Head fin adjustment and design to speed up heat emission
9. Configure a strap to make your trip more convenient
10. Handle, switch button and gravity control, is more ergonomic to facilitate your operation
11. Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
12. IPX-7 standard waterproof, can be used in rainstrorms
Notes:
1. Battery Configurations: Sumsung 30Q 3000mAh 20A Battery Recommended
2. Do not disassemble the lamp head, otherwise it is easy to destroy the bulb
3. In order to reduce weight, the original battery holder is made of aluminum alloy.(But it is common with the brassiness battery holder of MF01 MF0.)
Package included:
1 x Astrolux MF04 XHP35-HI Searching LED Flashlight
2 x Spare waterproof O-rings
1 x Lanyard
1 x Strap
1 x User manual
Accessory recommended:
