Convoy L6 [P2-3C] XHP70 3800LM 200-500meters IPX-8 $46
1 post / 0 new
LumenMax
LumenMax's picture
Last seen: 7 hours 21 min ago
Code: BGNL6 (Must select P2-3C - 5000K color temperature)
  • Order Subtotal: US$71.57
  • Coupon Discount: US$25.57
  • Grand Total:US$46.00
Cheapest deal on this was $39.99
Affiliate link: https://www.banggood.com/Convoy-New-L6-XHP70_2-4300lm-5000mAh-Powerful-S...
Specification:
Product name: Convoy L6 XHP70 3800LM LED Flashlight
Brand: Convoy
Model: L6
Emitter Type: XHP70 (soldered on 20mm copper plate)
Emitter BIN: N4-1C,N2-3A,N4-5C,N2-7A
Light temperature: 6000k(white light),5000k (neutral white),4000K,3000K
Material: Hard-anodlized Aluminum alloy
Mode: Low 50mA,Mid 200mA,High 1700mA,Turbo 5200mA,Strobe
Battery Configurations: 2 x 26650 6A protected battery(not included)
Switch Type: clicky
Switch Location: Tail switch for turn on and off,
body switch for change modes and double click the button the light will strobe.
Max Output: 3800lumens
Range: 200-500meters
Reflector: Orange peel reflector 67.8mm x 48.2mm(diameter x height)
Lens: Ar-coated lens
Waterproof: IPX-8 waterproof 2 meters
Color: black
Weight: 255mm x 75mm x 35mm(length x head x body diameter)
Size: 550g without battery
Note:
1.Please take out of the battery when the flashlight no use for long time.
2.When setting the tactical ring please take out of the ring on the flashlight.
3.Please use 2 x 26650 6A protected battery to confirm the safety of the flashlight.
4.When carry the flashlight in the backpack,please loose the tail cap in case of wrong click to the button.
Package included:
1 x Convoy L6 XHP70 3800LM LED Flashlight
1 x Tactical ring
Convoy L6 XHP70 3800LM Super Bright Long Range LED Flashlight
