[♛ FreemeGB] ASTROLUX MF01S 15000lm Flashlight Group Buy + Diffuser Cap - ALIVE
1417 posts / 0 new
ssschen
ssschen's picture
Last seen: 1 week 2 days ago
Please add me to the GB list. Thank you.
ToyKeeper
ToyKeeper's picture
Last seen: 2 days 1 hour ago
pearlriver wrote:
ASTROLUX said that it has been manufactured in batches, and will be on sale in the middle of next month.
Yeah, I got the light to behave thermally, so I think it should be almost ready to buy. Here’s an example of a thermal test with the maximum temperature set pretty low to make things harder for the thermal algorithm:
Given the style of power channels used, this result is pretty close to optimal.
SKV89
Last seen: 1 hour 20 min ago
Which emitter is it using? The sustainable lumens seems low if it is xpl hi or sst 20 70cri. The heat shedding of this version is significantly improved by TA from the original MF01 so should do better than this.
Th558
Th558's picture
Last seen: 23 min 42 sec ago
Seems kinda disappointing tbh. Efficiency could be better. It’s set to only 45 degrees so I guess it could sustain higher output.
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 56 min ago
It’s probably using the SST-20 95CRI emitter, as it seems inefficient.
ToyKeeper
ToyKeeper's picture
I think this is SST-20 4000K 95CRI, which runs hotter and less bright than the lower-CRI versions. Just checked again, and it’s definitely around 4000K, so it’s not the 5000K 70CRI version.
Texas_Ace
Texas_Ace's picture
Last seen: 10 hours 17 min ago
Yes, you should have the 4000k FD2 bin LED’s if they did as I asked lol.
ToyKeeper
ToyKeeper's picture
This high-CRI version is only supposed to make about 10,000 or 11,000 lumens, but I measured it at 13,900 lm at start with a set of just-charged 30Q cells.
This was measured with an integrating tube, so it’s not as accurate as a sphere… but it’s pretty close. I used some biased diffuser sheets to improve the integration qualities, then calibrated it to match reference lights from maukka. The sheets force the light to spread out and bounce around inside, so it’s less favorable to throwy lights. It also acts as sort of like one-way valves, which reduces the impact of the entry point and initial bend, so it gets more consistent readings for a wider variety of lights. But it’s still not as good as a sphere.
Anyway, I think it actually could make 14,000 lumens with some high-amp cells like 25R. And more, when using lower-CRI emitters. Just not for very long, because it gets hot fast.
Lund1660
Last seen: 1 day 9 hours ago
All the technology in today’s world and astrolux uses a camera from the late 1990s.
JasonWW
JasonWW's picture
Last seen: 8 hours 52 min ago
What are you refering to?
Click this to go to signature links.
SvenWalker
Interested!
Lund1660
The last post on page 12
JasonWW
JasonWW's picture
Nothing shows up for me, but the coding says it’s an animated gif, not a picture. Typically gifs are grainy so that must be what your refering to.
SKV89
TK, will the first batch of lights get updated with your improved thermal regulation firmware?
ToyKeeper
ToyKeeper's picture
I don’t have any details on that. I hadn’t even heard there was a first batch.
SKV89
Im referring to the yet to be on the market first batch that is supposedly already in production.
mortuus
mortuus's picture
Last seen: 12 hours 1 min ago
but looking at the graph it shows at around 2m its already down to 2000 lumens only ? kinda low to me..
...where Frugal meets with Flashlight!
Texas_Ace
Texas_Ace's picture
Only the metal parts are in production at this point last I heard. The driver and firmware have yet to be finalized. Could be wrong though.
d_t_a
Last seen: 13 hours 39 min ago
This Astrolux MF01S looks very similar to the Emisar D18, as both use 18x SST20 emitters, and both use Anduril firmware.
Just curious what would be different about this MF01S compared to the Emisar D18? The D18 uses 3×18650, so the batteries have to work harder to put out higher lumens (need to use very high-drain 18650s on the D18), whereas the MF01S uses 4×18650 so the current drain per battery is notably less. (I’m assuming that the higher max lumens on the MF01S compared to the D18 is mainly due to the MF01S having 1 more battery to drain current from).
I would presume the MF01S, having a 4×18650 body, may have a bit more thermal mass so heat may be able to dissipate a bit better — at around what lumens does the MF01S stabilize (it seems to be nearly 2000 lumens from the above graphs), doesn’t the D18 also stabilize at nearly 2000 lumens?
How about in terms of beam pattern, I’m curious how the MF01S compares to the D18 (the D18 has a focused spot, corona and useful spill area of light).
Texas_Ace
Texas_Ace's picture
Keep in mind that the D18 was 70CRI LED’s and the MF01S above is 90+CRI. So the lumens will be lower naturally.
shirnask
shirnask's picture
Last seen: 2 hours 47 min ago
The D18 is available with 4 different emitters 2 of which are 95 CRI
Led & Tint
Cool White – SST20 6500K
Neutral White – SST20 5000K
Neutral White – SST20 4000K 95CRI
Warm White – SST20 3000K 95CRI
SKV89
Led & Tint
I think TA meant the D18 sustained output was tested with 70CRI emitters whereas TK tested the MF01 with 95CRI emitters so you can’t directly compare these sustained outputs.
Lexel
Lexel's picture
Last seen: 2 hours 35 min ago
with the firmware you can calibrate the temperature and set the ceiling higher
JasonWW
JasonWW's picture
This was not a test for highest sustainable lumens. This was a software test of how the driver handles heat. Two different things. So I would not make assumptions.
To test max sustainable lumens you start at a certain lower lumen level and see how the light behaves. Temperature will build up much slower which may or may not activate the thermal management and you should get different results.
It will probably be in the same 2,000 to 3,000 range, but probably higher than what the tests above show.
My point is you should not jump to conclusions. Recognize what is actually being tested. (I might be grumpy today)
ToyKeeper
ToyKeeper's picture
They’re a similar concept, but there’s a significant difference in size, beam shape, driver type, and extras. The MF01S is larger/heavier and holds 4 batteries in a carrier instead of 3 in the tube. The MF01S has a big wide “wall of light” hotspot with virtually no spill, similar to a Noctigon Meteor or a triple in a Carclo 10507 optic. It uses a 2S2P 2-channel driver at 6V instead of a 4P 3-channel driver at 3V. It also has colorful aux LEDs and a lighted button and a tripod mount hole.
I’m the wrong person to ask about which is better though, since I mostly stick to smaller lights.
Also, I probably shouldn’t be telling people which of two clients to send their money to… so I don’t get to have a public opinion on this sort of thing.
nick779
nick779's picture
Last seen: 1 month 6 days ago
Hopefully I wasnt getting my hopes up over this. Im pretty much sold on a D18, but the driver and the aux board on this were definitely interesting. Im surprised it doesnt really show much difference over the D18’s specs considering its size and assumed increased driver efficiencies.
Texas_Ace
Texas_Ace's picture
The drivers themselves are basically a wash on paper. The D18 should be a bit more efficient at lower modes and the MF01S a bit more efficient at higher modes.
I expect the optic efficiency to be larger then the drivers.
robertino
Last seen: 2 months 4 days ago
Interested, pending price.
d_t_a
Thanks for clarifying the distinction between the 2 flashlights!
Have a few more questions:
MF01S: big wide “wall of light” hotspot with virtually no spill
D18: has a smooth hotspot, corona and spill
Just curious, is the above difference due to having different optics used by the MF01S vs the D18, or also due to the size of the heads (I’m guessing the MF01S has a bigger head since it has a bigger 4×18650 body tube)
ToyKeeper mentions:
MF01S: 2S2P 2-channel driver at 6v
D18: 4P 3-channel driver at 3v
I’m not that well-versed in electronics, so maybe need more explanation for me to understand… 3-channel driver is more efficient at lower modes, whereas 2-channel driver at higher voltage is more efficient at higher modes. Is that the correct line of thought?
D18, 3 channel is FET+7+1? while MF01S is FET+1?
Texas_Ace
Texas_Ace's picture
In my testing the 3 channel vs 2 channel efficiency difference was not nearly as much as many people used to think.
That said the 3 channel will have a fairly small window in the low/midrange where it has a bit of an advantage simply because it has a channel specifically designed for that output level.
At other output levels the only real difference is the input voltage.
Honestly there it is not even worth talking about driver efficiency. We are talking about a ~10% change in efficiency one way or the other depending on the exact output level. Considering the LED’s have a tolerance of 12% themselves there are simply better things to worry about.
