[♛ FreemeGB] ASTROLUX MF01S 15000lm Flashlight Group Buy + Diffuser Cap - ALIVE
1427 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 23 min 41 sec ago
Texas_Ace wrote:
Since it will be using Narsil with ramping you can set it to any power draw / lumen output you want pretty much.
This reminds me, does it have the gap between “top of ramp” and turbo? Like steps 1 to 140 then jumps to 150? Will it be a small or big jump?
Click this to go to signature links.
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 57 min ago
Yes, the ramp will end short of full turbo. This has proven to be the best setup over time for a few reasons. In this light an important one is how fast it heats up on full turbo. The top of the ramp noticeably improves the heat up time.
Far as how big the jump is, something around the last 10-15 steps sounds right. Visually it looks like what you would expect the next mode to be.
Unloco
Last seen: 1 hour 34 min ago
Interested.
No glue, please.
surasakkongtha
Last seen: 1 day 21 hours ago
Interested
adam7027
Last seen: 4 hours 19 min ago
Hello Texas_Ace,
I just ask, if a 2S3P or 3S2P battery compartment were considered.
That would be only as thick, as a 1S3P compartment, just twice the length. That could be good for hand holding – but the flashlight body would lose the ‘soda can’ format.
Still, it would be a nice to have for longer runtime and less strain on batteries.
Texas_Ace
Texas_Ace's picture
I mentioned several options along these lines but they were adamant that the basic form factor must remain the same as the first version. Not sure why.
That said there is nothing keeping future lights from being developed in other form factors. Although the triple 21700 format is not something I am itching to jump behind for a few reasons. Most were stated above, there are just not many advantages over a 4× 18650 setup and 18650’s are a lot more common. A triple setup is also a very odd voltage that is hard to use as well.
akoposilester
akoposilester's picture
Last seen: 1 week 2 days ago
Interested!
FL Newbie
nokoff
nokoff's picture
Last seen: 1 day 4 hours ago
Interested
Nokoff..still Made in China 山寨主義
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 53 sec ago
Texas_Ace wrote:
I REALLY want to use Anduril firmware on this light but …
This is the light you were asking about? I thought it was a GT variant of some sort.
Texas_Ace wrote:
slowly get up to 100c+ … a bug in the code itself that TK has known about for some time. She was able to bandaid the issue for the D4S but for a large light like this it seems the bandaid does not work.
There is a known bug, but it doesn’t involve slowly getting up to 100C… it’s something else entirely. The known bug is about responding quickly enough to the initial peak, and has nothing to do with what happens later.
The bug has an optional workaround called a “hard turbo drop”. However, the D4S does not use this workaround. It works fine as-is without any bandaids.
The code also seems to work fine on the Emisar D18, which is extremely similar to the MF01S, so I don’t think the issue is due to the overall type of light.
I haven’t been able to reproduce the slowly-rising-to-100C bug locally, and it doesn’t show up on any reviewers’ published runtime tests for existing lights.
I don’t have all the details, but from the limited information available, it sounds like it’s probably one or more of the following:
  • Not calibrated or configured correctly. PID systems oscillate when they’re not tuned right.
  • There could be insufficient thermal transfer from the emitters to the MCU’s sensor. If it was only sensing heat from chips on the driver, and not from the emitters, it would be inclined to drop while it has extra voltage to burn off, and then increase power when battery voltage gets close to emitter Vf. This could be the case if the driver is burning off extra voltage and the MCU is insulated from the emitter heat but not insulated from the driver’s own excess-voltage heat.
  • There could be something else related to the driver itself. I don’t know much about the driver in this light.
  • There could be something else changed in the code to introduce new issues.
adsum
adsum's picture
Last seen: 1 month 23 hours ago
Interested.
Itsme
Last seen: 1 day 8 hours ago
Interested depending on price
Glenn7
Last seen: 1 day 22 hours ago
interested
Bruno28
Last seen: 1 month 4 days ago
Interested Smile
Lexel
Lexel's picture
Last seen: 3 hours 27 min ago
I asked Matemineco to fasten up the thermal response a lot this way, hope this will fix the firmware issue
a thermal Pad between MCU and copper cylinder
also clearly visible the LED shelf got thicker from the original MF01
ToyKeeper
ToyKeeper's picture
Lexel wrote:
I asked Matemineco to fasten up the thermal response a lot this way, … a thermal Pad between MCU and copper cylinder
If I understand correctly, most of the thermal transfer generally comes through the driver’s copper layers. This can happen through the LED wires and then through traces leading back to the MCU, and through the driver’s outer ring and the copper pours which lead back toward the MCU. Also from the regulator chips and their traces connecting to the MCU. Some heat can also come in through the MCU’s outer shell, but I get the impression it might be a relatively small factor. I haven’t found significantly different results when I place thermal transfer foam between the MCU and the emitter shelf, but I also only tried it once.
The behavior I heard about was a matter of oscillating gradually upward after the initial peak had passed. Oscillating is typically a sign of poorly-tuned PID, and I’m not sure what made it rise over time. I haven’t looked into it in detail because I’m not really involved in making this light and Mateminco hasn’t asked me to.
Lexel
Lexel's picture
oweban wrote:
Lexel, will the aux LEDs be adjustable or be able to be completely disabled from the main firmware, or only from the trimmers on the aux board? And if it’s just the aux board, they better make sure not to glue it!
AUX LEDs can be controlled as in other firmwares like Anduril or NarsilM
oweban
oweban's picture
Last seen: 8 hours 33 min ago
Great, thank you! (I’m still learning about all the firmware options and types)
Glov
Last seen: 14 hours 39 min ago
Interestede, depending on price
Texas_Ace
Texas_Ace's picture
Yes, this is the light that was having issues, I was under strict instructions to not post anything about it, although I offered to explain it in a PM to you if it would of helped.
Ok, I stand corrected on the bug, in my defense you never gave much information on it other then to say you know about the bug Wink
Far as the possible issues.
1: I have tried it both with the temperature calibration and without, same results. Although I am still lost as to how the temperature offset could effect the workings of the thermal system as a whole, seems like it would just offset the thermal control points.
2: I ran another test yesterday with thermal pads on the MCU giving it an almost direct connection to the body of the light and got the same results. It would of also wicked away any heat from the driver, although that is minimal.
3: The driver is the same basic layout I have been using for awhile, DEL helped me get it right so it is very stable. I also tried anduril on some other lights like the MT09R and it also overheated, just took longer since it has more surface area.
4: I have tried using the pre-made hex file from your repo for the D4S / D4 and got the same results with them as well. I also tried the changes you suggested to the code with no real change except slowing the process down. Overall the only things I changed in the code was added the new layout files, which were basically just copied D4S since they use the same pinout then changing the ramp for the higher output.
The thermal control works fine at first, it ramps down nicely and looks like it will maintain the set temp at first but then it just keeps ramping the power back up even when WELL over the thermal set point using the self reported blink out.
This is what has boggled me, why does it keep ramping the power up even when it knows the temperature is 100c via the blink out? It seems like it should lock it to the lowest output once the temperature is above the set point. If it would just lock it to the lowest mode when above the set point, or say ~10-20% above it, it would be fine.
Texas_Ace
Texas_Ace's picture
I have tried this with thermal pads already, it actually seemed to make the problem worse as it overheated even faster then normal. Yes they are a bit higher thermal resistance then metal but still plenty to eliminate heat from the driver itself interfering with anything.
Although I doubt that is an issue since the self reported temperature from the firmware is within ~2-5c of the real temperature, and it is usually 2-5c lower then the real temp, not higher.
Indeed, the shelf is a lot thicker this time around.
ZozzV6
ZozzV6's picture
Last seen: 1 day 12 hours ago
To this thermal pad thing:
I tried silicone thermal pad with Andúril in my D1 long time ago. Here is the thread about the results.
ZozzV6
ZozzV6's picture
Maybe there is time to step up with another atmel with more I/O pins and use external NTC placed on the MCPCB like on led4power led stars.
ToyKeeper
ToyKeeper's picture
ZozzV6 wrote:
To this thermal pad thing: I tried silicone thermal pad with Andúril in my D1 long time ago. Here is the thread about the results.
That’s a really interesting test, especially with the thermal pads involved. I wonder how it would behave with newer code, because it has changed a lot since then.
Future Lights
Future Lights's picture
Last seen: 1 month 1 week ago
The Samsung INR18650-30Qx2 I have been ordering through BLF Banggood offer (page20) says flat top unprotected but the BG page says protected but the length are short, so that is just a fault right?
BG page
mortuus
mortuus's picture
Last seen: 10 hours 21 min ago
BG page
30q are not protected, i guess wrong yea..
...where Frugal meets with Flashlight!
JasonWW
JasonWW's picture
BG page
You can buy protected 30Q if you want to, but this particular ad just seems mislabeled.
carmantl
Last seen: 9 hours 12 min ago
Interested, hopefully orange or clear.
blueb8llz
Last seen: 30 min 56 sec ago
Interested
nokoff
nokoff's picture
I’m pretty excited about this one, great grouping of features with the AUX LED and Anduril. I think the SST20 should manage to output a very postive runtime.
I’m not concerned that the MF01S isn’t the brightest or smallest soda can on the block. I already own an Acebeam X80 with 12x CREE XHP50.2,2x CREE XPE2-R2 630nm, 2x CREE XPE2-B4 475nm, 2x CREE XPE2-G3 530nm, 1x Nichia 233A 365nm. I’ve also got 4 ROT66 with SST-20, XPL-HI, and 219b emitter groups. IMO it’s really about features in this classification.
Dioda
Last seen: 3 hours 45 min ago
Interested.
