Emisar D18 introduction
957 posts / 0 new
niktak11
Last seen: 44 min 18 sec ago
Looks like I can finally replace my meteor. What is the maximum fully regulated output?
JasonWW
JasonWW's picture
Last seen: 40 min 8 sec ago
I suppose it will use all 14 7135 chips at 0.350A each so that’s 4.9A.
Then 4.9 ÷ 18 is 0.27A each. I think the sst20 will do maybe 70 lumen at that output so that’s roughly 1260 lumen. We won’t know exactly until it’s measured, but that’s probably the right ballpark.
The cooler temp leds might be higher than this and the warmer temp leds might be lower.
Click this to go to signature links.
niktak11
Excellent. Even the highest regulated mode on the D4S puts out a substantial amount of light.
CREEXHP70LED
CREEXHP70LED's picture
If the XPL-HI 3A fit and are available in the future I am in for 2 of these. Wink
koziy
Hank Wang wrote:
This is how the 3*18350 tube look in the 3D file, short and thick, what do you guys think?
I’m not interested in the shorty tube, but I will buy one with the 18650 tube.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 53 min ago
JaredM wrote:
when have you ever used a light in this category on lower modes (of which are achievable in much more pocketable form factors) long enough to deplete the batteries and require a change?
Stubby lights like this make great lanterns, and when using them that way, they can be on for several hours at a time. I’m hoping that Hank might consider making a lantern attachment or a diffuser cone attachment too, in order to make that style of usage more feasible when there is no ceiling to bounce off.
I haven’t been able to properly measure it, and I don’t have optics, but the highest regulated level should be somewhere in the range of 1500 to 2600 lumens. I did a quick test and got 1948 lm, but I don’t have great equipment for this.
JasonWW
JasonWW's picture
Wow, that would be quite a bit higher than I figured. All good news. Thumbs Up
lionheart_2281
lionheart_2281's picture
Last seen: 2 hours 27 min ago
Ultra keen, even moreso for XPL HI 5000k if that ever comes to fruition (extra $25-$30 doesn’t worry me)
lawallac
lawallac's picture
Last seen: 1 hour 4 min ago
That’s not a flashlight. That’s a Lumen Grenade.
alexirc
Last seen: 3 months 20 hours ago
Very impressed with this light. I’ll be buying one, as well as a 18350 tube for it.
manithree
Last seen: 2 hours 17 min ago
djozz wrote:
Can we get light creeping out of the fins like in the picture? Party
Only if you hold it at exactly (0,0,0)
JaredM
JaredM's picture
Last seen: 2 hours 11 min ago
Yes. I thought of this as well while writing the post, but as you said, without a diffuser I figure that wasn’t the primary design intent or average use case (as marketed). The 18x emitters and their resultant efficiency lends well to long runtime applications for sure, but I feel like Hanks primary focus was making a more pocketable, yet more powerful successor to the M43. Only way of achieving the former by any meaningful margin (and in general to differentiate from competitors) was to go to a 3cell config and between the FET driver and 50% more LEDs he got the latter. Thus my assumption behind this question/statement was in a use case where you are holding/carrying the light the entire duration of a discharge cycle.
A lantern mod kit would be awesome. Maybe including a new tailcap with tripod mount and a bezel-replacing screw-on diffuser that reflects light outwards (shielding the center ~20 degree half angle)
ToyKeeper
ToyKeeper's picture
I have a few soda-can lights. For most purposes I find them too large and too heavy, but I still find them useful for photography and lantern purposes. They’re good at providing fill light, when bounced off large surfaces. Also handy on a tripod. Or for lantern purposes, I’ll often put one on candle mode for several hours at a time. I keep a Q8 next to my bed and use the candle mode timer so I can see for a while but it turns itself off shortly after I go to sleep. Candle mode works well during a bath, too.
SKV89
Last seen: 12 min 25 sec ago
I feel the same about soda can lights. Single cell lights are most practical for me. The E07 is the most practical hotrod for me because of the pocketable size. With thay said I will still buy this since it is an Emisar. I might be able to fit this in my coat pocket.
nokoff
nokoff's picture
Last seen: 1 week 1 day ago
If you like programming :), you should give a try to a WiFi bulb if you haven’t yet. Mine work with Alexa so I use voice command for color, brightness level, and on/off. I set for red each night on timer and have alarms set for the morning to come on at 1% brightness in red and stay on for a fixed time. It’s all programmable in the app. They turn themselves off if I leave the house and forget too. I adorbs them. The brand I use has a deep red hue for night vision, zero issues with connectivity, and works with multiple bulbs as a group.
Nokoff..still Made in China 山寨主義
Hikelite
Last seen: 7 hours 4 min ago
3*21700 makes the light bigger and heavier
45grams*3pcs 18650 = 135grams
68grams*3pcs 21700 = 204grams
45grams*4pcs 18650 = 180grams
3*21700 add much more weight, much bigger, literally the size of 4*18650, but even more weight.
And 21700 does not bring more runtime, just much more amps that go just as fast due to lower resistance for turbo. Unless you don’t want to not use turbo and want to cruise a heavy light at 2000lm, which then simply you wouldn’t carry. Who carries 3*21700 heavy light for the sake of longer runtime at non-turbo levels of 2000lm? For that matter I’d rather carry a single cell light with a low resistance cell
Considering everyone got the lowest resistance cells for single 21700 flashlight, I wouldn’t go and buy some lwoer resiatnc cells just to have more runtime in at lower levels in a heavy light.
mattadores
mattadores's picture
Last seen: 2 hours 32 min ago
+1 for interest in the shorty 18350 tube
I don’t own any 18350s and personally hate the feel of even my GT mini with the tiny 18350 tube. But when I eventually buy this light if the 18350 tube is available, I would always buy the attachment. If you build it, the gadget lovers will come!
I, like many here like gadgets and I’ve personally never been able to resist gadgets that have other gadgets you can attach to your gadgets that make them even more special gadgets. Crazy
… extension tube or shorty tube or lantern kit… make it and I at least, will buy all the accessories!
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 hours 51 min ago
I vote for an D18 18650 extension tube (6p configuration)! Silly Love
mattadores
Lol yes I’m quoting myself! lol I’m not sure I’ve seen that before but oh well!
Just a visual representation for those who don’t quite get my statement:
non-gadget/accessory/attachment lovers gun:
my gadget/accessory/attachment lovers gun:
Agro
Agro's picture
Last seen: 1 hour 34 min ago
Literally longer and literally larger diameter.
Skylight
Skylight's picture
Last seen: 17 min 52 sec ago
+ 1 Thumbs Up
Already voted for the 18350 tube! Cool
Salty_Pancake
Definitely interested in this, as well as the 18350 tube
DB Custom
DB Custom's picture
Last seen: 6 hours 5 min ago
Ok, so make my D18 with a copper pill section, SS bezel and Titanium head and body. Big Smile
ohbreeeezy
ohbreeeezy's picture
Last seen: 3 months 4 days ago
!https://intl-outdoor.com/images/20190316103816.png!
Is 26650 tube possible?
JasonWW
JasonWW's picture
Just to save weight? There’s a lot of wasted space. I don’t think it would be popular.
DB Custom
DB Custom's picture
3 parallel 18650’s will easily deliver more current to the 18 emitters than a single 26650, as well as have a LOT more capacity. So while it may technically be feasible to use an 26650 it wouldn’t be ideal.
DB Custom
DB Custom's picture
If this one is made similar to the M43 you could always leave a cell or two out if absolute weight savings were critical. The light’s performance would, of course, be handicapped.
gregor
gregor's picture
Last seen: 5 hours 9 min ago
Do you know when this FL will go on sale and what will be exact price?
Thank you
ToyKeeper
ToyKeeper's picture
gregor wrote:
Do you know when this FL will go on sale and what will be exact price? Thank you
Hank estimated it’ll be available to buy before the end of the month, for under 100 USD.
ToyKeeper
ToyKeeper's picture
SKV89 wrote:
ToyKeeper wrote:
I have a few soda-can lights. For most purposes I find them too large and too heavy, but … photography … lantern … candle mode …
The D18 is pretty small, but it’s also clearly designed to take a lot of heat. It’s very solid. So don’t drop one on your foot. The flashlight will be fine, but I can’t really say the same about the foot.
Mostly, I’m just surprised how well it can tank ~50A (150-200W) of power. It doesn’t get hot quickly, and it seems like it can sustain at least a couple thousand lumens indefinitely without getting too hot.
