Convoy S9 Carbon Fibre & Lighted Switch Fixed
5 posts / 0 new
CRX
CRX's picture
Last seen: 14 min 34 sec ago
Convoy S9 CF SST-40 - SD - 18650 - EL Sw - 1160lm - Rechargeable.
I thought it was a bit silly for the Convoy S9 to have the lighted switch illuminated only when the light is on so I installed a white LED under the switch cover which is always on unless the light is locked out.
I shortened the battery tube and installed a magnetic tail, the magnet is not too strong but just enough to hold the light horizontally.
The original switch boot is covered in some GITD power & silicone mix which also makes it a little firmer to operate.
27mm x 1mm 3K carbon fibre sleeve on head & body and resistor modded for more current.
Charging indicator LEDs can be seen from the side. Driver cavity is potted.
Stock driver/ 1A USB charger unit with resistor mod so still four modes with 0.5s press for On/Off and single click to progress through the modes while the light is on. The UI takes a little getting used to but is tolerable.
Aluminium & Carbon Fibre shell
Luminus SST-20 6500K Emitter
16mm Copper DTP MCPCB
OP Reflector
GITD O-ring & LED Surround
Lockout-able
Shortened Body
Magnetic Tail
Potted Internals, including the USB port
Lighted & GITD Electronic Side Switch
Low - 9lm
Med - 60lm
High - 435lm
Max - 1200lm
Length – 106mm
Width – 27mm
Weight – 125g (with 18650 cell)Convoy S9 CF SST-40 - SD - 18650 - EL Sw - 1160lm - Rechargeable.
Edited by: CRX on 03/14/2019 - 09:37
MascaratumB
MascaratumB's picture
Last seen: 2 hours 4 min ago
Sweet Smile Like the way the switch looks like Wink And turned out great with the CF Thumbs Up
I wish I had the ability to mod this light’s driver; i would get one! The current UI is a no-no!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Yeah it’s not the best but not the worst either.
I’ve never liked lights that you need to press & hold for On & Off but the S9 isn’t too bad.
-X3-
-X3-'s picture
Last seen: 41 min 10 sec ago
I wanted to like the S9 but that UI just doesn’t do it for me…
It’s a pity because I love the aesthetics !
Great job CRX, as always !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Slayer1
Slayer1's picture
Last seen: 21 hours 11 min ago
Awesome mod as always! Thumbs Up Beer
