LG HG2. Fakes?
21 posts / 0 new
Nev
Last seen: 6 hours 1 min ago
LG HG2. Fakes?
I bought these cells from aliexpress,here’s the link ,Look what I found on AliExpress
http://s.aliexpress.com/nyU7Vbqm
The writing is different , the colour is slightly lighter , the flat top is adifferent shape & the internal resistance is 30+mohm (my known genuine cell is 17 mohm) these test out on my skyrc mc3000 at around 2500mah ( my genuine cell test at very close to 3000mah )
Here’s a few side by side photos with my known genuine ,the genuine cell is on the right in all pictures
What do you guys think?
Edited by: Nev on 03/14/2019 - 18:33
RobertB
RobertB's picture
Last seen: 3 days 16 hours ago
They are probably 2500mAh LG HE2 or HE4’s. For a while, most of the fake HG2’s were re-wrapped HE2’s. Which wasn’t all bad since the HE2 and 4’s are a 20A continuous discharge cell.
I’m guessing you IR tester is erratic. 17mΩ is pretty darn low for HG2, and 30 sounds about right for a HE2.
wolfdog1226
wolfdog1226's picture
Last seen: 21 hours 26 min ago
My guess is they are fakes.They certainly look different and if your Skyray is consistent as you would expect, that 2500mAh capacity is a big difference from the genuine cells.
I only used LG HG2’S on Two occasions[2 cells] They were definitely genuine. I was not impressed with them and never bought them again. They degraded at a much faster pace than my 30Q’S and VTC5A.
I know you are in the UK, so it maybe harder to get certain cells. Now I use what is left of my VTC5A and my new go to high drain is the Molicel P26A which has worked superbly the last 6 months with apparently no capacity loss. They have been tested by Two know battery gentlemen to be slightly better than VTC5A.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Nev
Yes they will pull 19.5 amps in an ecig mod but I bought them because I was led to believe they were 3000 mah ,so do you think I am right in demanding a refund?
wolfdog1226
I would certainly think so. If Robert is right about them being replaced with HE2’S/HE4’S,then you are not getting what you ordered.
        WOLFDOG
Nev
I can get genuine cells in the uk but these were £2.50 each compared to £5.50 genuine ,I thought the only drawback from getting these would be the long wait .
wolfdog1226
OK,,I was not clear enough,,,,,,,,,,,,I meant I am not certain about the availability of Molicel P26 in the UK. I am sure you can get genuine cells there as VEN has for years.
The old saying,,,,you get what you pay for! I am blessed with Liionwholesale being less than 1 mile from me and of course other great dealers in the USA,,,Illumn,Orbtronic, ect.
NOT sure if I helped your cause,,,I hope I did not add to your grief.
        WOLFDOG
Nev
Yes I can get molicells here ,I already have one but I use that in my D4 but my ecig eat through cells quickly so I use 3000mah so they would last a bit longer but these fakes only last about 2 hours , maybe I’ll get som flat top 30Q’s ‘ I have loads but all button tops ,the ecig only takes flat tops.
Nev
I’ve just made a dispute about them ,I’ll see what they say , unfortunately I ordered two more a week after I ordered these Facepalm
Oh well you got a learn from ya mistakes , I won’t be making that one again ,only genuine cells from the uk for me from now on, thanks wolf dog & Robert for your help Thumbs Up
wolfdog1226
30Q sounds like a good battery for you mod. Hopefully you can get them at a good price.
I always liked my 30Q.
What amazes me about the molicels is, it provided ~ 15 more amps than 30Q and the run time[at the same voltage] was basically the same. I use them in my TN42vn90. I get 25 minutes of MAX w/ voltage of 3.50V. 30Q was 3.53V at the same 25 Minutes.
From what I have read, vaping is a lot different. Probably harder on the batteries.
        WOLFDOG
RobertB
RobertB's picture
Jon got a bunch of fakes in one time. As soon as he found out he contacted everyone who bought them and took that batch off the shelf. I bought 6 HG2’s from someone else and 3 of the 6 turned out to have matching marks to an HE2 under the wrapper. My ecig device takes 3 18650’s and voltages weren’t matching when it was time to charge, which is how I figured it out.
I got 6 more HG2’s from Jon, a couple years ago. All 6 have been run through 600+ cycles, and they still work great. Retired them from the ecig, but still using 4 of them in a Q8 right now.
Nev
That’s why I got HG2’s because the mod I got was second hand & the HG2 that came with it was 2 years old but tested very well with IR of 17 & it is still very close to 3000 mah
Nev
I can actually get flat top 30Q’s for £1 cheaper than the LG’s.
LG=£5.45 30Q=£4.65. Molicell P26=£6.49.
wolfdog1226
Have a good night gentlemen,,,,NEV,,,,,,,,,,Its after midnight,,,get some sleep!!
I am off to the trail w/ CAPO,,,,Closing in on 19K miles.
        WOLFDOG
Nev
I’ll be up till about 4 or 5 am , have a nice walk give capo a hug from me.
wolfdog1226
Wow,,,you were not kidding! We just got home. It is 2:22am where u r!…….Nice of you to think of Capo.
Why do you stay up so late? Work?
        WOLFDOG
Nev
I’m nocturnal.
I don’t work , I’m a career for my very ill wife.
wolfdog1226
Your a care taker for your wife? I am sorry to hear that she is ill. What is wrong with her?
I am ready to go to bed,,10 pm!
I do private work w/ the elderly. Primarily ones w/ alzheimers and/or mobility issues.
        WOLFDOG
Nev
She had cancer a few years ago with many complications she also has M.E she also has very bad arthritis ,she’s on warfarin because she’s had 2 strokes & D.V.T , she also needs a new knee joint but they can’t operate because the risks outweigh the benefits ,she’s getting by with a leg brace for now & she has bipolar & she’s borderline schitefrenic ,she’s only 49 years old ,she also moans at me a lot ha ha , I bet you wish you never asked now don’t you ? Lol.
I miss walking with my dog very much but we lost him two years ago ,he was only 8 years old , he was my best friend.
wolfdog1226
Nev wrote:
She had cancer a few years ago with many complications she also has M.E she also has very bad arthritis ,she’s on warfarin because she’s had 2 strokes & D.V.T , she also needs a new knee joint but they can’t operate because the risks outweigh the benefits ,she’s getting by with a leg brace for now & she has bipolar & she’s borderline schitefrenic ,she’s only 49 years old ,she also moans at me a lot ha ha , I bet you wish you never asked now don’t you ? Lol. I miss walking with my dog very much but we lost him two years ago ,he was only 8 years old , he was my best friend.
Wow. That is a lot to deal with. Did you think of getting another dog?
        WOLFDOG
Nev
No ,I’ve had three & it’s so heartbreaking when they die ,my first two were 14 & 15 when they died ,the last one was only 8.
