Eizfan IMR18650 3100mAh (Black-cyan) 2018
Official specifications:
Capacity: 3100mAh
Nominal Voltage: 3.70V
Standard Charge: 1550mA, 4.20V, 50mA cut-off
Fast Charge: 4000mA, 4.20V± 0.05V, 100mA cut-off
Max. Charge Voltage: 4.20V
Max. Charge Current : 4000mA
Standard Discharge: 500mA
End voltage (Cut off): 2.5V
Max. Discharge Current: 40A
Weight: Max. 48.0g
Operating Temperature: Charge: 0°C ~ 50°C, Discharge: –20°C ~ 60°C
Storage Temperature: 1 month: –20°C ~ 60°C, 3 months: –20°C ~ 45°C, 1 year: –20 ~ 20°C
This is a 18650 battery with good capacity rated for high current.
The discharge curves tracks nicely, but the battery gets fairly hot at high discharge currents.
Conclusion
The cell has good capacity (slight below 3100mAH) and good high current ability for the capacity, but the current rating is way to optimistic.
Notes and links
The batteries was supplied by Eizfan (Efan) for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
