I have a question that if I can solve, it will fix most of my problems of portability.
I’m a light artist, and often I work where there’s no power outlets so I have to depend on batteries for my sculptures. I’m using a powerbank with DC out but it is limited in capacity so I was trying to go for a 20000mah powerbank.
I was wondering if there is a way to use the usbc port of a powerbank to power my lights, as the port support more voltage (if I have understood correctly)
My classical setup is this:
2 rebel LEDs in serie with a 1A driver, meaning around 6V@1A (6W of power).
is there a way to simply connect it to the usb powerbank?
Yes, but you need a USB-C trigger. A QC power bank and a QC trigger can also be used.
You can fairly easily buy cables that split the USB plug into power connections, or you can cut an existing cable and use the two power wires directly.
QC3 has variable voltage, USB-C and QC2 is usual in fixed steps of 5-9-12 and also 15-20 for C volt.
You can use a led without driver, you just need a resistor in series with the led, a 2ohm (or 2.2ohm) 5W would probably work fine. This is not as efficient as a switch mode driver (A linear drive may give you problems with heat).
It looks like it would work with with QC 12V or PD* 12V/15V/20V in and 1 to 3 leds in series on the output.
*PD is Power Delivery and is the USB-C name for power output.
The red one I showed on the picture will remember selected mode and automatic restore it when power is applied.
I have also seen some triggers where you can solder a link to select output voltage.
I bought the red one but it will take time to reach Europe…but it looks exactly what I need…
anyway I found here in a shop the third one, the one with the display. from your review I can’t understand if it has memory and it basically is the same one as the red just with a display. if you say so, I’ll buy also this one to star testing various solutions.
thanks again HKJ, your knowledge and dedication is very very helpful!!!
USB C may be a little more complicate. why not just use regular usb A port from powerbank? Easy to get at least 10W, but make sure you have some current protection!
the thing is that the driver need 2.5v over the total voltage, so 3v+3v+2.5v = 8.5v. that’s why I thought about usb-c that have a higher voltage, but off course usb3 is good as well…
