Review: Intl-outdoor NCR18650 3100mAh (Blue)
25 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 33 min ago
This battery has been replaced by Intl-outdoor NCR18650 3100mAh (Black)
DSC_0436
Official specifications:
  • Panasonic 18650
  • Capacity: 3100mAh
  • Nominal voltage: 3.6V
  • Full charge: 4.2V
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-info
DSC_0435
The batteries arrived in an envelope without any other protection (intl-outdoor has informed me that they have changed to a better packing, see below).
DSC_0438 DSC_0439
DSC_0437
DSC_0446
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-Capacity
The batteries shows nice discharge curves up to 2 ampere, but 3 and 5 ampere is stopped by the over current protection.
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-CapacityTimeHours
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-Energy
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-PowerLoadTime
On this curve it can be seen that the protection on the two cells activates at different currents.
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-TripCurrent
I uses 3 ampere as the minimum test current, but one of the batteries had a protection that activated at a lower current.
Intl-outdoor%20NCR18650%203100mAh%20(Blue)-Charge
Conclusion
These batteries uses a very good Panasonic cell and as can be seen on the discharge curves the two batteries matches perfectly, but they only works up to 2 ampere, the protection stops the 3 ampere test.
It is a bit difficult to rate these cell, up to two ampere they are good cells, i.e. they will work perfectly in lights with a single XR-E, XP-E or XP-G led, but the batteries are useless in a XM-L light, due to the low protection threshold.
From intl-outdoor I have received this comment:
Limit will be changed in the next batch. Currently working with a different company for a new protected battery.
Notes and links
The batteries was supplied by intl-outdoor for review.
New packing use by intl-outdoor:
IMG_0566a IMG_0569a
IMG_0571a IMG_0572a
Edited by: sb56637 on 08/26/2014 - 17:47
Stephen Wallace
Last seen: 5 years 11 months ago
I honestly don't know how you find the time to do all this testing! But I greatly appreciate that you do. Smile
Hopefully, as with the 16650 cells, I can make time to do some testing on a couple of these that I have received, though I doubt that I'll find much different. Hopefully the next batch will indeed be better.
sb56637
sb56637's picture
Last seen: 7 hours 12 min ago
Excellent technical review HKJ, thanks very much for all your hard work!
Frontpage'd and Sticky'd.
ri chevy
Last seen: 6 months 1 day ago
X2 with the thanks for all you do here and there for all of us!  You confirmed through science what we all knew by finding out through trial and error, that the battery is a good cell with a bad PCB.  Hopefully Hank will make good on replacements or credit toward the cell with newer/better PCB.  I bought these cells for use specifically with XM-L drop ins.  I was sad to find out that they tripped off on high.  I was using the Manafont 3 mode XM-L drop in.  They work OK on medium and lower settings with long run times.
Olli1783
Thanks!
Noctigon Meteor M43
jacktheclipper
jacktheclipper's picture
Last seen: 14 hours 41 min ago
Thanks .
cd520
cd520's picture
Last seen: 6 years 6 months ago
Looks like a pretty good battery once the protection current is raised.
dthrckt
dthrckt's picture
thanks, I think the new protected version will be the next cells I purchase.  intl-outdoor doesn't have a huge selection but he's obviously put some thought into what is offered...
____________________
Girls can shoot!
ri chevy
Any updates?
SashiX
SashiX's picture
Last seen: 5 years 12 months ago
Hm, strange Flat Stare I'm almost sure, that if you remove the protection, it will work @ 3-5A for sure. Why it being tripped at such a "low" current?
ludow
Thanks for review and test.
So this battery is NOT suitable even for one 18650 X-ML flashlight model?
What a shame indeed. Yell
Never trust a smiling dino!
Hikelite
Last seen: 1 day 23 hours ago
I think even if we say it's suitable for XP-G XP-E  and not for XM-L is somehow not acurate. It's not about XM-L or not. It's about the current that passes through MOSFET that is the shut down problem.
It doesn't matter what LED is, it only matters what current is being drawn by the driver. From what I see 2A current is OK.
Look at it like this, use one battery with a flashlight that says max 650 lumen or a mode that has 650 lumen.
ludow
Excellent. Thanks Hikelite, well explained.
yavi
Last seen: 4 years 12 months ago
Very good explanation, I also ordered this one and I am having the same problem with them, mines cut off at about 2.5A, I am using them with XR-E and 2*18650 flashlights.
I hope they will update the product with new protection boards able to reach at least 5A out of the 6A given by Panasonic data sheet.
Before I ordered them, I asked about it to Intl-outdoor, and they told me the protection was made to kick at 6A, it made me so happy to have a great battery with the best runtime and also a high drain, but unfortunately it was not true.
HKJ
HKJ's picture
That is correct and because a XP-G is about 1.5 ampere it works fine with a single XP-G led. A XM-L needs about 2.8 ampere to be driven at full power, it is just at the limit and if the light has a boost driver it will be above the limit.
On my website there are curves that shows the exact current draw for some flashlights at different voltage (Just measuring the tail cap current with a fresh battery does not tell the full story about current draw), this gives a much more detailed picture than just saying XP-G and XP-E leds.
Stephen Wallace
In a different thread about these cells, Hank from intl-outdoor stated that when the protected cells were ordered form the person/s who assemble the protection circuit and cell, he requested that PCBs with a high dicharge current value were used. It seems that during the actual assembly, his specification was ignored and PCBs with a lower discharge value were used instead.
As such, when you contacted him, it is entirely possible that he did believe these cells were capable of a 6A discharge rate, as that is what his specification called for. It appears that it was only after people started purchasing these and testing them that is became apparent that the wrong PCBs had been used.
weiser
Last seen: 7 years 1 week ago
So we're to assume they don't have the updated cells yet? I'm not sure if he hasn't updated his website or if they're just not in yet.
HKJ
HKJ's picture
If you look at the intl-outdoor website, only unprotected batteries are sold. The checkbox for ordering protected batteries are missing.
yavi
Yes, I understand they were told by the supplier they were made to give 6A, and they realized about it later on.
I did not ask for a refund or anything else, but it is true I asked about it before purchasing them and they were not as described.
If they get a new model with a better protection board I will probably get them for one reason, they are much cheaper than their competitors using the same Panasonic battery ( Kallies and Redilast) at lest shipped to Spain.
ri chevy
For these reasons stated herein, is why something should be done by Hank and Intl-outdoors.  Either send us the cells that we thought we were getting as a direct replacement, or give us a very discounted rate on the "new" cells when they are done.  I thought I was buying a premium cell, and did not get what I thought I was getting.  It needs to be corrected for all who purchased them.  I realize that it may not be Hank's fault, but it surely is not our fault!
ludow
[/quote]
[/quote]
[/quote]
Sounds reasonable for me. Hank can get his money back from "dealer".
benckie
benckie's picture
Last seen: 6 years 12 months ago
With out the protection I've tested them to 6.2 amps no problem, that's the maxium Panisonic recommend.
I believe the protection trips early due to there only being one cheap MOSFET in the protection circuit, even the cheap trustfire flames I've tested have 2 and other high end batteries I have have 3.
HKJ has done some Awsome work here.
ri chevy
A little off-topic here, but how does one make a safe battery after removing the protection circuit?  Can someone with more knowledge show us please?
2100
It IS a safe cell in the first place.   The wires used were 12AWG, way thicker and lower resistance than even hardcore mods in any light (save for the 60" carbon arcs) or any driver dead short instances.
ri chevy
I thank you for that.  I was looking more at trying to remove the "weak" protection circuit from these batteries to make them more useful,  I am just not sure on how to go about it safely.
