[Reference] Nichia E17A/E21A (2000K - 6500K, R9050/R9080, color) CCT and tint shots
147 posts / 0 new
maukka
maukka's picture
Last seen: 9 hours 5 min ago
Ryzbor wrote:
4000K+4500K as a neutral tinted (?) 4250K
Not much reason to mix such close color temperatures. The difference between 4000K and 4000+4500K will be practically indistinguishable.
maukka
maukka's picture
Tested the difference. CIEDE2000 color difference is 1.44 which means there’s no practical difference. DeltaE >3 starts to be obvious.
clemence
clemence's picture
Last seen: 4 hours 59 min ago
Woohoo, finally Maukka chime in. I’m still on the road to Malang city when I get the notification to this thread. Drove 400km and still 60km to go… Man…LPS everywhere in Java island
http://imgur.com/gallery/wu0LGr0
[Clemence]
maukka
maukka's picture
Aren’t they just glorious (sorry, chart doesn’t reach warm enough to show 2000K, 2200K, 2000+3000K).
maukka
maukka's picture
CRI data for all the emitters and some tint mixes. All except one mistake at 700mA per emitter.
2000K
2200K
2700K
3000K
3500K
4000K
4500K
5000K
5700K
6500K
2000+3000K
3000+4000K
3000+4500K
3500+4500K
4000+4500K (350mA per emitter, oops)
4000+5000K
4000+5700K
2000+6500K
Tally-ho
Tally-ho's picture
Last seen: 1 week 3 days ago
Thanks a lot maukka and clemence.
ToyKeeper
ToyKeeper's picture
Last seen: 54 sec ago
This is really cool, and I should definitely try some E21A emitters.
Any idea how a 2700K+6500K or 3000K+6500K combo would look? Ideally I’d hope to hit near 4200K with duv -0.008 or so.
Edit: On second thought, perhaps I should just go for the 4500K emitters by themselves. They seem just about right, aside from being a bit less rosy than desired. With the flat surface, it’d probably have a fantastic beam.
maukka
maukka's picture
Here’s data in a big table:
https://docs.google.com/spreadsheets/d/1CERSuF2JvYtjsoyPh-wEZ0dG6fSI-FDC...
I haven’t measured lumens yet, so the Y column is just relative brightness.
maukka
maukka's picture
Open the chart in a photo editing program and draw a line between the emitters you’d like to mix and eyeball the xy coordinates at the middle point. Enter them to a calculator such as this one: https://www.waveformlighting.com/tech/calculate-duv-from-cie-1931-xy-coo...
edit: as it happens, in my image the duv (with a bit of a multiplier) is pretty much the 1:1 pixel distance from the BBL, so that helps too
AEDe
AEDe's picture
Last seen: 5 hours 22 min ago
maukka, could you hold total current fixed but change current of components that mixing?
It is interesting would it be trajectory of such kind or not.
maukka
maukka's picture
Here’s the spectra and CIE plot for the E17A color LEDs
SRGB color space for reference
Only the CRI for the amber LED is of interest
clemence
clemence's picture
Amber looks like a low CRI extremely warm LED. Mixing red and amber can produce something interesting…I request a test for this Maukka.
Red on the other hand is very close to Cree’s new 660nm XPE2 photo red except it has very wide spectrum coverage. A very good candidate for night vision friendly torch.
[Clemence]
SKV89
Last seen: 11 min 47 sec ago
Thanks Maukka for providing those extremely useful test data for us. I have a few questions.
1) Why does tint mixing drop R9 so much on the 2000k+ 6500k
2) Could the low R values for 2200k be a fluke?
3) If I remember correctly the batch of E21A you tested last year was much rosier. Is that correct? This batch seems to hug the BBL similar to the Optisolis.
Also a request if it doesnt require too much effort is if you can test 2000k+2700k, 2000k+4000k, and 2000k+4500k. Of it require much effort to setup the test then nevermind.
Thanks again for your hard work and contribution.
clemence
clemence's picture
Let me try to answer those.
2000K has quantitatively more red than 6500K. 6500K measured with D65 standard while 2000K with incandescent baseline. Combined, the resultant R9 will result in less R9.
Early test done at 100mA current. Some LED produces less CRI at low current, and more R9. Different behaviour for different phosphor chemistries.
2000K and 2200K rated at R9050 not R9080.
[Clemence]
goshdogit
goshdogit's picture
Last seen: 1 hour 5 min ago
These two scenes are amazingly similar!
What’s that game called, Clemence?
clemence
clemence's picture
AFAIK it starts with something “…find hidden objects…”
goshdogit
goshdogit's picture
Thanks, Clemence! Thumbs Up I hadn’t seen this ‘hidden object’ game genre before.
It seems your image is a screenshot from a game called ‘Criminal Case.’
maukka
maukka's picture
Amber+Red
maukka
maukka's picture
RGBA. Bad Rf, huge Rg. Very magenta.
iamlucky13
Last seen: 6 hours 3 min ago
Thanks for making that measurement. I suspected it would end up being unbalanced. Trying to build anything around this mix would result in a freakshow light if current to each channel can’t be managed separately. One the other hand, being able to adjust each channel individually would be what would make an RGBA light fun.
It seems like blue would need to be dialed back quite a bit, and perhaps the amber increased a little in order to get a more natural result.
maukka
maukka's picture
Sure, by individually addressing the emitters, you can tune it to anywhere within the color space quadrangle they cover.
It’s trippy.
clemence
clemence's picture
To save you time:
http://www.nichia.co.jp/specification/products/led/ApplicationNote_SE-AP...
[Clemence]
clemence
clemence's picture
Normally, the middle rank is the safest for good output at or below BBL tint. The higher the output the farther up from BBL the tint.
[Clemence]
clemence
clemence's picture
maukka
maukka's picture
Added lumens and efficacy numbers to the Google Sheet.
Individual Current-Flux-Voltage curves
2000K
2200K
2700K
3000K
3500K
4000K
4500K
5000K
5700K
6500K
Tint in an integrating sphere without any optics, i.e. how these measure diffused and how the binning is done (much closer to advertised CCT values)
Individual CRI data
2000K
2200K
2700K
3000K
3500K
4000K
4500K
5000K
5700K
6500K
2000K+6500K
clemence
clemence's picture
GREAT job Maukka Thumbs Up Beer . These integrated measurements is extremely close to OEM rated, a good example of what to expect from 3 steps binned Nichias. Many thanks for all your efforts.
FYI, this also closer match to my tint shots in the OP (no optics, matte white reflector)
[Clemence]
Ryzbor
Ryzbor's picture
Last seen: 4 hours 5 min ago
Great job as usual Maukka, thank’s for measuring the requested mixes Thumbs Up
The thought behind this is to get the tint of a d240 4000K Wizard Pro below the bbl on the medium modes since the current setup is above it even on M3 ~250lm as bob_mcbob measured. And I see 4000K+4500K is slightly below the BBL at around 450lm.
Speaking of, Maukka could you add info about which flux binning you used in cases more than one is available? Eg. your previous the 4000K you measured abut a year or more ago had the d220 bin but now you’ve measured the d240 bin.
I find the results a bit optimistic besides the 5000K (which bin?). At 700mA/led, thus around 990lm it’s pretty obvious the tint is going to be below BBL and the E21A is well known for that. Even the XHP50 WW in the Wizard is below BBL on turbo. 990lm is more a turbo mode than a regular used and sustainable mode in a typical host. What really matters is how every setup performs a medium mode and a low mode which are going te be used by fat the most in real world usage. IMO it would be more interesting to know how they perform at lets say 200lm or even less. That’s where the “big table” helps.
clemence wrote:
Normally, the middle rank is the safest for good output at or below BBL tint. The higher the output the farther up from BBL the tint. [Clemence]
I couldn’t agree more…
But I’m actually open for a positive duv setup for special tasks. For walking in the woods I actually prefer positive duv above a pink tint, maybe because trees aren’t pink and leaves look less green under a pink tint Big Smile
Or maybe a 4500K (rosy)+5000K(greenish) mix to create a true neutral 4750K…
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
maukka
maukka's picture
Clemence probably knows the flux bins. I just got the bare leds on mcpcbs.
clemence
clemence's picture
New E21A flux bins measured by Maukka can be checked via my store. Sm503 = D240, sm403 = D240.
No LED can satisfy your needs for consistent tint. You asks for below BBL from the very low current yet stays there at very high current. This is almost impossible with such wide operating current, not with current technology. That’s why PWM control is highly desired in CCT and tint critical lighting.
If you want to get the most consistent tint and CCT, go with Optisolis. Or any mid power LED. There’s no magic here, with such low current range you wont get tint/CCT swings as those in high power LED.
[Clemence]
clemence
clemence's picture
FYI, we tested all those LEDs at 700ma because that’s the current used for all E21A binning standard (Nichia)
[Clemence]
