[Reference] Nichia E17A/E21A (2000K - 6500K, R9050/R9080, color) CCT and tint shots
147 posts / 0 new
SKV89
Last seen: 5 hours 34 min ago
I’m quite surprised the E17A is not that far behind the E21A in terms of efficiency. If Clemence will ever make a 13mm board, I will buy a bunch. There’s so many AA/AAA/16340 lights I can think of that can use the 4xE17A
Aprilis
Aprilis's picture
Last seen: 1 sec ago
That depends on the current. On lower modes they are indeed very close(about 5% difference), except the fact that E17A has noticeably higher forward voltage, however on higher modes e.g ~700 lm E21A achieves 108 lm per watt while E17A only 93lm per watt and that’s already 16% which is not that small, at least for me, plus again higher forward voltage. Anyway, I’ll wait for the tests before drawing any conclusions.
clemence
clemence's picture
Last seen: 21 min 46 sec ago
UPDATE 191107: Color E17A beamshots added to the OP
[Clemence]
Pavlo
Last seen: 48 min 46 sec ago
To the E21A and E17A fans, I need your opinion.
I will be modding 3 identical hosts with quad e17a virence board, and I can’t decide on which CCT’s to pick.
The max output with these hosts will be about 260 lumens using the e17a 9080 LEDs, with both floody and throwy optics.
I typically enjoy lights from 3000K to 5000K, but have never tried 2700K, and sometimes find 5000K too cool.
Any recommendations?
Option 1: 2700K, 3500K, 4500K
Option 2: 3000K, 4000K, 5000K
Option 3: 2700K, 4000K, 5000K
What are your favourite CCT’s with these leds?
clemence
clemence's picture
2000K
4000K
5700K
maukka
maukka's picture
Last seen: 1 day 1 hour ago
Clemence sent me some E17As for testing, like all of them.
Go here for CRI results: https://imgur.com/a/IuzKvvn
virencelights
virencelights's picture
Last seen: 18 hours 5 min ago
thank you.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k, Virence Jetbeam AAA Nichia HCRI Red Led.
clemence
clemence's picture
Thanks Mauri, looks like the results follow E21A closely.
[Clemence]
iamlucky13
Last seen: 9 hours 50 min ago
Thanks for testing these!
It looks like somehow the 2000K was received in R9080 rank even though Clemence listed them on his site as R9050.
Pavlo
Thanks for the tests and happy to see they are as good as e21a!
SKV89
Maukka, thanks for the test! What kind of reflector or optic did you test them under?
maukka
maukka's picture
Added a CIE chart for quick tint checking.
Additional observation: mixing 2700K+4000K in different ratios would result in the 3000K or 3500K emitters almost exactly. Same goes for 4000K + 6500K which results in the tint for 4500K and 5700K.
maukka
maukka's picture
Test was done integrated.
maukka
maukka's picture
Output and Vf graph on the 6500K sample.
Pavlo
Anybody know what the approximate gain in luminous intensity/Throw is of the e17a compared to E21a under the same optic/reflector?
djozz
djozz's picture
Last seen: 7 min 31 sec ago
It looks a bit like a dedomed XP-E2 (low CRI) both in output and die size, but just a bit less, pretty good for a 95 CRI led.
Pavlo
So a quad e17a is about the size of an XP-G LED, and quad E21a is about the size of an XM-L LED.
Would you say the quad e17a will have about 40% more throw than the e21a at the same power setting?
maukka
maukka's picture
Tint vs. current on the same 6500K version. Fast sweep with only 3 seconds spent on each step.
CRI data at a couple currents
100mA
500mA
1000mA
clemence
clemence's picture
LOL Hahahaha, thanks Maukka. Your post makes me giggles. The color swings for 3 steps R9080 is the tightest.
[Clemence]
nsl18
Last seen: 8 hours 39 min ago
I tested only 2000k and e17 has a very low lm/w. And, generally. you get same picture in narrow optic (a smalled spot and seeming increase of range). A only advantage of e17 series is a rosy tint at a lower current than e21
Aprilis
Aprilis's picture
Thanks for the information. Could you tell me what optics have you used?
nsl18
XP 20 mm x 5 degree with custom matted #320 sand and slightly cleared dichloroethane. Bottom of lens is cutted off to 0.3 mm (http://budgetlightforum.com/comment/1094565#comment-1094565 http://budgetlightforum.com/comment/1305887#comment-1305887). And i will be compared parallel 2000+3000k with 10×30 elliptical lens. I have it in e21 and, for me, throw is low as outdoor light. All optics is yajiamei
Aprilis
Aprilis's picture
So if I am understanding you right your are using a lens like this(https://www.aliexpress.com/item/1323039915.html?spm=a2g0v.12010612.81483...)? Is it a multiemitter setup(VR16SP4) or single emitter setup?
nsl18
Yes this lens. Maximum 2xe21 on vr16s1 (hole dia 4.8 mm). Very carefully when installing the lens, damage to the phosphor is possible
nsl18
An quad system (vr16sp4) i do not use because i got problems with focusing and final output. My working hl have 2× 5000k with https://www.aliexpress.com/item/1281151114.html
JaredM
JaredM's picture
Last seen: 9 hours 16 min ago
Clemence,
Have you played with using the Green/Lime E17A in a tint mixing array in order to better track the BBL?
