TC66C-a powerful Type-C USB tester
183 posts / 0 new
Youngcrazy
Youngcrazy's picture
Last seen: 4 months 3 days ago
   Nowadays, Type-C interface is wildly used for its superior performance; It’s much better than others in terms of interface volume, charging power, transmission speed and ease of use.
   Recently I got a new Type-C USB tester (TC66C) from RD technology, they produce many kind of USB testers like UM24/Um25/UM34/TC64, they perform well but can be better. So, today I want to introduce it to you because I think it will be a useful tool for many enthusiasts and laboratory workers.
   OK let’s have look at TC66C, it is compact designed and easy to carry. We can test our device anywhere because it doesn’t take too much space.
   There are two versions: TC66 and TC66C, the only difference between them is that TC66C can communicate with mobile phone by Bluetooth connection while TC66 cannot.
Then we can see details of TC66C, just as shown below, TC66C has 8 interfaces and each interface has its function. Compared with other USB testers, it is more powerful. I will introduce some useful functions and you can know more about TC66C.
I list these functions and I will introduce them in detail.
-6digit voltage and current, resolution is 0.0001V(0.1mV)/ 0.00001A(0.01mA)
-Quick charge protocol detection,
-PD and other trigger operation,
-USB communication for PC software,
-Bluetooth communication for IOS app and android APP,
-Firmware upgrade,
-Two-way measurement,
-Independently power supply
-Offline storage
  1. Voltage/Currentaccuracy comparison
we can see that Voltage and Current are displayed in six digits, which means the Voltage measurement resolution is improved to 0.0001V (0.1mV), and Current measurement resolution is improved to 0.00001A (0.01mA). I think it will be suitable for enthusiasts or mad scientists :D.
2.quick charge protocol detection
We know that many electronic products has quick charge mode: Samsung AFC quick charge, Huawei FCP/SCP quick charge, PD quick charge etc. These quick charge modes can be detected by TC66C;  Several different chargers are tested as shown below. We can see two colors on the screen, green options indicate supported protocols, red options indicate unsupported protocols.
3.PD Trigger
TC66C can test the maximum power of PD charger, so that we can know the quality of our charger.
4.Two-way measurement
TC66C allows current flow passing in two directions so we won’t be afraid that the tester might be burned if we insert the wrong interface.
5.USB communicationfor PC software
C66C supports PC software communication, after being connected to PC by Micro-USB cable, we can view data on PC software, it can record curve when mobile phone is charging. (PC system must be Win7 or above, TC66 and TC66C can use the micro USB to connect computer)
6.Bluetooth communication for mobile phone
We can also use mobile phone to view data or operate. TC66C can be connected to APP by Bluetooth. That is so convenient for me. (Android system must be Android 5.0 or above, iPhone must be IOS 8.0 or above)
7.Offline storage
   Sometimes we will be busy and we do not have time to record data, we can use offline storage function; data information will be recorded on TC66C and be exported to PC software when connected to PC.
  1. Firmware upgrade
When there is a new firmware, the tester will remind you to upgrade the firmware. So we can use new functions.
9.Independently power supply
TC66C can be Independently charged so that it won’t consume the voltage and current of the device under test.
In short, I am satisfied with TC66C, thanks for reading.
Products link:
https://www.aliexpress.com/item/RD-TC66-TC66C-Type-C-PD-trigger-USB-Voltmeter-ammeter-voltage-2-way-current-meter-multimeter/32968303350.html
Edited by: Youngcrazy on 03/28/2019 - 05:15
Youngcrazy
Big Smile
ohbreeeezy
ohbreeeezy's picture
Looks good!
Youngcrazy
It’s useful and powerful, you can see detailed introduction by click Products link(very very long LOL )
maukka
maukka's picture
Last seen: 18 hours 36 min ago
Seems like good functionality for $21. Thanks for the test!
Does the PC software allow for logging and exporting as CSV/TXT file?
Why does the display and software report different voltages here, or is it just not connected:
Youngcrazy
!http://ae01.alicdn.com/kf/HTB18OMlOmzqK1RjSZFHq6z3CpXaV.jpg!
I didn’t click “conncet” button so it is not connected at that moment, pc software can export data to an Excel file Crown .
maukka
maukka's picture
Great! Gonna get one.
I especially like that it supports power going both ways. First I was worried that it’s not possible to measure a USB-C PD power source with a fixed cable, but you can just stick that into the “output”/female port and the “input”/male port to the device being charged.
BlueSwordM
BlueSwordM's picture
Last seen: 9 hours 35 min ago
Same thing.
Will be ordering one.
Pete7874
Pete7874's picture
Last seen: 4 hours 43 min ago
Nice tester.
Since it can trigger PD, does it mean you could then connect HD35 to it and simulate a PD load?
BlueSwordM
Oh that would be amazing.
Seems like it is capable to do so.
Pete7874
Pete7874's picture
Is the only difference between TC66 and TC66C the bluetooth board? Can you still use the TC66 to connect to a PC and log data and perform firmware upgrades?
Youngcrazy
Yes,TC66 can be connected to PC in the same way, TC66/TC66C use the same PC software, but we cannot use APP to control TC66 or view data. Smile
Youngcrazy
Pete7874 wrote:
Nice tester.
yes,when connected to HD35, HD35 will be used as PD load, and you can choose PD mode at TC66C
Youngcrazy
almost forget that For this manufacturer, there is a big sale promotion for first publish from 28st-31st,
TC66 16.5USD/piece, TC66C 21 USD/piece only 4 days, after 31st, the normal price TC66 19.5USD/piece, TC66C 24.5 USD/piece.
And there is biggest sale promotion 328 on his shop, 17% off 40% off, most DPS power supply discount are more than 25% off, for A3 and A4 buyer, there are some products more off 5%. There is also big coupons more 65 off 6 usd, 130- off 12 usd, 195- off 18 usd ……
This is home page:https://rdtech.aliexpress.com/store/923042?spm=a2g0s.12269583.0.0.58a052... Facepalm
Youngcrazy
this is introduction vedio of TC66C
Youngcrazy
nobody wants to talk about it Question
bmengineer
bmengineer's picture
Last seen: 3 hours 50 min ago
Youngcrazy wrote:
almost forget that For this manufacturer, there is a big sale promotion for first publish from 28st-31st, TC66 16.5USD/piece, TC66C 21 USD/piece only 4 days, after 31st, the normal price TC66 19.5USD/piece, TC66C 24.5 USD/piece. And there is biggest sale promotion 328 on his shop, 17% off 40% off, most DPS power supply discount are more than 25% off, for A3 and A4 buyer, there are some products more off 5%. There is also big coupons more 65 off 6 usd, 130- off 12 usd, 195- off 18 usd …… This is home page:https://rdtech.aliexpress.com/store/923042?spm=a2g0s.12269583.0.0.58a052... Facepalm
I’m in the market for one of those adjustable DC power supplies with a case. Any deals for those?
Find all my reviews of flashlights and more gear at www.bmengineer.com
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 13 min ago
Stupid question: How can I use this nice device with USB-A ports (both in and out)? Can I use adapters (USB-A to USB-C, microUSB to USB-C) or is it not recommended to use adapters? Will adapters have any influence on the results measured by this device? Thanks for your feedback!
Pete7874
Pete7874's picture
Good question. I’d like to know the answer, too.
Using any kind of cables/adapters can certainly increase resistance and impact readings. If you want to avoid having to use those, for USB-A, look at the UM25C:
https://www.aliexpress.com/item/RD-UM25-UM25C-for-APP-USB-2-0-Type-C-LCD-Voltmeter-ammeter-voltage-current-meter/32855845265.html?spm=a2g0s.9042311.0.0.44884c4dQIo7kh
Lux-Perpetua
Ah okay, thank you Pete7874! Thumbs Up
Actually, I already have the UM24 that I like very much. Smile
Youngcrazy
RD Technology also sell adjustable DC power supplies but you need buy case in their store and build up by yourself, It is 328 festival so you can buy that at a inexpensive price,just have a look at RD technology or other stores, buy the one fits you. Cool
Youngcrazy
you can use adapters but it will influence the accuracy of the result because of its resistance, the Micro-USB port of TC66C is used for independently charging, so this device is designed for Type-c port. hope it helps you Grad
Pete7874
Pete7874's picture
Where is the PC software?
The instructions refer you to this location:
http://www.mediafire.com/folder/pqn0ybytqpy7n/TC66
But when you go to this location, there is only an .apk file there which is not a Windows executable.
BlueSwordM
Same thing here.
I’ve also bought the TC66C.
I’m looking forward to testing it.
BlueSwordM
Ah ok, thank you.
So, do you work at RDTech?
Are there any products being made/in the product pipeline?
Youngcrazy
BlueSwordM wrote:
Ah ok, thank you.
they give me a product , then I test it and write an article so that I can get this beta TC66C for free, LOL you can just have a look at their eshop,they have their own factory.
Youngcrazy
they said they will upload PC software in two days,you can use it when you get your item. I use beta version Facepalm
Pete7874
Pete7874's picture
What is the “CC drop down” they talk about in the description?
Youngcrazy
“For CC drop-down:PD stipulate that type-c interface has no output by default. When there is a drop down on the CC line (pin in the Type-c interface), PD charger thinks that the load is connected and then starts the 5V output. Therefore, it is normal for the tester to plug directly into the PD charger and not light. if CC drop down is enabled in the setting of TC66, when you plug TC66, it will automatically brighten the screen after it is set as enabled, but it may affect the normal charging process. If protocol detection and trigger are to be carried out, CC drop down must be enabled, and the back end shall not be connected with any load. If it is set to be off, the charging of PD charger will not brighten the screen, and the charging process will not be affected. Please first plug the tester into the charger and then insert the load.”
this is written in their Introduction Big Smile
Pete7874
Pete7874's picture
Sounds very confusing. So what if you want to trigger a specific protocol and apply load using that specific protocol, for example PD 20 volt?
Youngcrazy
at first,we should make sure that charger support that protocol, then you set the protocol you need,when finished setting,connect it to your load
