TC66C-a powerful Type-C USB tester
183 posts / 0 new
RD tech
RD tech's picture
Last seen: 7 hours 48 min ago
unmesh59 wrote:
The PC software wants me to update the firmware but won’t update successfully
Dialog box
now don’t update , we did not add updated things , now please uninstall the software and install it again to check the function and operation
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
RD tech
RD tech's picture
Dialog box
Hi friend
don’t update it now, because we did not add the update things .
now please uninstall the software and install it again to check normal function and operation
unmesh59
Last seen: 11 months 3 hours ago
I uninstalled/reinstalled and everything seems to be working though it did pop up dialog boxes to install new software and new firmware.
Are you planning to implement something like the K2 long press function so I can operate the TC66C from the PC without touching the device?
unmesh59
RD tech wrote:
unmesh59 wrote:
On my Lenovo laptop with a USB-C PD charger, the Quick Charge Detection screen shows the correct 20V and 2A operation but QC2.0 as the Quick Charge protocol instead of USB-C PD. Why?
In fact, running Protocol Detection against the charger correctly shows it is USB-C PD only.
for this problem, in our user manual, there is note: D+ and D- value are just reference, not very accuracy. The product will automatically identify a device with a supported fast charging mode. At this time the device supports the QC2.0、QC3.0、APPLE 2.4A/2.1A/ 1A/0.5A、Android DCP、SAMSUNG.(Note: This quick charge agreement recognition model is not complete and for reference only, we will add other protocol in the future)
It might be better if you leave that part of the screen blank or ???? if you don’t recognize the quick charge protocol instead of an incorrect one.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 17 hours ago
Which charger do you have?
If I remember well, some USB-PD devices actually use QC 2.0/QC 2.0 Type B charging to achieve higher power levels using Qualcomm ICs.
It may be that your charger actually uses USB-PD over QC 2.0/3.0 Type B, which can reach 20V at 5A.
RD tech
RD tech's picture
our protocol is identified by D+ and D- data, This quick charge agreement recognition model is not complete and for reference only, we will add other protocol in the future)
unmesh59
Lenovo 00HM633 that was bundled with the Lenovo Yoga 720 laptop
Here is the output of the protocol detect function (I have been unsuccessful at embedding the image in my post)
Screen capture
BlueSwordM
Seems like it’s actually working though, as it is showing USB-PD being active.
RD tech
RD tech's picture
Screen capture
detection is right , it is detection by CC wire, but fast charge identity is by D+and D- value
unmesh59
Right.
I was thrown off by the Lenovo specification saying PD, the TC66C detecting that it was a PD charger but then saying QC2.0 when actually charging.
RD tech
RD tech's picture
detection is right , it is detection by CC wire, but fast charge identity is by D+and D- value.
unmesh59
RT tech,
You have got me started on reading up on the use of D+ and D- values for various protocols, many of which are proprietary. One article with a very good explanation of QC 2.0 and QC 3.0 is Article
Do you expect to be able to implement detection of a protocol running on the CC wire in the future?
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 1 year 1 month ago
Today my TC66C arrived. Damn is it small if you see it side by side to a UM 25C. I like it!
But I hope they make a change in the Sotware. The UM 25C turns on the second you put in a device (so i can let it connected to the charger and see the current when i connect a device).
But not so the TC66. I have to manualy turn it on to see the values.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
RD tech
RD tech's picture
!{width:60%}https://i.postimg.cc/htHTqLhG/20190417-092501.jpg!
thank you for your support
UM25C is bigger than TC66C, for the welcome interface, I will consider
TheOnlyDocc
Thanks RD tech! At the moment i use the TC66C mainly to check the current draw of my QI wireless charger. It helps to find the best position on the charger.
But like i said it would help if it would automaticly turn on.
And can we logg the data when using the PC software?
RD tech
RD tech's picture
!{width:50%}https://i.postimg.cc/bvTs6WD1/20190417-111203.jpg!
thank you ,I am so happy that you like it like i said it would help if it would automaticly turn on.—— I don’t understand
yes, you use the PC software to log the data
TheOnlyDocc
If i put the UM 25C in the charger and do not use it for a few hours it will turn off. When i then connect a phone, tablet. . . it turns on automaticly and i can see voltage current. . .
If i put the TC66c in the charger and do not use is for a few hours it will turn off. When i then connect a phone,Tablet. . . it will not turn on automaticly. I have to turn it on by hand to see the voltage, current. . .
RD tech
RD tech's picture
HI friend
please check the screen off time, we have screen off time function, you set 0 minutes, it will be lighting
For auto screen off time setting press ‘PREV’ to repeatedly step though the 10 options from 0 to 9 minutes. Default time is 1 minutes.
TheOnlyDocc
Sorry thats not what i mean. If i have time tomorrow i will make a video to show the difference.
But it is only a convenience thing not a real problem.
RD tech
RD tech's picture
very good, friend
I am waiting
Youngcrazy
Youngcrazy's picture
Last seen: 6 months 1 week ago
have you solved your questions?
TheOnlyDocc
I do not know what happend. I was putting everything together to take the Video and the TC66 turned on automaticly like the UM25.
I used the same cables and devices. And i tried it a few times (so it is not a coincidence).
It is a bit strange that it did not work this way the first few times but is working now.
Youngcrazy
TheOnlyDocc wrote:
I do not know what happend. I was putting everything together to take the Viedeo and the TC66 turned on automaticly like the UM25.
so it works normel now? you can ask RD tech if you still doubt there is any problem
dodge_911
dodge_911's picture
TheOnlyDocc wrote:
I do not know what happend. I was putting everything together to take the Video and the TC66 turned on automaticly like the UM25. I used the same cables and devices. And i tried it a few times (so it is not a coincidence). It is a bit strange that it did not work this way the first few times but is working now.
I noticed the same thing.
Got mine yesterday, and when inserting it into a ZMI USB PD charger, it didn't turn on.
I thought it could trigger PD, so was a little flabbergasted. I connected my Passmark tester and it turned on.
But later, when I played around a little more, it turns on a few seconds after being inserted into the charger.
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
Pete7874
Pete7874's picture
Last seen: 9 hours 7 min ago
dodge_911, are you close to releasing your review on this USB tester?
dodge_911
dodge_911's picture
Not even close Smile I just got it and just filmed the unboxing, need to mess around some more with it before I can start recording the video.
Maybe this weekend, but even then, if I finish it, it ends up in the pipeline, so it'll be at least 2, maybe 3 weeks before it gets released.
:: YouTube ::
:: Discord ::
Youngcrazy
Maybe this weekend, but even then, if I finish it, it ends up in the pipeline, so it’ll be at least 2, maybe 3 weeks before it gets released.
waiting for you Big Smile
RD tech
RD tech's picture
what’s wrong , friend ? you can make a video to show the problem
unmesh59
While I wait for the enhanced firmware that can do things like enumerate USB-PD Power Data Objects, my Windows 10 laptop complains that update.exe in the application software installation has an embedded Trojan.
Did anyone else have that happen?
Thanks.
Youngcrazy
Thanks.
it is made by RD themselves, and windows system will treat it as embedded Trojan, but actually it doesn’t matter, just do it √
