Test/review of VariCore 32700 LiFePO4 6500mAh (Gray)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 15 hours 12 min ago
DSC_5342
Official specifications:
  • Model: 32700
  • Voltage: 3.2V
  • Nature: LiFePO4
  • Capacity: 6500mAh
  • Discharge current: 35A
  • Maximum current: 55A
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-info
Large LiFePO4 batteries with good capacity and high current rating.
DSC_5341
DSC_5343 DSC_5344
DSC_5345
DSC_5346
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Capacity
The two cells tracks fairly well and has no problem delivering 30A with nearly same capacity as at low current. As usual LiFePO4 has a very flat discharge curve.
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Temp-20.0
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Temp-30.0
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-CapacityTimeHours
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Energy
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-PowerLoadTime
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-TripCurrent
VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Charge
Conclusion
This looks like good batteries, they can deliver a lot of current and has fairly constant output voltage.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
led4power
led4power's picture
Last seen: 1 hour 36 min ago
140Wh/kg and 200$/kWh, looks like a nice cell for DIY battery pack builds.
