[Review] Sofirn SP31 V2.0 - dual-switch XP-L HI tube light
12 posts / 0 new
gchart
gchart's picture
Last seen: 6 hours 4 min ago
Sofirn SP31 V2.0
I was kindly offered this light for review by Sofirn. I have made my best attempt at keeping all remarks honest, fair, and impartial. I thought this must be a brand-new Sofirn, but for some reason I see a handful of posts about from several months ago. Not sure how I missed this one until now Facepalm
In the Box: the SP31 arrived in a nice sturdy retail box a 3000 mAh Sofirn-branded battery, a basic charger, and a micro USB cable.
Overview: the SP31 V2.0 is a throwy-ish tube-style light. It has both a forward-clicky tail switch and a side e-switch with embedded battery indicator light. The tail switch has on-off duties while the e-switch iterates through the 5 modes.
What I Like:
  • As usual for Sofirn, it has nice quality: lubed square-cut threads, good anodizing, and a solid feel to it
  • Decent CCT: also typical of Sofirn, it’s just on the cool solid of neutral
  • XP-L HI with a smooth reflector helps give the SP31 V2.0 a reasonable amount of throw for it’s size and plenty of lumens
  • While I haven’t disassembled it (yet), I’m guessing it has a buck driver. The runtime graph seems too flat for it to be using a FET or linear driver.
  • Good compact size
What Could be Improved:
  • Honestly, it’s difficult to complain about anything here, but if I had to pick something… I might recommend temperature regulation vs a timed step down.
  • The mode spacing could also be improved a little. I feel like the first 4 modes could all be reduced a bit.
Throw: (being an XP-L HI, I felt like this needed a lux comparison)
Flashlight Measure Lumens Measured Lux Meters
Sofirn SP32 V2.0 1162 lm 8,050 cd 179m
Sofirn SP31 V2.0 1163 lm 17,900 cd 268m
Nitecore P12GT 1077 lm 20,150 cd 284m
Lumens and Runtime:
Mode Eco Low Mid High Turbo
Measured Lumens 3 58 178 575 1163
Spec Lumens 5 50 160 500 1200
Spec Runtime 291 hr 26 hr 49 m 9 hr 45 m 3 hr 41 m 2 hr 37 m
Runtime Measurements:
The runtime graph is nice and flat. There’s a hard step-down at 3 minutes. I took a few temperatures readings (still room, no wind or other cooling) and it never got above 51°C.
Conclusion: This seems like a great throwy tube light. Nice and pocketable, and won’t break the bank (poor man’s P12GT, anyone?) And at the time of this writing, the SP31 V2.0 kit can be found on Amazon (non-aff link) for $36.99. Considering you get a well-built light, a battery, and a charger, that seems like a pretty good deal.
And now for some comparison shots:
Left to right: Sofirn SC31, ThorFire TK15, Sofirn SP32A V2.0, Sofirn SP31 V2.0, and Nitecore P12GT
Edited by: gchart on 04/12/2019 - 02:01
ggf31416
Last seen: 8 hours 36 min ago
Does it tailstand well? The v1 I purchased some time ago could tailstand, but was somewhat unstable. I ended exchanging the tailcap with a UV Convoy (I don’t really need momentary ON). I’m not sure if Sofirn fixed that.
Serlite
Last seen: 5 hours 11 min ago
I got the v2 not that long ago, and I think it’s basically still the same situation – when off, it really can’t tailstand at all, but when switched on, the button will be depressed just enough that it can tailstand (though probably not in the stablest of ways).
fluke
Last seen: 13 hours 21 min ago
So basic throw and output compared to the P12GT would be?
gchart
gchart's picture
Just double checked… mine tailstands flawlessly. The tailcap doesn’t even touch (though it’s very close).
gchart
gchart's picture
Did you see the table under the “Throw” heading?
fluke
D'oh. No <img src= " />
gchart
gchart's picture
Big Smile don’t sweat it
Lightbringer
Lightbringer's picture
Last seen: 7 hours 7 min ago
As far as the nice flat runtime graphs, I think it has a buck or buck-boost converter, especially if it can take a pair of ’123s like the SP32Av2 can.
I think it’s not really as popular as it should be because it got overshadowed a bit by the ’32.
Did the ’31 ever get made in silver or “pale gold”? That’s what made the ’32 a big(ger) star.
gchart
gchart's picture
LB, you can have whatever color you want… as long as it’s black. Wink
I wish it were offered in the silver or pale gold options like the ’32 Sad
Lightbringer
Yeah, the ’31 got short shrift. Kinda sad.
peg matite
peg matite's picture
Last seen: 6 hours 1 min ago
Very similar to Fenix PD35 V 2.0.
Other than Fenix feeling a little more solidly built, not much difference. Sofirn beam a bit floodier than the Fenix. Nice in my book.
Sofirn 1/2 the price.
