Osram Ostar Projection PC-green tested, KP CSLNM1 F1
62 posts / 0 new
djozz
djozz's picture
Last seen: 7 hours 27 min ago
I received this brand new led from TheOnlyDocc, who managed to get some samples from Osram. Partnr is KP CSLNM1 F1, brightness bin 7N (lowest bin on the datasheet), chromaticity bin A. Datasheet here: https://www.osram.com/media/resource/hires/osram-dam-2494973/KP%2520CSLN...
It is clearly the same generation as the White Flat, 1mm2 die, the die is a phosfor-converted blue led with a surprisingly uniform emission surface.
The spectrum at 50mA (does not change noticably at an angle or at higher currents):
Now that is efficient!, no CRI to match (it does have a CRI of 31 btw), so no light wasted for inefficient red colours, everything goes to where your eyes are most sensitive to. The appearance is a pale green, not as deep green as a single wavelength led, and when things are illuminated you can distuinguish colours faintly.
For completeness, here's the tint:
The performance (on a 16mm XP DTP board from Kaidomain) was a surprise, I plotted the data for comparison together with the 1mm2 White Flat.
For my method see my XP-L test from a few years ago, found via my sigline.
I think it is a good achievement but to be expected that the output is higher than the White Flat, but what is the real surprise is how it handles high currents: it maxes out at almost 7A, and at 9A where I stopped the test the output was hardly less. Mind that this is a 1mm2 ledsurprised Also going back to lower currents showed almost the same performance as before the 9A abuse. That makes the expectation for the HX Boost even higher.
Should be fun to make a thrower at 4-5 amps with this one.cool
________________________
Thanks to The OnlyDocc for sending me two of these leds.
Edit: a first test of this led in a flashlight in post#29.
Edited by: djozz on 04/19/2019 - 13:02
CRX
CRX's picture
Last seen: 52 min 52 sec ago
Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 8 months 3 weeks ago
Thanks for the test! Will get me a 4-5 amp driver and build a nice thrower with it.
If the new Boost HX performs similar it will be a very very interesting throw led.
To bad wavien collars are no longer available. A boost HX pushed behind specs covered by a wavien collar. Mhhh
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
contactcr
Last seen: 35 min ago
TheOnlyDocc wrote:
Thanks for the test! Will get me a 4-5 amp driver and build a nice thrower with it. If the new Boost HX performs similar it will be a very very interesting throw led. To bad wavien collars are no longer available. A boost HX pushed behind specs covered by a wavien collar. Mhhh
There doesn’t exist many good aspheric hosts anyways!
Agro
Agro's picture
Last seen: 8 hours 22 min ago
Indeed. I do think there’s a market space for another. Several another.
MRsDNF
MRsDNF's picture
Last seen: 53 min 8 sec ago
Thanks for the testing djozz and to The OnlyDoc for donating them.
So these would outperform the XPE2 green led by a long shot?
TheOnlyDocc
@MRsDNF
Yup it ourperforms the XPE2 and the LCG H9RN.
And what is more interesting, this new led can handle a huge amount of current (way over spec).
If the boost HX reacts similar it will be a huge bump.
Guess they are on point with their advertising:
OSLON Boost HX makes use of the high current capability of the latest chip generation in a thermal optimized package.
Can not wait to see one in a aspheric or a very good reflector (like the GTmicro).
EasyB
Last seen: 2 hours 28 min ago
Thanks for the test. Nice LED for those lumen hunters. Big Smile
That is interesting about the higher current-handling ability. I thought this is basically the same as the white flat but with different phosphor? So the chip and thermal path down should be the same. Could it be that the white light phosphor produces a lot more heat than the green phosphor and that is the source of the difference?
djozz
djozz's picture
Strictly it is not a green led and the light looks different too. But if that is not relevant its luminance is higher than anything there was before, including all white leds.
contactcr
I think between his efficiency comment, the lumens being higher and spectral chart being so narrow that is likely exactly what he is trying to say Question
Barkuti
Barkuti's picture
Last seen: 4 hours 5 min ago
contactcr wrote:
There doesn't exist many good aspheric hosts anyways!
Agro wrote:
Indeed. I do think there's a market space for another. Several another.
Albeit it looks pretty good this one is still untested around here: http://kaidomain.com/S027435-DIY-LED-Flashlight-Host-130mm-x-47_5mm-Black
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
contactcr
I mean it looks OK but if it doesn’t beat the Z1 it doesn’t interest me. A fixed thrower aspheric with a slightly larger lens would be even better.
nofearek9
nofearek9's picture
Last seen: 1 day 16 hours ago
thanks for the test!good results.
led4power
led4power's picture
Last seen: 16 hours 32 min ago
White flat and "Green" flat have the same thermal resistance, so max. currents should be similar, green flat peak could be a little bit higher (0.5-1A) due to higher efficiency and lower phosphor loss.
So I think this confirms your white flat test was probably with sub-optimally reflowed LED since I got 5.75A peak, almost 1A higher than what your test shows.
djozz
djozz's picture
led4power wrote:
White flat and “Green” flat have the same thermal resistance, so max. currents should be similar, green flat peak could be a little bit higher (0.5-1A) due to higher efficiency and lower phosphor loss.
Yes, I considered that. Funny thing is that this time the reflow was done with less care (more solder) than with the White Flat test. So I do not rule out that this difference is real. I may re-do the White Flat test although it is less fun to re-test stuff than something new Tired (and it costs me another led, ).
led4power
led4power's picture
How about this: I'd like to send you 9 LEDs, 3 soldered by me, 6 bare + 6 3030-20 DTP boards + small amount of lead free solder. You should solder 3 LEDs with your lead paste, and other 3 with my lead free paste.
So you could finally test lead vs. lead free solder,and also see if soldering technique has any visible effect, white flat is best LED for that test since it has smallest thermal pad (3x1mm) and highest power density (W/mm2).
3LEDs for each test is to eliminate "luck" during soldering and LED thermal resistance variance.
djozz
djozz's picture
led4power wrote:
How about this: I’d like to send you 9 LEDs, 3 soldered by me, 6 bare + 6 3030-20 DTP boards + small amount of lead free solder. You should solder 3 LEDs with your lead paste, and other 3 with my lead free paste.
So you could finally test lead vs. lead free solder,and also see if soldering technique has any visible effect, white flat is best LED for that test since it has smallest thermal pad (3×1mm) and highest power density (W/mm2).
3LEDs for each test is to eliminate “luck” during soldering and LED thermal resistance variance.
That is quite a few hours of testing but it sounds like that will generate some useful data, let’s do that. But we can not set a hard deadline for this, having a family, and with always the possibility for the need of extra care for my son, my hobby-time can spontaneously evaporate at any time, so things must be postponable.
Henk4U2
Henk4U2's picture
Last seen: 6 hours 30 min ago
djozz wrote:
led4power wrote:
How about this: I’d like to send you 9 LEDs, …………
Wow, that is some hardcore BLF cooperation Thumbs Up Thumbs Up
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 11 hours 11 min ago
Is there a red version available, too?
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
djozz
djozz's picture
there is the KR CSLNM1.23
datasheet: https://dammedia.osram.info/media/resource/hires/osram-dam-5961110/KR%20...
617nm, up to 2500 mA and then just over 300 lumen. Probably an upgrade over the red XP-E2 but it is not a phosfor-converted red but a classic single wavelength led. I expect it can not be overdriven like blue leds can.
Tom E
Tom E's picture
Last seen: 2 hours 10 min ago
Wow, this is pretty interesting... Would be interested in getting a couple of these when available.
led4power
led4power's picture
Looking at datasheets, two graphs (output vs current and output vs temp) also show that green flat looses output slower than white flat at higher currents and higher temperatures, which is in agreement with djozz' measurements(left white flat, right green flat):
One interesting thing is green flat output reaches max. at ~40-50C, but it's only 1-2% higher compared to 20C.
djozz
djozz's picture
The relative flux looks almost identical to me (2.4times at 3A for both) ?
led4power
led4power's picture
Green flat is a little bit closer to 2.5 than white flat, difference is small, temperature has much more visible effect, at 100C white flat is at ~89%, green flat at ~94%.
The_Driver
The_Driver's picture
Last seen: 1 week 1 day ago
Thanks for this very interesting test!
So the luminance is around 400cd/mm^2 or even above that!
Unfortunately it has a green tint Facepalm
JaredM
JaredM's picture
Last seen: 5 hours 19 min ago
Interesting to see the future results and parsing out the efficiency differences at high currents.
A Boost HX at 5000k is something to dream about..
Tom E
Tom E's picture
The_Driver wrote:
Thanks for this very interesting test! So the luminance is around 400cd/mm^2 or even above that! Unfortunately it has a green tint :FACEPALM:
No one likes green, hhmmmm. But if there's a lot of green, that's good!
Barkuti
Barkuti's picture
Djozz, could you please edit the opening post and fix the full of tracking sh1t datasheet link provided? Replace with the following:
https://www.osram.com/media/resource/hires/osram-dam-2494973/KP%2520CSLNM1.F1.pdf
Due to being long like a longaniza it breaks the page layout for small screen devices. Thanks.
P.S.: anything beyond a question mark or ampersand in a link usually is best removed.
djozz
djozz's picture
I just put the second led that I got in my GT micro. I know, this nice flashlight deserves better than green, but I could not resist. The steps I took:
*Unsoldered the ledboard, unsoldered the XP-L Hi, added a little solder paste, soldered the Green Flat on the stock board
*had to use a new centerpiece with square cutout to center the led. Sanded it the same thickness as the stock centerpiece, made the cutouts with a scalpel to fit the Green Flat 45 degrees rotated.
*Reamed the reflector hole to fit the new slightly larger centerpiece. Can’t go back now to stock Facepalm
*Closed the head and test: perfect focus on first try Glasses , also tells that Lumintop did a good focussing job
*did a spring bypass on the tail (with tailboard in place).
Wow, that is a bright green spot. I carefully measured it (purple Efest battery, 30 seconds) at 7 meter with my best luxmeter: 177 kcd. I measured a few known lights to check the luxmeter (it reads high with an almost depleted battery), and it reads correct. The output (purple Efest, 30 seconds) I measured at 930 lumen, good enough, that would be between 3.5 and 4 A.
It does well outdoors as well, spot aimed at about 70 meter. Shocked
So now I scratch my head what to use it for. Showing off to my son I guess Party
djozz
djozz's picture
Sorry about that, done Smile
penumbra
penumbra's picture
Last seen: 2 weeks 1 day ago
waw thats cool i hope there come one deep red like that.
