[M4D deal ALIVE] ADEASKA VC4 PLUS 3A Fast Charger
groupbuy: ADEASKA VC4 PLUS 3A Fast Charger
Hello my dear friends!
Today i present a new banggood groupbuy:
(links in the pictures and text take you to the shop)
ADEASKA VC4 PLUS only US$ 30.99 (39.99)
3A Fast Charging – LCD Screen – USB output
use my Code: MAVC4 in the cart to get the discount!
(works for ~30 days or when all units are sold)
reserved
what is the max lenghts for battery?? some protect 21700 are up to 75mm….
Any good review for this?
looking on 18650 in pictures there is about 80mm total length
also 2/3A for NiMh charging?
Can it discharge to measure capacity ?
No battery discharge function
But you can build a good battery discharger: see here
https://github.com/msillano/e3DHW-PMS/blob/master/applications/Battery%20discharger_en.pdf
The project is for NiMH batteries, but it is easy to change code for any battery.
Best regards.
NiMH limited only to 0.5 A
Max length measured on my charger: 7.5 mm.
Best regards
m.s.
For a good review see:
Best regards.
I used to buy those chargers often for my friends as a good and cheap charger.
However on the latest batch I received, I noticed that it started to charge with an extremely high voltage. With all 4 units, it goes up to 4.30V on most slots while charging, even often triggering the protection of my batteries, leading to an over-full battery (it has 4.27V after finishing) in a slot with ‘Null’ display (because of tripped overvoltage protection) and the charger applies a constant 5V to that battery because it seems to constantly want to revive the battery…. :frowning:
Anyone else seeing this behavior?? Won’t be buying them anymore I fear :frowning:
