Test/review of MPIFR 18650 1500mAh (Gray)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 48 min ago
DSC_3472
Official specifications:
  • Type: IFR MUB18650 1500mAh
  • Nominal Capacity: 1500mAh
  • Nominal Voltage: 3.2V
  • Size: Diameter 18±0.2mm X Height 65±0.5mm
  • Net Weight: 40g
  • Max charge voltage: 3.70V
  • Max continuous charge current: 1500mA
  • Max continuous discharge current: 3000mA
  • Discharge cut-off voltage: 2.0V
  • Internal impedance: (20±2°C)
  • Operation temperature: Discharge: -20°C ~ 70°C, Charge: 0°C ~ 70°C
  • Cycles: above 1000 (0.2C to 3.7V till the charge current is less than 0.01C. 0.2C to 2.0V when discharge)
MPIFR%2018650%201500mAh%20(Gray)-info
A LiFePO4 18650 cell, the capacity is fairly limited, but the lifetime rating is good.
DSC_3471
DSC_3473 DSC_3474
DSC_3475
DSC_3476
MPIFR%2018650%201500mAh%20(Gray)-Capacity
The discharge curves match fine and as usual for LiFePO4 the discharge voltage is very constant. The batteries are only rated for 3A and they handle that easily.
MPIFR%2018650%201500mAh%20(Gray)-Temp-7.0
MPIFR%2018650%201500mAh%20(Gray)-Temp-10.0
MPIFR%2018650%201500mAh%20(Gray)-Temp-15.0
MPIFR%2018650%201500mAh%20(Gray)-CapacityTimeHours
MPIFR%2018650%201500mAh%20(Gray)-Energy
MPIFR%2018650%201500mAh%20(Gray)-PowerLoadTime
MPIFR%2018650%201500mAh%20(Gray)-TripCurrent
MPIFR%2018650%201500mAh%20(Gray)-Charge
Conclusion
This battery works fine, but capacity is limited. The 3A rating looks rather conservative.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 50 min 6 sec ago
Thanks HKJ!
DavidEF
DavidEF's picture
Last seen: 2 days 11 hours ago
This looks to be a decent cell. However, it would be nice if some manufacturer could get a LiFePO4 18650 up to at least 2000mAh. The voltage range is perfect for modern low Vf emitters.
- The YKK Philosophy
Shadowww
Last seen: 2 days 23 min ago
Perhaps discharge current rating is underrated to ensure good cycle life?
