Test/review of Vapcell INR18650 2800mAh (Black) 2018
13 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 hours 48 min ago
DSC_2106
Official specifications:
  • Model: INR18650
  • Size: 18.3*65.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 2700mAh (0.2C discharge)
  • Min capacity: 2800mAh (0.2C discharge)
  • Weight: Max:50g
  • Internal resistance: Max: 12mOhm (AC 1kHz)
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 2.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 25000mA
Vapcell%20INR18650%202800mAh%20(Black)%202018-info
This is high current 18650 batteries with good capacity.
DSC_2103 DSC_2105
DSC_2107 DSC_2126
DSC_2108
DSC_2109
DSC_2110
Vapcell%20INR18650%202800mAh%20(Black)%202018-Capacity
Very nice discharge curves with a good match and capacity drops slowly with higher current.
Vapcell%20INR18650%202800mAh%20(Black)%202018-Temp-15.0
I forget to put the temperature sensor on the A battery
Vapcell%20INR18650%202800mAh%20(Black)%202018-Temp-20.0
Vapcell%20INR18650%202800mAh%20(Black)%202018-Temp-30.0
Vapcell%20INR18650%202800mAh%20(Black)%202018-CapacityTimeHours
Vapcell%20INR18650%202800mAh%20(Black)%202018-Energy
Vapcell%20INR18650%202800mAh%20(Black)%202018-PowerLoadTime
Vapcell%20INR18650%202800mAh%20(Black)%202018-TripCurrent
By accident I started a “small battery test” instead of a normal test for the A cell. This means it will include a 100mA discharge, charging current is 0.5A and this test here only goes to 7A
Vapcell%20INR18650%202800mAh%20(Black)%202018-Charge
See text above.
Conclusion
This is a very good high current cell.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Barkuti
Barkuti's picture
Last seen: 1 hour 43 min ago
Overstated capacity  as usual.
Smells like Murata VTC5D under the hood.
Thanks for another review.
Superstocker
Superstocker's picture
Last seen: 2 hours 33 min ago
Thanks for all your work HKJ.
SKV89
Last seen: 40 min 11 sec ago
Thank you HKJ. I’ve been waiting for you to add this to your comparator. I assume this is the Sony VTC5D under the wrap. I bought a bunch of these Vapcells last year and am very happy with them. Outputs higher than my original wrapper Sony VTC6 in all of my high output flashlights. It is the best 18650 high drain and good capacity cell on the market.
Now hopefully you can test the new Vapcell rewrapped Molicel P28A. Hopefully this will outperform the VTC5D.
wolfdog1226
wolfdog1226's picture
Thanks HKJ,,,,,,,,I have Four of these from last spring. I was told they art VTC5D re wraps
___________________________________________________________________________________________________________________________
P28A? Never heard of it. Do you mean P26A?
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
HydrAxx
HydrAxx's picture
Last seen: 7 hours 7 min ago
False, the Sony / Murata US18650VTC6A (3000mAh, 25A Max continuous) is much better, and no other brand has managed to do as well or better, the only big problem remains to get at the moment (and authentic, not fake VTC6 rewrapped in VTC6A as is often the case). Personally I managed to get 6 units in February 2018, since impossible to get again, at least authentic, but what a person working in the distribution of lithium-ion cells told me, this situation should be unblocked soon.
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
SKV89
Vtc6a is the best 18650 for sure but they cant be bought anywhere. I bought the last two from Vapcell. Hope they make more of those or hope Molicel will outperform it.
contactcr
Last seen: 4 min 2 sec ago
http://www.molicel.com/hq/product/products12.html
Looks like a good one. If it’s cheaper than vtc5d then will be nice
vapcell Dennis
vapcell Dennis's picture
Last seen: 4 hours 46 min ago
Great job,HKJ Thumbs Up
d_t_a
Last seen: 19 hours 32 min ago
HKJ, will you be able to do a re-test of the Vapcell 2800mAh 18650 (perhaps Vapcell can provide them to you).
I’ve ordered these Vapcell 2800mAh 18650 (similar wrapping and label) but it looks a bit different from the ones in the photo — the bottom has a “ring” (and Vapcell mentions it’s now using Sony VTC5D). The photos of this former Vapcell 2800mAh 18650 do not look like Sony VTC5D..
HKJ
HKJ's picture
If Vapcell provides a new one I will retest it.
vapcell Dennis
Never change, always VTC5D rewarpped
Could you give us some pics?
Thank you very much.
d_t_a
vapcell Dennis wrote:
d_t_a wrote:
HKJ, will you be able to do a re-test of the Vapcell 2800mAh 18650 (perhaps Vapcell can provide them to you). I've ordered these Vapcell 2800mAh 18650 (similar wrapping and label) but it looks a bit different from the ones in the photo -- the bottom has a "ring" (and Vapcell mentions it's now using Sony VTC5D). The photos of this former Vapcell 2800mAh 18650 do not look like Sony VTC5D..
Never change, always VTC5D rewarpped Could you give us some pics? Thank you very much.
Ok, I'm sorry, I thought the picture from HKJ didn't have a "ring" on the bottom, but the photo just doesn't show it very clearly:
It looks like it's still the same Sony VTC5D. Pardon the confusion.
