Headlamp with tight beam?
21 posts / 0 new
wolfey
Last seen: 2 months 4 weeks ago
Does anybody know of a good headlamp with a tight beam without a lot of spill? I’m looking for a light for a friend of mine that runs trails at night and he needs this type of beam I guess. I let him borrow my zebralight h600 mkIV xhp50.2 and he said that the spill light was too bright and distracted his focus on the trail. So if anyone knows of a good 18650 headlamp with a tight beam and a neutral to warm led I’d appreciate any input.
Pavlo
Last seen: 7 min 36 sec ago
The H600w with XHP35 will be tighter than yours with the XHP50.2
The other headlamp I can recommend is the Eagletac PH10LC2 with either XP-L Hi or Nichia 219C led.
https://illuminationgear.com/products/sportac-ph10lc2-headlamp
Pete7874
Pete7874's picture
Last seen: 27 min 19 sec ago
Skilhunt h03r maybe?
zak.wilson
Last seen: 1 day 5 hours ago
The Thrunite TH10v2 with XHP35 HI should have a fairly tight beam. If you want tighter, I hear Sofirn is planning a right-angle 18650 light with an SST-20.
Ceilingbounce – flashlight testing and runtime graphs for Android
Quadrupel
Quadrupel's picture
Last seen: 1 week 19 hours ago
…spill light was too bright and distracted his focus on the trail….
Nonsence
YuvalS
YuvalS's picture
Last seen: 3 days 19 hours ago
Lightbringer
Lightbringer's picture
Last seen: 8 hours 42 min ago
Any headlamp which uses a 20mm TIR lens, you can swap that with a 5° or 8° lens instead.
Any headlamp with a reflector will have spill, ie, anything that comes straight off the LED instead of hitting the reflector, which’ll be a lot unless the reflector’s like 10× as deep as it is wide.
wolfey
Thanks. I think one of these models will work well for him.
Enderman
Enderman's picture
Last seen: 1 day 14 hours ago
Led Lenser makes several headlamps with no-spill beam.
sac02
sac02's picture
Last seen: 6 days 21 hours ago
My H3 Warboy has a tight beam pattern for a reflector light, the tightest of all my non-TIR headlamps.
Also, the choice of LED plays a large role. Swap out the large XHP50.2 you mentioned in the OP for something like an XP-L Hi and the beam will be significantly tighter.
(I know mods on a ZL are problematic, I meant more like choose a light with a throw-ey LED as much as I meant mod it yourself)
Enderman
Enderman's picture
Anything that uses a typical reflector will have spill.
There’s no avoiding that, no matter how small an LED you use.
Oli
Last seen: 3 weeks 4 days ago
Looking at zebralight website you could have one of four models that they sell. 2 with 4000k and two with 5000k. The higher tint causes more light reflection back off of trees and leaves and other things. Do you have the 4000k or the 5000k? I’m going to guess 5K.
mattadores
mattadores's picture
Last seen: 1 week 1 day ago
Try the Olight H16 Wave. has a dual emitter set up with one diffused and one a thrower
my older model H25 wave is amazing but for me the beam profile is way too narrow
Oli
Low tint and hight cri and the spill won’t really distract/matter.
Pavlo
The Eagletac PH10LC2 with 219C LED strikes all the boxes:
-Super efficient driver with constant current and flat regulation
-High CRI
-Warm White 4000K CCT
-Small LED for increased throw and decreased spill intensity
Con: recommend a different headband. Zebralight ones work great.
Oli
I think 4000k is still too high for running past trees and other obstacles if they are close to you on a trail. If the trees are way off to the side maybe 4K would work. This issue of tint selection hasn’t really had much discussion when there are obstacles between you and what you are trying to look at or focus on. You read a lot about people saying tint selection is a personal preference. Bull. Stand in an open area and shine a light into the woods somewhere and try to see some specific object well into the woods and the higher tints will bounce off of the trees right on the edge and you can’t see and focus farther into the woods as well as you can with a lower tint. The same thing applies while shining a light down a long hallway. Regardless of how much spill you have higher tints bounce more light off of the walls and ceiling and floor and do not allow you to see and focus on specific objects at the end of the hallway.
wolfey
It’s a 4000k. I was thinking the light would work well for him but everyone likes something different.
Pavlo
I think its a compromise between CCT preference and function. 3000K will be better to reduce glare as you describe over a cooler CCT, but many dislike 3000K as they find it too warm. It will also be harder to find a headlamp with 3000K high CRI that fits the above criteria without modifying one.
LumenMax
LumenMax's picture
Last seen: 2 min 5 sec ago
Acebeam H40 Neutral White. Pretty tight compared to other headlamps that I've seen.
sac02
sac02's picture
Enderman wrote:
Anything that uses a typical reflector will have spill. There’s no avoiding that, no matter how small an LED you use.
True, but he didn’t say “no spill” he said not as much as XXX light. My interpretation of the OP was that he wanted a higher hotspot/spill ratio.
An aspheric like a Lenser will either have all spill (and we are looking for less spill) or all spot with no spill and you need SOME spill when trail running. Trying to trail run with a laser beam on your head would be a bad idea
Oli
I think we are actually on the same page. But you are inadvertently perpetuating a fallacy. How can people dislike a 3000k high CRI headlamp that doesn’t exist? Let’s assume this trail has rocks and roots and leaves and little ankle twisting holes. You need to be processing foot placement two three four steps out and looking down the trail. A light with a more focused beam or hotspot is just going to introduce more angles and edges and perceived movement to your field of vision as that light/spot bounces wildly in front of you. So less spill is not the answer. Less light bouncing off of tree trunks and live leaves on the trees is a good thing. Being able to distinguish between the rocks and dried-up brown leaves on the ground is a good thing. Beam shots are one thing. The real world is entirely different. I think part of the problem is that everybody “knows” that higher tints throw “better”. I think that needs a lot more discussion but in a different thread.
