Review: Nitecore NTP40 Titanium Alloy Mechanical Pencil
4 posts / 0 new
roma58
roma58's picture
Last seen: 1 month 1 week ago
NITECORE NTP40
The Nitecore NTP40 was sent to me directly by Nitecore for review.
For the technical characteristics of the product: https://flashlight.nitecore.com/product/ntp40
For purchases: https://www.nitecorestore.com/NTP40-Mechanical-Pencil-p/pen-nite-ntp40.htm
Immagine
The Nitecore NTP40 Titanium Alloy Mechanical Pencil is a pencil made of Titanium alloy TC4 machined with a CNC machine (computer numerical control), characterized by an excellent lightness, excellent resistance to shock and corrosion.
The Nitecore NTP40 is an excellent travel companion for all situations in which a prestige mechanical pencil is needed to write or draw fluently.
The Nitecore NTP40 is compact and light and equipped with a good grip to easily write in everyday use without getting tired.
Specifications:
Made of TC4 titanium alloy for strength and lightness
Shock and corrosion resistant
Detailed thread for a secure but comfortable grip during use
Abrasion resistant crystallized cap
High-quality German Schmidt Feinminen system with 0.5 mm lead refill
Detachable pocket clip for easy transport
Mechanism shaft dimensions: 0.437 "Length, 0.024" Diameter (111mm x 6mm)
Dimensions:
Length: 5.4 "(137 mm)
Diameter: 0.35 "(9 mm)
Weight: 0.84 once. (23.9 g)
Immagine
The packaging:
The Nitecore NTP40 package remembers the one previously seen with the NTP30 tactical pen. We have a semi-rigid black cardboard box. On the front the writing Nitecore, the name of the model NTP40 and the type of mechanical pencil TITANIUM ALLOY MECHANICAL PENCIL 0.5mm Lead. In the central part there is also the stylized design of the new NTP40.
Immagine
Inside the package we find the Nitecore NTP40 inserted inside a shaped protective foam with a yellow cardboard on it with the writings that identify the main parts that distinguish the Nitecore NTP40.
Immagine
Immagine
Nitecore's NTP40 mechanical pencil is made of TC4 titanium alloy and CNC machined. With this type of processing a light product is obtained but at the same time very resistant to impact and corrosion.
Immagine
In addition to being light, the NTP40 holds well in the hand and does not slip thanks to the special 26-thread slip-resistant processing. This treatment facilitates writing comfort even for prolonged use.
Immagine
Immagine
Immagine
The internal cartridge containing the mines is of German construction. It is a 0.5mm Schmidt Feinminen system.
This system allows a smooth and legible writing in every situation.
https://www.schmidttechnology.de/en/index.htm
Immagine
Immagine
Immagine
The Nitecore NTP40 can also be completely disassembled.
Immagine
Immagine
The processing of the NTP40 threaded parts is always of quality. The thread are precise and smooth.
Immagine
Immagine
Particularly at the head of the NTP40 is the mine thrust cap with the cap with crystallized finish for excellent abrasion resistance. Every pressure we make on the head pushes the mine out perfectly and evenly.
Immagine
Immagine
Immagine
The Clip that we find installed on the NTP40 is also made of titanium alloy and allows an excellent portability of the NTP40. It can be removed by unscrewing the two fixing screws.
Immagine
Immagine
The writing NITECORE NTP40 is excellent and we find it engraved on the central body of the pencil.
Immagine
Immagine
The Nitecore NTP40 next to the Tactical Pen NTP30.
Immagine
Immagine
VIDEO.
CONCLUSIONS:    The Nitecore NTP40 TITANIUM ALLOY MECHANICAL PENCIL is a mechanical pencil made of titanium, valuable material resistant to impact and corrosion. The processing is accurate, precise and without imperfections. It wears well and can be a useful everyday companion "EDC", also thanks to the excellent Clip, it can be easily stored in trousers, jacket, case, backpack etc.
The NTP40 is equipped with the German-made 0.5mm Schmidt Feinminen mine port system. Thanks to this system and the excellent mechanical precision, the writing quality is always high.
In conclusion, the Nitecore NTP40 is an excellent product, elegant in its forms, precise and light in writing. The selling price is not low but if you need a quality and prestige pencil the Nitecore NTP40 is the right product.
Thank you for reading the review.
Immagine
MascaratumB
MascaratumB's picture
Last seen: 5 hours 37 min ago
Thanks for the review! That surely seems a nice pencil! Too bad that it’s price is…three digits! Seems reliable, though !
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Jeraa
Last seen: 5 days 14 hours ago
Actually a detailed review but I would like to have more photos. I’m really interested in professional writing so the right tool is very important to me. But anyway, I like this review and hope to read something like this but about another product.
Rexlion
Last seen: 15 hours 19 min ago
Maybe I missed it, but I never saw how the lead is retracted. That’s the one feature that matters most to me, since I am constantly having to pull the pencil out of my shirt pocket, write a bit, then put it back in my shirt pocket (lead retracted). Quick, one-handed retraction is what led me to the Pentel GraphGear 1000, and so far that is my go-to pencil. But it’s definitely not titanium.
