Test/review of Vapcell INR21700 4500mAh (Red) 2019
16 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 min 27 sec ago
DSC_5814
Official specifications:
  • Model: INR21700
  • Size: 21.5*70.8mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50v
  • Typical Capacity: 4500mAh (0.2C discharge)
  • Min capacity: 4400mAh (0.2C discharge)
  • Weight: Max:72g
  • Internal resistance: Max:15mOhm
  • Standard Charge: 1500mA, CCCV 100mA cut-off
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 20A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage Temperature -5°C~35°C
  • Storage Humidity:
Vapcell%20INR21700%204500mAh%20(Red)%202019-info
This is a high current battery in 21700 size with good capacity.
DSC_5812 DSC_5813
DSC_5815 DSC_5816
DSC_5817
DSC_5818
DSC_5819
Vapcell%20INR21700%204500mAh%20(Red)%202019-Capacity
The two tracks matches fairly well and capacity only goes down slowly with load.
Vapcell%20INR21700%204500mAh%20(Red)%202019-Temp-15.0
Vapcell%20INR21700%204500mAh%20(Red)%202019-Temp-20.0
Vapcell%20INR21700%204500mAh%20(Red)%202019-Temp-30.0
Vapcell%20INR21700%204500mAh%20(Red)%202019-CapacityTimeHours
Vapcell%20INR21700%204500mAh%20(Red)%202019-Energy
Vapcell%20INR21700%204500mAh%20(Red)%202019-PowerLoadTime
Vapcell%20INR21700%204500mAh%20(Red)%202019-TripCurrent
Vapcell%20INR21700%204500mAh%20(Red)%202019-Charge
Conclusion
This looks like a good battery, it can handle a fairly high current and has good capacity.
Notes and links
Graphical comparison to 18650 and other batteries
Graphical comparison to 26650 and other larger batteries
Table with all tested LiIon batteries
shadockan
shadockan's picture
Last seen: 3 days 10 hours ago
Is it the Lishen ???
Thank’s HKJ
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 min 40 sec ago
It could also be Samsung’s 48G (with the recessed ring in the bottom).
SKV89
Last seen: 4 hours 51 min ago
It’s the Lishen LR2170SF. It beats the Samsung 48G and 50E per Mooch’s testing but that was with the orange wrapper version, which test about 47xx to 48xx mah. Seems Vapcell wasn’t able to source the same batch or grade as the orange wrapper version. Still, it is better than the 48G.
Superstocker
Superstocker's picture
Last seen: 8 hours 48 min ago
Thanks HKJ!
vapcell Dennis
vapcell Dennis's picture
Last seen: 5 min 58 sec ago
Thanks HKJ Thumbs Up
vapcell Dennis
the same orange version Smile
toobadorz
toobadorz's picture
Last seen: 5 hours 15 min ago
I have bought LR2170SF for several times. This cell performance varies from batch to batch, and their original wrappers are all orange.
These two tested by HKJ here performed differently from Mooch’s samples, they are better. Mooch’s Vapcell samples are about 4050mAh down to 2.8A at 10A load, while HKJ’s samples here are close to 4300mAh.
And, if you go back to examine the Shockli 4550mAh (also a LR2170SF re-wrapped) samples tested by HKJ, you’ll find that the two samples also performed worse (~4100mAh down to 2.8A at 10A load). But the same cells I bought from Shockli previously were good (also close to ~4300mAh down to 2.8A at 10A load).
So I think both Vapcell and Shockli simply re-wrap the cells sourced, without ensuring they are from a batch of good performance. It will be better if they can do this for us, because the original LR2170SF cells are cheaper.
Lux-Perpetua
Is there any comparison between Lishen’s blue-wrapped LR2170SA and orange-wrapped LR2170SF? It seems the “SA” cell is 4.000mAh while the “SF” cell is 4.500mAh, correct?
toobadorz
toobadorz's picture
Exactly. And “LR2170SC” is 5000mAh. Many are re-wrapping the “SA” cell, say, the LiitoKala 21700 4000mAh. Simply compare them with HKJ’s comparison tool.
The LR2170SA cell performance also varies. To my experience, some of them are 4000mAh or slightly less, and some of them are 4200mAh or more, even close to those worse LR2170SF. The discharge curves are quite different between “SA” and “SF”, so you can still identify them easily.
Blggg
Last seen: 4 days 18 min ago
Have you got the 5000mAh version? Is it out on the market yet?
toobadorz
toobadorz's picture
That “SC” cell can be found in some China power bank built with a single 21700. Not a feasible/practical idea to get it though. Its performance is slightly better than Sanyo NCR21700A, but given the high variation seen on “SA” and “SF”, maybe not a common fact…
If Vapcell manages to re-wrap this “SC” cell, I’ll be more than happy to buy some…
Besides this LISHEN LR2170SC cell, I’m also looking forward to the upcoming MOLICEL M50A, which is also a 5000mAh 21700 cell of moderate drain.
Lux-Perpetua
toobadorz wrote:
[…] Besides this LISHEN LR2170SC cell, I’m also looking forward to the upcoming MOLICEL M50A, which is also a 5000mAh 21700 cell of moderate drain.
Me, too! Smile But I‘m worried that these won’t fit in most 21700 lights for they have 21.7mm in diameter. Actually, Molicel fibs a bit when declaring the M50A a 21700 cell. They‘d rather call it 22700.
Blggg
Yes, I am really looking forward to its release. Lishen cells would have easily been one of the best if there was not much of the performance variation between the cells. Must be quite some time till either Molicel or Lishen-Vapcell is out on the market.
vapcell Dennis
LOL Vapcell shrinkage was prepared last year, but only a few samples were available.
Hope to get a large quantity of 21700SC as soon as possible, we will release it. Smile
vapcell Dennis
lol 22700 battery,i think it is Cool
