Best Method To Replace Your Astrolux FT03 Thermal Paste!
21 posts / 0 new
vietnamreviews
Last seen: 3 hours 57 min ago
It can be said that at the present time with a price of only $ 30 Astrolux FT03 is the most affordable flashlight.
We can increase the performance of Astrolux FT03 significantly when replace the new thermal glue.
If you don’t have a good iron, do it my way. Removing the led is not a good option It takes a lot of time. Good luck my friends.
HONDARIDER
HONDARIDER's picture
Last seen: 2 months 1 day ago
Wow, that looks messy. Sure wasn’t very much past under there from the factory. I will be removing my MCPCB this evening to rework the thermal paste.
Johm
Last seen: 4 hours 38 min ago
Well done.
Still, this seems a little tricky to be certain:
- you removed all the previous paste
- coverage is good
- not too much paste.
Is it getting hot faster now?
Lexel
Lexel's picture
Last seen: 8 hours 30 min ago
Johm wrote:
Well done.
- coverage is good
the thermal mass of the MCPCB can be likely ignored
so the heat up is always pretty much the same speed, just the MCPCB temperature stays lower as less thermal resistance
compared to electronics its like you got to feed 20W to a part, but with different resistors
the bigger resistor needs a higher voltage (resistor loss of course not calculated into the 20W power as a thermal resistance does not create heat)
teacher
teacher's picture
Last seen: 9 months 3 weeks ago
Cool video & great music. Thumbs Up
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 44 min ago
Better hope it don’t start to smoke with all the grease you put under and around the sides of that board when it gets really hot, specially if your board and the host shelf isn’t flat, the air gap will get the grease boiling, the suspension will start to vaporize leaving a nice oily film on your reflector.
KB1428 “Live Life WOT
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 8 hours ago
Well, thermal grease can’t really boil at the temps any CPU/GPU/flashlight run at, so it shouldn’t be a problem.
Lexel
Lexel's picture
The amount and pattern on my FT03 looks good
KawiBoy1428
Yeah not the grease itself, the suspension burns/vaporizes/smokes, I have had it happen. Well the only thing I could point my finger at, I used way too much back in the beginning, way too much.
vietnamreviews
Please use it, mx-4 or some kind of good thermal glue
Funtastic
Funtastic's picture
Last seen: 4 hours 23 min ago
Can someone suggest some decent inexpensive paste off AliExpress. The cheaper the better as I’ll be building heaps of lights and selling them. Something that can still handle direct drive. I’ve been using Arctic MX-4 but it’s a little expensive
Texas Ace Lumen Tube calibrated with maukka lights
vietnamreviews
Arctic MX-4 is good
Funtastic
Funtastic's picture
Yeah, i ended up just buying 20g of it
Agro
Agro's picture
Last seen: 1 min 3 sec ago
GD900?
rikr
rikr's picture
Last seen: 3 months 5 days ago
Hey guys I tried dedoming the sst40 in my FT03, it has been a disaster. It seems my soldering iron isn’t getting hot enough to solder on the + and – wires and then they ripped. So I need a new MCPCB, I’m just going to put it back together in stock form. Do you know what size that is in this and new wires what gauge should I get? Thank you
 New Collection / Old Collection
Funtastic
Funtastic's picture
Funtastic
Funtastic's picture
I sliced my SST-40 as dedoming is quite hard on that LED. It barely gave any extra throw so I wouldn’t repeat it.
rikr
rikr's picture
Cool, thank you.
AlexGT
AlexGT's picture
Last seen: 2 days 18 hours ago
Anyone remembers what size is the MCPCB? Just wondering if it’s 32mm to order a replacement to use on another project.
TheOnlyDocc
TheOnlyDocc's picture
Wow! Thats a messy way to do it. A really good tipp to vietnamreviews. Get yourself a soldering iron! It makes things like that way more easy and way less messy!
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
HKSJOSHUA_
HKSJOSHUA_'s picture
Last seen: 5 days 7 hours ago
I used artic silver 5 for this on my ft03
