Test/review of EAIEP INR18650-33E 3300mAh (Pink)
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 36 min ago
DSC_4568
Official specifications:
  • Cell Type : Li-ion
  • Battery type : INR18650-33E
  • Capacity : 3000-3400 mAh
  • Voltage : 3.7V
  • Size: Ø18mm x 65 mm
  • Weight: 46g
EAIEP%20INR18650-33E%203300mAh%20(Pink)-info
A 18650 battery with the same name similar to Samsung naming, is this a Samsung battery?
DSC_4567
DSC_4569 DSC_4570
DSC_4571
DSC_4572
EAIEP%20INR18650-33E%203300mAh%20(Pink)-Capacity
The battery can “only” deliver up to 7A and the cells is not perfectly matches.
EAIEP%20INR18650-33E%203300mAh%20(Pink)-Temp-7.0
I forgot to mount the temperature sensor on the B battery.
EAIEP%20INR18650-33E%203300mAh%20(Pink)-Temp-10.0
EAIEP%20INR18650-33E%203300mAh%20(Pink)-CapacityTimeHours
EAIEP%20INR18650-33E%203300mAh%20(Pink)-Energy
EAIEP%20INR18650-33E%203300mAh%20(Pink)-PowerLoadTime
EAIEP%20INR18650-33E%203300mAh%20(Pink)-TripCurrent
EAIEP%20INR18650-33E%203300mAh%20(Pink)-Charge
Conclusion
The battery works fine, but are slightly limited at higher current.
I have not tested a Samsung called 33E, but 32E, 33G & 35E they are all better.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Barkuti
Barkuti's picture
Last seen: 1 hour 41 min ago
Thanks for the effort Henrik.
Looks like some sort of lesser known asian li-ion cell manufacturer product. Its OEM rating should be ≈3100mAh and ≈1.5C for discharge rate, I think.
Not bad for the price.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Milan
Last seen: 2 days 3 hours ago
This cell is obviously trying to impersonate an INR cell while having the IR 3 times of normal lico, and 8 (yes eight) times of true high current cell.
For this it deserves to be slammed and warned against!
Saying “slightly higher current” is like saying its ok to totally scam us.
If you let them, they will just keep doing it!
Don’t agree with that game!!!!!
Lexel
Lexel's picture
Last seen: 3 days 4 hours ago
IR of and 5 year old laptop pull thanks no
Superstocker
Superstocker's picture
Last seen: 6 hours 56 min ago
Thanks HKJ!
59
59's picture
Last seen: 1 month 6 days ago
Maybe the “DLG 3200mAh”
Barkuti
Barkuti's picture
59 wrote:
Maybe the "DLG 3200mAh"
Thanks 59. I have downloaded the Cylindrical Li-ion Battery manual found here, no reference of cells higher than 2800mAh capacity. The manual is pretty dated (2016/08/05), though.
For the complainers all I will say is don't buy if you don't like. The false wrap advertising doesn't depreciates the product, it is consequence of the overall li-ion industry to layman consumer fears and the ignorance motivated low vibration of potential buyers.
The unit cost of these cells makes them a nice choice for an affordable battery pack assembly.
snakebite
snakebite's picture
Last seen: 5 days 19 hours ago
if cycle life is good might be ok for large packs with lots of p.
that could offset the crazy high ir.
all laptop pulls i have seen with that high of ir were just plain ol worn out.
Barkuti
Barkuti's picture
The internal resistance of this cell is not “crazy high” snakebite, not because you are accustomed to high or standard discharge cells of first brand manufacturers makes a ≈70mΩ figure bad at all. In fact, some 18650 energy cells from the top four have comparable or even higher numbers. Very few, of course.
Their main problem is improvable consistency. Their main avantage is super affordable price.
Party
Petr J.
Petr J.'s picture
Last seen: 4 weeks 1 day ago
I bought the batteries at Aliexpress. When used in working light with COB LEDs and low current draw, they are good.
