[Interest & Feasibility Check] Sofirn SP10S "BLF edition" with Andúril
675 posts / 0 new
nobody
Last seen: 4 days 23 hours ago
Still interested!
blind-eye
Last seen: 1 week 1 day ago
Still interested as well… Cool
dbare
Last seen: 2 weeks 2 days ago
Interested
Sillen
Sillen's picture
Last seen: 1 day 8 hours ago
I’ll have one
Scallywag
Scallywag's picture
Last seen: 4 hours 26 min ago
MascaratumB,
Boosting the voltage from a NiMh to usable levels for the LED is a bit rough. The NiMh cell will have voltage sag when we ask higher currents of it, so we end up boosting from ~1V up to 3.5-ish or so for the LED. If we wanted to drive the LED at 1A, that's easy for a Li-Ion 14500 cell to do, but from the NiMh cell we're suddenly asking for something like 3.5A from it. The alkaline will already have given up, but quality NiMh will hold up to this for a bit. Just not very long, as that's over 1C discharge, with voltage falling fast. The more the voltage falls, the more current we need to get our power output (because Watts = Volts*Amps).
I used to rebuild NiCd/NiMh tool batteries, and there are some cells out there that I wouldn't mind subjecting to that kind of abuse, but they are all larger than AA size. Eneloops are good, and can discharge surprisingly high drains, but the voltage is too much of an issue.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Tldd
Interested, but I’m concerned about how Anduril will be ported for a boost driver, and of course the associated problems with boosting a NiMH/Alkaline.
I see myself using this light normally on 14500, where I would wish to have a max of ~600 lumens. But in case of emergency, it would be nice to also be able to run off of a AA/NiMH, where I wouldn’t want 600-700 lumens anyway to conserve power. I’d be fine with a max of ~100 lumens, which all chemistries should be able to handle.
Slayer1
Slayer1's picture
Last seen: 9 hours 7 min ago
Interested.
Unheard
Last seen: 34 min 45 sec ago
How did Wuben the magic in its E05? It runs on NiMH the same modes as on 14500, except turbo. Is this a matter of efficiency?
oakheath
sounds good to me, interested for sure
EmptyWallets
Last seen: 2 weeks 4 days ago
Scallywag wrote:
MascaratumB,
Boosting the voltage from a NiMh to usable levels for the LED is a bit rough. The NiMh cell will have voltage sag when we ask higher currents of it, so we end up boosting from ~1V up to 3.5-ish or so for the LED. If we wanted to drive the LED at 1A, that’s easy for a Li-Ion 14500 cell to do, but from the NiMh cell we’re suddenly asking for something like 3.5A from it. The alkaline will already have given up, but quality NiMh will hold up to this for a bit. Just not very long, as that’s over 1C discharge, with voltage falling fast. The more the voltage falls, the more current we need to get our power output (because Watts = Volts*Amps).
I used to rebuild NiCd/NiMh tool batteries, and there are some cells out there that I wouldn’t mind subjecting to that kind of abuse, but they are all larger than AA size. Eneloops are good, and can discharge surprisingly high drains, but the voltage is too much of an issue.
Would it be possible to limit the power of the flashlight when running on NiMh on the basis of max optimal load for that cell chemistry? Unsure if that would be easier or harder
Dioda
Last seen: 1 month 3 days ago
Interested
JasonWW
JasonWW's picture
Last seen: 8 hours 21 min ago
This is mandatory.
hodor
hodor's picture
Last seen: 1 hour 13 min ago
Only just realised I haven’t explicitly expressed my interest. So… interested!
Dutcheee
Last seen: 1 week 11 hours ago
Very interested if the light comes with a lighted switch or dim indicator light (or is easily modded to have one)
Dual chemistry would be great to see!
Rusty4x4
Last seen: 3 days 22 hours ago
Interested if it comes with nimh support and anduril
kase
Interested
2Ace
Last seen: 4 days 3 hours ago
Interested
JackJax
JackJax's picture
Last seen: 10 months 2 days ago
Interested
A_M_K
A_M_K's picture
Last seen: 4 days 21 hours ago
Interested!
madness
madness's picture
Last seen: 4 months 1 week ago
Interested
You can never have too many torches........just not enough darkness
lohtse
lohtse's picture
Last seen: 6 months 23 hours ago
heck I’m in… I am in the market for an AA edc and had just started looking…. My short list was the Utorch, lumintop tool 2 and sofirn sp10s!!!! so this would be great!!! BUT ONLY IF IT CAN RUN ON AA’s too…
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
mk23
Last seen: 2 hours 20 min ago
Interested even if it only work with 14500.
Th558
Th558's picture
Last seen: 1 hour 23 min ago
Interested if it’s aa compatible. Could you somehow make the glass have a built in minus green filter?
sbslider
sbslider's picture
Last seen: 22 hours 12 min ago
interested if it supports alkaline/nimh as well. Not sure why there is a debate about the possibility, the original light does it, as do other lights in this size (Rofis R2). Perhaps adding Anduril and a small board is the challenge? Certainly the lower voltage cells have lower outputs.
Sorry, I only read through 2 or 3 pages of the thread.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
CJ Avlis
Last seen: 1 week 9 hours ago
Interested
firstcipher
Last seen: 1 hour 44 min ago
Interested
mortuus
mortuus's picture
Last seen: 22 min 23 sec ago
Interested, dont have a light with LH351D emitter yet.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Scallywag
Scallywag's picture
Withdrawing my interest. DQG Slim AA is too good, it fills my “nimh/alkaline” support niche.
lohtse
lohtse's picture
Price put me off!!!! same with max lumens on AA
Current lighting
dekozn
Last seen: 2 hours 37 min ago
What s the latest news on this project?
Idiot proofing something only creates improved idiots.
