[Short Review] Olight Seeker 2 Pro - 21700, 3 x XPL, Silicone grip, 3,200 lumens
18 posts / 0 new
rookiedaddy
rookiedaddy's picture
Last seen: 1 day 21 hours ago
after more than 5 months of hiding in the void (Warrior X Desert Tan notwithstanding), Olight has finally come out to play again... they are announcing a few new models for the NRA shows, and this review will be focus on the Seeker 2 Pro, a 21700 battery powered household/outdoor/vehicle flashlight that inherit some design elements they've done with the Olight X9R. (psst, the other 2 are hunting and weapon light...)
The specifications:
What's in the box:
honestly, I would rather they gives us a higher quality holster than the L-Dock. The L-Dock has a set condition for installation, you must make sure the distant of the L-Dock magnetic top is less than 1.2 meter from the nearest USB power source (minimum 1A) because that's the length of the MCC 1A cable. Of course, you could always use a longer (5 meter?) USB extender cable.
The 2 main differentiating factors...
... 3 x XPL (HD?) LED, my sample is less than 6000K CCT and projects a nice pure white beam.
... and the 21700-size battery, the first 21700 size flashlight from Olight.
of course, it's a proprietary dual-polarity design from Olight...
the actual measurement is larger than 21700, I measured diameter of 21.2mm and a length of 75.2mm, so it's essentially a 21750-size battery. Your normal size 21700 may not work in this Seeker 2 Pro due to the length and it needs to have button top (nipple-top to be precise) to make contact. take a look at the top of the battery here...
this is a design from S1R Baton II ORB-16C05-10C battery... officially, this design elements is there to prevent potential shorts... but I think it serves more purpose than that... you need to go back to Olight to get your spare 21700 battery and you cannot charge this proprietary battery in normal cradle charger, none of my Xtar and NiteCore chargers can fit the battery in the cradle... and that brings us to a very sticky point for me about this Seeker 2 Pro, it takes ~5.5 hours to fully charge the battery from empty, 5.5 hours!!! Come-on Olight, you have had 3A rapid charger with R50 Pro LE Docking station, and most of the USB world already moved on to above 2A charging, and yet, in 2019, this is the charging speed we get from Olight engineering team?
Let's take a few more look at the Seeker 2 Pro...
finger-milled grooves, made from some kind of silicone material. pretty grippy.
Indicator lights, the left is for brightness, and the right is for battery status. the Moon and Low mode share the same brightness indicator. useful for initial checking of battery status, and after that, useless unless you change mode or switch OFF and ON again. No other way to activate the indicator except initial Turn-On or switch mode. Due to this, a marketing gimmick at best, unless they gives us a way reactivate the indicator lights.
Below are size comparisons to other lights:
size is very comfortable to hold, especially with the silicone grooves.
and here we have the UI Diagram.
It's the trial and tested, familiar Olight side switch UI.
following is my measured output:
The usual disclaimer: I do not claim the above measured lumens as authoritative nor an indication of over/under-stating the number given by manufacturer. It's calibrated against some known light output (e.g. SureFire, Elzetta, etc.) so take it with a grain of salt and just as a relative reading.
Next comes the runtime:
Pretty good runtime considering most of the runtime spent in the 1,300-ish lumens. That 5000mAh does shines in Seeker 2 Pro.
Zoomming in to the first few minutes:
and you can see it doesn't get the full 2 minutes in 3,200-ish lumens as claimed, but ~1.5 minutes.
Also, repeatedly double-clicking to go to Turbo after step-down will land you between 2,500 to 3,000-ish lumens and not the 3,400-ish lumens we get when the battery is freshly charged...
... and speaking of fully charged battery, the included MCC 1A (pictured above) charging cable is not able to fully charge the included battery to 4.20V but ~4.11-4.15V depending on your multi-meter calibrations. However, using S1R Baton II MCC (the slimmed down Magnetic Charging Cable), I get a light that is fully charged. This testing has been carried out multiple cycles and every time is the same results. So, the MCC cable are NOT the same despite Olight saying otherwise.
The good thing about not fully charging the battery is the battery should (in theory) last longer, unlike Olight's R50 Seeker Pro LE where the initial release of the charging Dock overcharges (actually it trickle charge) the battery as long as you leave the light at the charging Dock (the non-LE version of MCC cable doesn't do this) and break the protection at the battery and renders the cell to read 0V. So if you want to squeeze the last drop of juice you can get, use the S1R Baton II Slimmed MCC charger, else, use the Seeker 2 Pro included MCC 1A cable.
In conclusion
This is a good household and Bag-carry flashlight, I especially like the long runtime in the thousand-ish lumens and pure white tint. Now, is this a flashlight that's worth getting? Well... let's just say that you should watch out for the latest promotion from your favourite Olight retailer and locked in the promotion price if you really need a new toy from Olight.
still changing sig ::
Anthon
Last seen: 12 hours 40 min ago
Thanks for the review!!! I enjoyed reading it
I like the light but I wouldn’t buy it because I don’t want proprietary cells, and 5lm can’t be called moonlight
I don’t know why they release some lights with magnetic charging that works with any cell (m2r, warrior X) and other times they release it with this strange proprietary cells that can’t be charged outside the flashlight
rookiedaddy
Anthon wrote:
…and 5lm can’t be called moonlight
Exactly, I do not know when was moon mode being redefine at 5 lumens because moon mode for me has always been sub-lumen brightness.
maukka
maukka's picture
Last seen: 4 min 47 sec ago
Perfect, a 3535 emitter triple. Easy to get rid of those cw XP-L HDs, or how’s the bezel, usually Olight doesn’t glue them?
zak.wilson
Last seen: 2 hours 54 min ago
I can’t imagine buying this over the Wuben TO50R HC once that’s actually available to purchase somewhere, even at full price. Proprietary batteries are not acceptable in 2019.
Ceilingbounce – flashlight testing and runtime graphs for Android
roma58
roma58's picture
Last seen: 1 month 1 week ago
Thanks for the review. Really detailed.
hasddie293
hasddie293's picture
Last seen: 3 days 21 hours ago
I see new development for flashlight : the led indicator status (wow). New sillicon grip. 21700 is just about perfect if consider size, capacity mah and high discharge current Thumbs Up
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
rookiedaddy
maukka wrote:
Perfect, a 3535 emitter triple. Easy to get rid of those cw XP-L HDs, or how's the bezel, usually Olight doesn't glue them?
You are right. It's not glue, easily unscrew.
zak.wilson wrote:
...Proprietary batteries are not acceptable in 2019.
I wish this were true, but it's a choice manufacturers made in the name of protecting consumers from "inferior" quality cells...
...but I'm secretly agreeing with you...
Thank you for the kind words.
will34
will34's picture
Last seen: 5 days 6 min ago
Thanks for the review! The sustained output looks great. Only pity is the use of proprietary cell, I’d rather not have the magnetic charge function and have it accept regular 21700 cells.
rookiedaddy wrote:
You are right. It’s not glue, easily unscrew.<
So it is possible to do an emitter swap without much work?
rookiedaddy
Thanks for the kind words, but I’m sorry I can’t give you much confirmation in this area as I sucks at modding. We will have to wait for our more experience modder like maukka and/or many others in this forum to chip-in. Innocent
Lexel
Lexel's picture
Last seen: 39 min 21 sec ago
is the bezel press fit or screwed?
get LH351D in there with NW and CRI
oweban
oweban's picture
Last seen: 2 hours 57 min ago
Agreed – wonder if it’s press-fit like the S-series. Throw some dogfarts in there and you’ve got a fantastic flooder. It’s not even showing on the AU store, so can’t even get an idea on how much it’d cost to start trying; not that I really want to open up a ~$200AUD light if it’s out of my pocket ;p
But yes, ouch, 5lm moonlight…
maukka
maukka's picture
Lexel wrote:
is the bezel press fit or screwed? get LH351D in there with NW and CRI
Exactly what I was thinking.
oweban
oweban's picture
Oops, missed that.
Yep, LH351D for ultimate flooder.
grzly
Last seen: 1 month 3 days ago
Thanks for the review Thumbs Up
Does anybody know who makes this optic? I’ve been looking all around for an optic to replace this but can’t find any. It seems to be 26.5mm with a distance between LED centers of 11mm.
I’m trying to do an emitter swap, but on one of my Seekers the head inner diameter seems a little low – it’s all very tight in there and I might not be able to get the white centering helper out of there without damage. As it’s needed to hold the optic in place I’d need a new centering thingy or a different optic entirely.
Any leads would be greatly appreciated Smile
TexasToasted
TexasToasted's picture
Last seen: 9 hours 44 min ago
Just picked up the orange version of this light and wanted to mention that unlike my 16340 and 18650 powered Olights, the magnetic tail on this light is much too weak to be used for anything other than holding the magnetic charger. You won’t be hanging this light on any metal objects for hands-free use.
71k5
Last seen: 52 min 52 sec ago
I have 3 Seeker2 Pro’s(2Blk&1Orange), and 1 blue Seeker2, and a Klarus 21700 button top model 21GT-50 works in all of them. They just won’t charge it.
I have a button top 21700 Samsung 50E, and an Acebeam IMR21700NP-510 coming from Battery Junction.
I’ll let you know how they work in them, as well.
SKV89
Last seen: 1 hour 42 min ago
I bought the Seeker 2 Pro orange version from the BF sale. It is an amazing light. Very well built and beam from the optic is very Olight like. The tint is actually really nice. 5700K is afternoon sun and the tint is slightly rosy making it one of the nicest Olight CW tint I’ve seen. These are the measurements I took with the Texas Ace Lumen Tube calibrated with Maukka lights.
Turbo: 3387 lumens, CCT 5742K, DUV -0.0021, CRI 70.6, R9 -17.2, R12 45.2, Rf 64, Rg 99
High Mode: 1169 lumens, 5518K, DUV 0.0004, CRI 70.6
I also bought the Seeker 2 (non pro) which uses the Osram emitters instead of XP-L HI. The hotspot is smaller and the output is slightly lower at 3060 lumens. However it is a good bit more CW and not as rosy. I didn’t take any photometric measurement before I gifted it but I’m pretty sure tint is about 6500K and DUV is surely positive side. The Seeker 2 Pro tint looks far more pleasing and natural.
