FW3A Troubleshooting / FAQ
1193 posts / 0 new
micknatt
Last seen: 15 hours 33 min ago
When I bought the smaller battery tubes, they came with a couple of white O-rings for each.
mattlward
mattlward's picture
Last seen: 12 hours 37 min ago
I picked up an 18350 tube and it came without one. That was how I broke the first one.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
micknatt
I bought my from Lumintoplighting. Where did you get yours?
mattlward
mattlward's picture
Direct from Neal.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
micknatt
When I bought some deep carry clip from Neal, I thought it was supposed to come with some white O-rings too but it did not. Either I got lucky with Lumintoplighting or Neal just doesn’t put them in the box.
atobe
Last seen: 9 hours 8 min ago
No O-ring with deep clip from neal also. I guess it only comes with the short tubes?
ᕦ(ò_óˇ)ᕤ
JaredM
JaredM's picture
Last seen: 3 days 7 hours ago
Firelight2 wrote:
I wonder if we can get more resistance in the switch by taking off the spring-steel dome on the switch and bending the 3 wings slightly inward.
http://budgetlightforum.com/comment/1580576#comment-1580576
Check out the discussion here if you’re interested in stiffening up the switch actuation.
trailhunter
Last seen: 5 min 17 sec ago
Thanks, ordered them from amazon https://www.amazon.com/gp/aw/d/B000FMWLR8?ref=ppx_pt2_mob_b_prod_image
hank
hank's picture
Last seen: 1 day 20 hours ago
What kind of color is applied to the flashlight?
I’ve noticed the gray color coating is disappearing around the edges of the tailcap and bezel
I wouldn’t mind being able to get the extra hard anodizing, even though I think it only comes in black.
trailhunter
!https://i.imgur.com/sfczJjy_d.jpg?maxwidth=640&shape=thumb&fidelity=medium!
Heads up, these work like a charm, gives a good tactical feel.
StormRider
Last seen: 6 hours 42 min ago
Got my FW3A yesterday from the Amazon sale. I have a few new Sanyo NCR18650GA 3500mAh High Discharge BUTTON Top unprotected cells. After I inserted the cell from the head, the light briefly flashed to indicate contact. However, when I clicked on the e-switch, nothing happens, no light came up, holding down the e-switch doesn’t ramp up to down (no light came out at all).
I emailed Lumintop through Amazon, but haven’t heard back. In the meantime, I just remembered that I have some harvested flattop Samsung 24E unprotected from a laptop battery, so I popped one in, and the FW3A worked like a charm.
I plan to order some higher capacity flat top unprotected LG MJ1 to see if they work. So far, I think unprotected flat top is probably my best bet.
trailhunter
Order yourself a couple Sanyo 30Q’s
JasonWW
JasonWW's picture
Last seen: 1 hour 59 sec ago
Some button top work and some don’t. The heights vary. You could remove the button top if your careful.
Sanyo? That would be Samsung.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
grin
Last seen: 3 days 14 hours ago
I have noticed that the driver shelf has not been cut out completely on a copper version. This puts the driver out of alignment.
JasonWW
JasonWW's picture
That’s normal. The notch on the driver fits there.
grin
Doh that makes sense
BOO5TED
BOO5TED's picture
Last seen: 9 hours 12 min ago
That’s because the FWXX series lights are designed to work on unprotected cells.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
LedTed
LedTed's picture
Last seen: 1 week 4 days ago
I had to buy a large tweezers and tighten all the retaining rings on my FW3X V2s.
A few days ago, the switch started acting up on my FW3A bare. Today, I took apart the switch to find pieces of what appeared to be the flat black rubber spacer; not the nub. The pieces were not from the spacer in the light. I used canned compressed air to clean the circuit board mounted switch. The switch is now back to behaving.
Wish I would have checked the switch before I originally tightened up the associated retaining ring.
Enjoy the light show - LedTed
hank
hank's picture
OK, for the record I will go back and take all the troubleshooting steps recommended.
Here’s why. I’ve been using the FW3A every evening walking the dog in the dark.
Tonight was different.
As usual, started from a low setting and ramped up.
Got one blink then the light went out.
Clicked once and it started again in low, ramped up, and went out
Clicked once, started in low, ramped up, flickered several times and went out
Repeated and again got ramp to flicker to out
Clicked again, started in low, got a normal ramp up and turbo bright
Clicked off, back on low, again normal ramp up and turbo bright
Clicked off, clicked on, no ramp or response to clicks, light went out.
Clicked off, back on low, ramped up and went out
Clicked off, back on low, ramped up and got the voltage report (4 blinks then 1 blink)
I think I have an intermittent, and will go looking for anything suggested (retightening, cleaning).
G’night.
xevious
xevious's picture
Last seen: 6 hours 41 sec ago
G’night.
The only time this has happened to me was when the tail cap was loose. I modified the switch, removing the nubbin & inserting a 5/32” o-ring, to firm up the button. It works great. But for some reason, it’s a little more prone to loosening when I partially unscrew the head for lockout. The symptom is the light going out while ramping up. Tightening the tail cap fixes it every time.
xevious
xevious's picture
Does anyone know if the retaining ring for the tail cap can be purchased separately and if it will work in a 1st release FW3A?
hank
hank's picture
Hm, tailcap on mine did not budge noticeably when I tried clamping down on it, but the intermittent problem seems to have cleared up.
I would gladly buy the revised model tailcap with retaining ring, if they made enough of them to sell them as spares. It seems a weak spot to fix.
shirnask
shirnask's picture
Last seen: 11 min 20 sec ago
Well not always., out of more than a dozen first and second run lights (no not all for me) I had one light that the only way I could get it to work reliably was to remove the retaining ring from the tail cap.
hank
hank's picture
OK, I had crud in the threads somewhere. Screwing the head and tailcap back and forth released some grinding/sticking points, then adding a bit of Nyogel conductive lube to the threads, seems to have eliminated the intermittency problem for now.
I’d still like to get one of the new version tailcaps with retaining ring, if they come available.
hank
hank's picture
Cross-reference: http://budgetlightforum.com/node/70380
FW3A Turns On and Becomes Stuck When Tail and Head Tightened
And here’s another case that sounds exactly like the problem I was having:
https://www.reddit.com/r/flashlight/comments/e3svp6/fixed_fw3a_rebooting...
and that Reddit thread pointed to this one:
http://budgetlightforum.com/comment/1524636#comment-1524636
Firelight2
Firelight2's picture
Last seen: 5 hours 14 min ago
The cell you tried is probably too long. As a result, the light is not firmly closing the circuit on both sides of the inner tube. Try Sony VTC5, VTC5A or VTC6, or Samsun 30q. All should work fine.
Rayoui
Rayoui's picture
Last seen: 2 hours 56 min ago
I also had a similar issue with one of my FW3As. When I disassembled the tailcap I discovered that the “nubbin” was about 1/3 longer than my other FW3Xs. I replaced it with a shorter nubbin (I cut a piece off of a spare o-ring of the correct diameter) and the problem went away. It also made the switch feel very nice and tactile.
Fargus
Last seen: 3 days 21 hours ago
Just received my FW3a. How water proof is it says ipx8 can it be submerged a few feet?
WalkIntoTheLight
Last seen: 28 min 31 sec ago
Yes. IPx8 usually means submerged for 30 minutes up to 2 meters (6 feet) depth. It could be better than that, but I wouldn’t count on it.
Firelight2
If you’re planning to submerge your light, it might not be a bad idea to disassemble it and lubricate the o-rings. It’s probably good enough as-is, but you never know.
