FW3A Troubleshooting / FAQ
1274 posts / 0 new
Helios azimuth
Last seen: 14 hours 24 min ago
Fargus wrote:
Just received my FW3a. How water proof is it says ipx8 can it be submerged a few feet?
Please let us know how it goes. Hope there are no issues.
WalkIntoTheLight
Last seen: 53 min 42 sec ago
Firelight2 wrote:
If you’re planning to submerge your light, it might not be a bad idea to disassemble it and lubricate the o-rings. It’s probably good enough as-is, but you never know.
Good point. Also, greasing the threads generously will help stop water seepage.
RobertB
RobertB's picture
Last seen: 21 hours 45 min ago
I wouldn’t purposely submerge any light that isn’t actually a dive light
hank
hank's picture
Last seen: 42 min 48 sec ago
Oh my gosh, just caught up on Dbsar’s report of the tailcap spring problems.
I hope whoever is managing production of the tailcaps is reading this. I doubt, but I hope.
cabfrank
Last seen: 1 hour 22 min ago
I would definitely not submerge it, but I would think light rain or splashing should be fine.
xevious
xevious's picture
Last seen: 51 min 56 sec ago
Rayoui wrote:
I also had a similar issue with one of my FW3As. When I disassembled the tailcap I discovered that the “nubbin” was about 1/3 longer than my other FW3Xs. I replaced it with a shorter nubbin (I cut a piece off of a spare o-ring of the correct diameter) and the problem went away. It also made the switch feel very nice and tactile.
Strange. Do you mean “thicker”? Or was the nubbin of a larger diameter? Mine was fine, just making for a very sensitive switch. I removed the nubbin, installed a 5/32” o-ring and switch has a nice firmness now.
hank
hank's picture
Cross-reference to the other Lumintop QA thread:
http://budgetlightforum.com/node/68079
Rayoui
Rayoui's picture
Last seen: 7 hours 52 min ago
I generally don’t have an issue with the firmness of the FWxx switch (I always use lockout), but this light in particular had a defect. The diameter of the nubbin was fine, it was just too long. It was physically longer than the nubbins in my other FWxx lights and was pre-loading the switch when the tailcap was tightened down.
I didn’t replace the nubbin with an whole o-ring, I cut a short piece out of the cross-section of a sufficiently thick o-ring to produce a new nubbin which fits in the original location. It’s a tiny bit larger diameter than the original but the rubber stretches to accommodate.
It definitely has made the switch more stable when pressing off-axis and has improved the tactility, even over my other FWs with properly fitted nubbins from the factory. It’s not immediately apparent to me why this would be. Perhaps a combination of the more pliant material and the slightly larger diameter?
xevious
xevious's picture
!{width:45%}https://i.imgur.com/zJFkJqL.jpg!
I was always using lockout because of the switch sensitivity. But now I don’t bother with the 5/32” o-ring. I lock out the light when I put it away. Yep, I got that you cut the o-ring, but didn’t quite get that “long” meant “thick”. This o-ring segment technique is interesting. You can cut a variety of thicknesses to see what works best.
JL-F1
Last seen: 23 hours 34 min ago
My FW3T always starts super dim, moonlight-ish, at first turn on
Even if I ramp it doesn’t remember the ramped value for next turn on, single click
My FW3A is not like this, it remembers the last ramped value.
Everything else works fine.
What am I doing wrong?
Thank you
atobe
Last seen: 9 hours 7 min ago
Does it start there every time? Is it in manual memory mode?
ᕦ(ò_óˇ)ᕤ
wle
wle's picture
Last seen: 18 hours 3 min ago
i didn;t think it had a manual memory [no memory] option..
one comment – it will do this [start on low], if you happen to hold the button down ‘too long’
it is a feature, to be sure you have a way to start on low
but you have to hold the button down maybe half a second
maybe your button is ‘sticky’ so that it thinks you are doing a slow press for start-on-low?
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
JL-F1
Yes, every time.
Not clear on manual memory mode, I don’t see it on the instructions.
The FW3T button does seem not a ‘clicky’ as my Fw3a, which does not have this ‘issue’
riffraff
riffraff's picture
Last seen: 1 day 24 min ago
Manual memory mode on Anduril software is 5 clicks from ON (“5C”). Automatic memory is 5 clicks, but HOLD the last click, from ON (“5H”). See flow chart.
Edit — Oops. Looks like the Anduril version in the FW3As may not have selectable memory mode. Sorry ‘bout that.
JasonWW
JasonWW's picture
Last seen: 2 hours 32 min ago
Was this added on newer versions? My older model does not have this feature.
BTW, I have no clue why it won’t remember it’s level.
Click this to go to signature links.
riffraff
riffraff's picture
My bad. You are correct. Edited above response.
JL-F1
It was manual memory
I did the 5H and boom, now it remembers.
Thanks all.
JasonWW
JasonWW's picture
Thanks all.
Oh, so you didn’t reflash it to a newer version, it came with the newer version?
Gunga
Gunga's picture
Last seen: 21 hours 16 min ago
I’ve found some lights have manual memory. Some don’t. Hard to predict what you will get.
JL-F1
Thanks all.
Correct, I did not reflash, my FW3T came with the firmware with the memory options, from Illumn.
So now I have two lights with different firmware and it’s bugging me Smile
I should have read more and bought both from Illumn instead of rushing into the FW3A purchase from another vendor
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 min 54 sec ago
JL-F1 wrote:
Thanks all.
I have 9 lights with 3 different firmware…. Facepalm
I bought 5 brand new drivers from Lumintop, I used 3 so far… 1 of them has the memory option… so far… the other 2 new drivers are waiting to be used… Big Smile WTF?
KB1428 “Live Life WOT
mortuus
mortuus's picture
Last seen: 2 hours 13 min ago
I wash my copper fw3a sometimes in the sink i let it be there for a while, no problems so far…
...where Frugal meets with Flashlight!
ttylamg
Last seen: 4 hours 58 min ago
What would cause flickering not in candle mode or anything
C8+ (osram mod) - FT03 (pending repair) - Chaselight (hack dedome) - FW3A (W aux TIR) - Sofirn C8T - Emissar D4 (W aux TIR) - Convoy S2+ - Sipik (rip) - Solarforce L2
Several laser pointers
Several pocket knifes
JasonWW
JasonWW's picture
Dirty threads or the ends not tightened enough.
wraithpc
wraithpc's picture
Last seen: 2 days 11 hours ago
Mine flickered, but only on lower settings, same thing on three different bodies, cleaning threads, tightening retaining rings, nothing helped! replaced all 7135s, same thing checked solder joints, did most everything except replacing the mcu. By that time I received a replacement driver which fixed the problem. Definitely exhaust all the possibilities, but in the end you may have similar results.
xevious
xevious's picture
Has anyone here dropped their FW3C and suffered notable dents? Just curious about the copper alloy, as raw copper is inherently soft, prone to denting.
raccoon city
raccoon city's picture
Last seen: 9 hours 25 min ago
My FW3A was acting strange.
After turning it on, I would try to ramp to change the brightness, and the FW3A would turn off!
So I started reading the OP of this thread...
FW3A Team wrote:
If the light acts strange, make sure the driver retaining ring is tight. Also make sure the tailcap is tight — very tight. Loosen the tail a bit, loosen the head, then tighten the tail as much as you can by hand, then tighten the head.
...I followed those directions, and now it works fine.  :THUMBS-UP:
I'm very glad this thread exists.
Thanks for the help!
xevious
xevious's picture
^ Yep, driver retaining ring and the tail cap — both being loose will end up creating strange behavior. I think that’s pretty much it, though. Easy to correct both! Unfortunately, this light is not turning out to be very user friendly, reliability wise. A number of people I know would be stumped by such a problem and put it down in favor of another light.
qandeel
Last seen: 6 hours 29 min ago
How to solve an issue of the FW3A starts to step down automatically almost immediately to a very low brightness level? This happens in both stepped and ramped modes. Many thanks.
 عُمَانْ
JasonWW
JasonWW's picture
Two main reasons, it thinks it’s too hot or the voltage is too low.
If the battery is charged up, then I would calibrate the internal temp sensor.
