Article about dangers of 18650
14 posts / 0 new
arow55
Last seen: 23 hours 40 min ago
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 5 hours ago
Copying and pasting my comment again here:
See, this is why I hate some of these writers.
Rather than blaming Amazon and how shoddy their inventory system is, they blame it on counterfeit cells and people wanting modular battery packs/cells.
IMO, this is why stores like Illumn and LiionWholeSale are so important.
They actually test their cells, unlike the sellers on Amazon.
This is the reason I’m wanting a rule that a seller has to prove/test their cells to make sure they are legit for every batch, which would make it easier and safer for customers to buy cells.
arow55
They said pushing the power density to limit is one problem. I use nimh and have come to prefer ones with less than maximum mah. They have advantages with # of recharges and also safety.
wle
wle's picture
Last seen: 2 hours 15 min ago
The real problem is vapers, mechanicals, overdischarging, and overcurrent. A flashlight isn;t going to have most of those problems.
And we mostly don;t use the highest current draw cells, like, again, the vapers do.
It;s not even ‘mechanicals’ really, but hackers using the ‘mechanicals’ components in a hazardous way.
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Dougiestyle
Dougiestyle's picture
Last seen: 4 days 10 hours ago
Batteries are stored energy, just like a container of gasoline. If mishandled, abused or damaged, either may experience catastrophic results.
M3CSL
M3CSL's picture
good article, interesting read. thanks for posting.
I don’t think flashlights are “as” dangerous but we have to be cautious, obviously. A broken spring bypass could be enough to create havoc.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
BlueSwordM
Yeah.
Any battery/energy source can catch on fire.
wle
wle's picture
M3CSL wrote:
good article, interesting read. thanks for posting. I don’t think flashlights are “as” dangerous but we have to be cautious, obviously. A broken spring bypass could be enough to create havoc.
how would that work?
the spring itself, is already a short
that part of the battery has ( at least the – side ) is not close to the + side to make a short
it (usually) cannot activate the switch or light..
wle
-Greg Lemond.
M3CSL
M3CSL's picture
I was referring to the driver side spring bypass (wire) – which, in theory, could bridge LED+ to BAT- if the wire breaks off and connects to the driver ring or host? Wouldn’t that DD the LED permanently?
This is theoretical, of course. The likelihood of this happening should be very small, but the wires I use are long enough.
wle
wle's picture
seems like it would be more likely to short the battery ..
(though that might also require the wrapping on the can (- side) to be breached somehow – i tend to use them even if they have a little shoulder wear)
whether or not there is a ‘driver ring’ near that wire, is not universal.. right?
i mean it would depend on board design
if there are contacts on that side of the board, like component pins and whatnot, then the loose theoretical bypass wire, could short to any of them
or am i wrong?
a lot of lights do not have springs at the driver end, anyway, just a round pad for + and a ring for -
would the ones with springs, be more likely to expose other circuit points, to that side of the board?
wle
-Greg Lemond.
M3CSL
M3CSL's picture
All lights are different, so there are probably “safer” and “less safe” designs out there. But most of my lights are Convoys and they all come with springs on both sides. My drivers are self-built and have BAT+/LED+ bypasses – so in a theoretical “broken driver side bypass” the LED would be driven directly at 100%, I think. I was wrong since nothing would happen afaik. LED+ against BAT- wouldn’t be DD.
If this BAT+ wire is NOT going to the LED+ but somewhere else on the driver, yes, that could be a short.
On all linear drivers I have seen there was at least the driver retaining ring and/or the driver ring which is equal to BAT- if the switch is ON. (I am sure there are plenty of drivers without a visible ring or some plastic part over it).
All in all – I believe flashlights are much safer than other electronics items with lithium cells? Is that correct to say?
wle
wle's picture
i hope so, i certainly use old and reduced-capacity/oldish cells without worrying…
i mean if the lights have undervoltage cutoff, and you have a modern charger, which will not charge undervoltage cells things should be ok.
i think the only really dangerous things are like i said, the vaping hobbyists that use ‘mechanical’ modifications incompetently
that will probably be outlawed sooner or later
though it really wouldn;t stop someone determined to do – well what is it the mechanicals add, that is so critical, anyway?
wle
-Greg Lemond.
VaKo
Last seen: 2 days 11 hours ago
Good thing about UK laws is the seller is always liable for product faults.
G0OSE
G0OSE's picture
Last seen: 9 hours 37 min ago
Providing they are bought in the UK, though that’s of little help if it blows the side of your face off or leads to a death somehow (fire etc) . No amount of compensation is going to cure those sort of things, though I admit they are extreme cases.
