Fireflies E01
27 posts / 0 new
iosala
Last seen: 5 hours 46 min ago
Fireflies E01
M3CSL
M3CSL's picture
Last seen: 1 month 1 week ago
good looking light!
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
Neal
Neal's picture
Last seen: 10 hours 56 min ago
about available at May 10th
I will also sell it
SKY69
Last seen: 13 hours 50 min ago
I was looking at their website last week and didn’t see this new one. I will definitely order one from Neal when available
JaredM
JaredM's picture
Last seen: 8 hours 14 min ago
Interesting.. pocket clip groove but no clip pictured.
Actually a smart form factor. Nearly identical to the ET TX25C2 which I’ve always regarded as the ideal “turbo” EDC. I just wish Luminus would offer the hi CRI in the sst40. This light probably will just burn straight through sst20s. Too bad..
BlueSwordM
BlueSwordM's picture
Last seen: 37 min 5 sec ago
Yeah.
Even an 90CRI SST-40 4000k would be so good, like the SST-20.
IMO, they would just plow Cree at that point in this segment, since it would be a high CRI 5050 3V emitter.
raccoon city
raccoon city's picture
Last seen: 4 hours 9 min ago
Neal wrote:
about available at May 10th I will also sell it
Neal, I saw your new avatar, and I thought you were Mr. Admin for a second!
Neal's picture
Lu
Last seen: 1 month 4 weeks ago
It says “battery discharge no big than 10A , Or it will cause damage to the emitter.” … I really don’t like that.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 hours 30 min ago
That's the issue with the SST-40 when using an FET driver. koef3 discovered that more than 7.4A may decrease the LEDs lifespan significantly and beyond 9A those bonding wires are subject to burn, causing the ultimate death of the LED.
Scallywag
Scallywag's picture
Last seen: 15 hours 28 min ago
Best argument for using Luxeon V instead Wink Kaidomain even has some in (claimed) 5000K and 6500K, in addition to the 4000K that Led4Power has had for a while.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
BlueSwordM
Why not get the Luxeon V 5000k then?
Would be great.
Lu
I ordered the FT03 with the SST40, it’s also FET drive on turbo, does it mean that I will burn it if the battery is more than 10A? I didn’t see that anywhere in their description, and I also do not own any 26650 that does below 15A at worse… I really would not like to kill the light the first day.
Petroleum Lante...
Petroleum Lantern Guy's picture
Last seen: 2 weeks 20 hours ago
Did you find out whether that is the case? I’m also wondering about it as I have also ordered the FT03, and already have the Astrolux FT03 SST40-W, which uses a Texas Avenger FET Driver.
I’m currently in the process of reevaluating my battery choice on that one.
I love all kinds of lights... storm lanterns, kosmos & matador lamps, gas lanterns, tallow lanterns, flashlights, lasers, tritium vials...
Lu
Not yet, and nobody gave me any insights. I also tried googling but didn’t find anything. I’m wondering why use a FET if the LED has problems with it…
JasonWW
JasonWW's picture
Last seen: 4 hours 21 min ago
Please do not confuse battery ratings for how it will will perform in a light.
They designed the circuit in the FT03 with a little extra resistance to limit the current.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Lu
Thank you for the reply! Of course I do not confuse, the Fireflies E01 is the first light that I know of that can kill the LED if the battery is “too powerfull”, as they say on their official web site.
So if the FT03 does not have that issue, it means simply that the driver of the E01 was not engineered very well.
BlueSwordM
No, it’s that the E01 was engineered too well.
Everything in a Fireflies light is made to have as low resistance as possible.
They should’ve just used a more suited LED for this purpose, like an LH351D 5000k 70CRI.
Lu
I hope there will be more LED choices soon then.
Marc E
Last seen: 2 days 13 hours ago
I received a couple of E01s today and they seem like very nice lights, there are lots of things i like such as the size/shape, beam pattern, switch lights, ramping, but… instead of concentrating on the good things i need to point out that i don’t think they’re actually running Anduril as claimed. Mine are missing most of the blinkies, and muggle mode, and here: http://budgetlightforum.com/comment/1507408#comment-1507408 Blueb8llz explains a problem programming the ramp levels on the E01, while 4 posts later TK explains:
ToyKeeper wrote:
blueb8llz wrote:
Does the fireflies e01 have a new version Andúril? Why am not able to program the maximum brightness as top of ramp? I tried 4 clicks with no response.
Fireflies asked me to make a new UI for the E01. It’s basically a stripped-down version of Anduril. The ramps are not configurable, and most of the blinky modes are gone. It has a police strobe and SOS instead of the Anduril strobes.
I have e-mailed FF asking for clarification.
d_t_a
Last seen: 1 hour 14 min ago
I see, so the FF E01 uses a stripped-down version of Anduril, but it’s a different variant than the RampingIOSv3 of the D4S.
How difficult would it be to re-flash the firmware of the E01? (does it have contact points similar to the D4S)?
Umpi2000
Last seen: 3 min 4 sec ago
Is there a reason I haven’t seen a manufacturer using a Luxeon V in a light like this? It copes with the high current better and has beautiful tint even though it’s not hi cri surely it would have made a reasonable choice for the E01? Or am I totally wrong?
JasonWW
JasonWW's picture
I bet it has something to do with it’s odd 4mm x 4mm foot print. Most leds use either 3.5mm or 5mm. You need a special mcpcb to fit the Luxeon V. If you fit it by hand you might be able to get it on a 3.5mm pad, but it’s tricky. Maybe too tricky for mass production.
Umpi2000
Fair enough, but a manufacturer could surely make the correct mcpcbs or get them in? Oh well.
JasonWW
JasonWW's picture
Flashlight companies (most, not all) just focus on the main parts like the body. Things like reflectors, drivers, switches and mcpcb come from specialty manufacturers. Then the flashlight company assembles the parts.
Right now I only know of one store, LED4POWER, that has had some 4×4 mcpcb made up to sell.
It’s pretty odd there aren’t many factory flashlights with the Luxeon V. Maybe it’s not a cost effective led compared to it’s competition? IDK. We’d probably need to ask a flashlight company to really find out. It might be something as simple they are hard to buy in bulk in China. Or maybe the nice tints are hard to get.
Scallywag
Scallywag's picture
What I'd really like to know is why the SST40 is so popular, when I consider the Luxeon V better in every way excepting the 4040 footprint.
Umpi2000
That’s sort of what i’m asking too Question
Ekstasis
Last seen: 5 days 7 hours ago
Any one have any beamshots or the osram emitter? Trying to get a sense of the throw to flood ratio in the beam. It might be too extreme.. I hope it’s balanced.
