[♛ FreemeGB] FireFlies E01 LUMINUS SST40W N5 5700K 2300lm Andúril 27100/18650 EDC Flashlight - [ ACTIVE ]
194 posts / 0 new
delete
Last seen: 2 days 12 hours ago
Interested
TrueRMS
Last seen: 6 hours 15 min ago
Just realized; why no AUX LED’s? This is Fireflies after all, it’s sort of their thing!
I’m still in, but it’d be a whole lot cooler if it had both forward facing AUX and switch LED’s to match the E07!
Will the switch led’s be fully controllable via FW or will it be like their others where 2 are always on and the other 2 controlled via FW? FF if you’re listening make all 4 switch led’s controlled by the FW please!
freeme
freeme's picture
Last seen: 5 hours 10 min ago
Only SST40 with cool white for initial batch.
gpbeiew wrote:
Interested Will there be a Nichia 219B 4500K version?
freeme
freeme's picture
This is there first entry model with simpler design... Have to sacrifice some functions in order to cut down the price.
TrueRMS wrote:
Just realized; why no AUX LED's? This is Fireflies after all, it's sort of their thing! I'm still in, but it'd be a whole lot cooler if it had both forward facing AUX and switch LED's to match the E07! Will the switch led's be fully controllable via FW or will it be like their others where 2 are always on and the other 2 controlled via FW? FF if you're listening make all 4 switch led's controlled by the FW please!
ZozzV6
ZozzV6's picture
Last seen: 6 hours 51 min ago
Can you ask that if they make them without any bezel or driver glue? They have a hystory about assembling problems so it is better if it is repairable. And also moddable. Big Smile
freeme
freeme's picture
List and links updated.
7pot
Last seen: 2 hours 5 min ago
Interested
koolranch
Last seen: 21 hours 44 min ago
Is the code out for this yet? I did not get a PM.
AlexGT
AlexGT's picture
Last seen: 55 min 23 sec ago
I was assuming it had Aux Leds behind the optic… can we order them as extra cost option?
justicemanvn
Last seen: 1 week 6 hours ago
interested
SKV89
Last seen: 3 hours 21 min ago
The mcpcb is only 20mm, with the solder wires and everything, I dont’ think it would be possible to fit aux leds
Enlightened1
Last seen: 1 hour 34 min ago
Interested. Thanks!
contactcr
Last seen: 28 min 48 sec ago
Plenty of room
http://budgetlightforum.com/comment/1453886#comment-1453886
shirnask
shirnask's picture
Last seen: 2 hours 58 min ago
Interested
freeme
freeme's picture
There is one code available now but is not quite i predicted. If you MUST have the light right now, i can forward to you today.
FF direct sale will be available in a couple of days time.
They need to do some accounting work before that. cool
SKY69
Last seen: 2 hours 31 min ago
I will wait for the direct sale Freeme
Annfirst
Last seen: 17 hours 5 min ago
interested
djypo
Last seen: 15 hours 24 min ago
Interested
mxyzptlk
mxyzptlk's picture
Last seen: 10 hours 36 min ago
Interested
vit55
Last seen: 3 days 10 hours ago
I’am in for 1 interested thanks
Nickke
Last seen: 1 week 4 days ago
Interested!
DunchBlaster
Last seen: 1 week 2 days ago
Interested!
AnhTran
Last seen: 5 hours 28 min ago
So Fireflies recommends to use
“battery discharge no big than 10A , Or it will cause damage to the emitter”
So using lower rated current batteries to protect the emitter, but wouldn’t this be dangerous for the batteries because it might run at maximum rated continuous current?
scottb7862
Last seen: 3 hours 33 min ago
interested..
ridepacker
Last seen: 6 days 8 hours ago
interested
Nite Shadow
Nite Shadow's picture
Last seen: 23 min 52 sec ago
NOT INTERESTED anymore, at least for now, with any FREEME GB’s since 2 other FREEME GB’s were just recently “ENDED” and the entire content of the first long detailed interest OP’s were just completely wiped out! Bad form. Just add “THREAD CLOSED” to the end of the existing subject title and PM the admin to close the thread to new posts.
TrueRMS
No, the higher iR of the cells will prevent them from running at unsafe currents.
Its a legit way to limit a lights potential, lots of us around here do it. I run 35E’s in most of my lights for normal use then stick a 30Q or P26A in it for max output. It’s not like if a light draws 15A on a P26A it will still try to draw that from a 35E, the 35E (a 10A rated cell) will usually do about 7-9A in the same light because of its iR.
Nicko69
Last seen: 25 min 56 sec ago
Interested
caplang
Last seen: 1 week 13 hours ago
No code yet?
Th558
Last seen: 6 hours 21 min ago
I like the design and size but I would’ve preferred 3x sst40
