FW3A Useful Information.....
85 posts / 0 new
MonkeyLight
MonkeyLight's picture
Last seen: 3 weeks 4 days ago
Thanks Teacher and all other contributors.
Just thinking
How to remove driver with pill and Led MCPCBs after unscrewing the driver retaining ring to be swapped with another FW3A/B/T?
I guess it is just by pushing the driver/pill/led MCPCP from head to tail direction or not that simple ?
likevvii
Last seen: 2 hours 11 min ago
I want to purchase a few extra FW3A drivers because I mod and break things often. I have FW3A comming soon in the mail so I am unfamiliar with how it works.
I am unable to find where to purchase the drivers directly.
Also, are there other drivers that are compatible? The drivers I have are only the click ON/OFF tail switches.
I dont know what type of switch the FW3A uses. Is it always connected with momentary clicking, or direct ON/OFF, or something else entirely.
contactcr
Last seen: 2 hours 56 min ago
You would have to go to Neal or Lumintop directly for this. The driver is eswitch (“direct on/off” = mechanical switch) and an unusual size and placement of the eswitch area since it is not connected via a wire like most eswitch drivers.
DavidEF
DavidEF's picture
Last seen: 3 days 6 hours ago
xevious wrote:
Ah, for the days when such lights connected by USB would allow for programmatic access, and a backup of settings. This way if the config ever got screwed up, you reset and simply reload your backup. Thumbs Up
Wait, doesn’t FW3A Andúril already have a ‘factory reset’ option? I know a lot of Narsil lights have that. I don’t own a FW3A, so I can’t test.
- The YKK Philosophy
WalkIntoTheLight
Last seen: 3 months 4 weeks ago
I believe it does now, but the original FW3A’s don’t have it. I’m not sure if the ones shipping now have the updated firmware with the reset function. Probably, but get confirmation before ordering if it’s important to you.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 2 min ago
BabyDoc wrote:
when I received mine, there was a slip inside the box saying illumn.com had already calibrated the sensor. In the process,I am sure they would have picked up and corrected any problems before shipping out the light. Mine was perfect.
Yes, Illumn has been checking and calibrating each light. This is an awesome and helpful thing for them to do, but it’d be really nice if the factory would do it instead.
In any case, that makes Illumn the best place to buy from, if you’re in their shipping area.
goshdogit
goshdogit's picture
Last seen: 5 hours 17 min ago
Not that simple. Smile
There is a ‘shelf’ between the driver and LED MCPCB. This light is not a ‘pill’ design.
Remove bezel, lens, and optic from head.
Unsolder red and black wires from LED MCPCB.
Remove LED MCPCB.
If you are swapping just the LEDs, you can leave the driver in place. Otherwise, remove driver ring and remove driver.
Clean the old thermal compound from the shelf and the MCPCB. Use a small amount of new thermal compound.
Be careful not to twist the red and black wires when reinstalling the optic/lens/bezel.
Here is a photo from CRX’s FW3A Mods & Teardown thread:
freq
Last seen: 3 weeks 5 days ago
ToyKeeper wrote:
… Yes, Illumn has been checking and calibrating each light. This is an awesome and helpful thing for them to do… In any case, that makes Illumn the best place to buy from, if you’re in their shipping area.
and thank you for that heads up… most helpful regarding this noob’s purchasing decision…
Paladin007
Thank you for great info. Is anyone able to help which emitters should I pick. What are the pro and cons between XP-L HI 3D , SST 20, Nichia 219c for this beast?
Would like to have high lumen, high cri (will this matter?), good flood with enough throw, and keep it low temperature. But I know I cannot have it all.
I don’t have any experience other than XP-G2 S3 with my Mecarmy SGN5.
What is the good balance for overall EDC around the house and night street walk?
Man Without Shadow
Man Without Shadow's picture
Last seen: 7 hours 15 min ago
I sure do like the xp-l HI 3d’s…brightest of the bunch, “least” heat…
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
cabfrank
Last seen: 1 hour 59 min ago
The XPL 3D is not high CRI, but to me, it is the best emitter for this light.
xevious
xevious's picture
Last seen: 4 hours 36 min ago
Yes, it’s more neutral white, but a very “clean” tint without being clinical. I find it very powerful and considering the turbo output plus form factor, it performs very well.
BabyDoc
BabyDoc's picture
Last seen: 6 days 9 hours ago
I suspect that illumn.com is NOT calibrating the copper version which is vacumn sealed to prevent tarnishing. (There was someone in another thread reporting an electrical contact problem with their new copper FW3 they purchased from illumn. com. Had illumn calibrated that light, I am sure that they would have noticed the problem and fixed it.) But if you are ordering the FW3A, illumn.com is the place to go in the USA. Perhaps, even with the copper version, you should go there, because their custumer service is great should you ever have a problem.
freq
ok… thank you for that referral as well, BabyDoc…
scosgt
Last seen: 4 days 5 hours ago
I agree . I was the one with the problem, and it got resolved in a couple of hours.
They are in the USA and ship quickly.
I am certain the copper is not calibrated by them because it is indeed vacuum sealed.
In fact, the clip corroded the copper a bit on the tube. I cleaned it up with a salt/vinegar combo, and a little toothpaste!
I have not calibrated the heat, but it gets so hot so fast you can not keep it above 800 lumens for more than a few seconds.
MonkeyLight
Remove LED MCPCB.
Thank you very much for the helpfull info and instructions.
Exactly the advice I was looking for without trying pushing it first and damage the LED MCPCB and the driver in the process.
Much appreciated :-)MonkeyLight
CalvinIS
CalvinIS's picture
scosgt wrote:
I agree . I was the one with the problem, and it got resolved in a couple of hours. They are in the USA and ship quickly. I am certain the copper is not calibrated by them because it is indeed vacuum sealed. In fact, the clip corroded the copper a bit on the tube. I cleaned it up with a salt/vinegar combo, and a little toothpaste! I have not calibrated the heat, but it gets so hot so fast you can not keep it above 800 lumens for more than a few seconds.
That's correct, we are NOT calibrating copper models to preserve the seal on the light. There should have been a note in each box saying so.
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
Chinaheart
Chinaheart's picture
Last seen: 20 hours 9 min ago
hank
hank's picture
Last seen: 6 hours 15 min ago
Calvin, can we tell by our order date/order number which version of Anduil is installed on a flashligh?
hank
hank's picture
No answer to that question. Oh well.
Here’s a lanyard ring:
https://jc-customflashlights.com/collections/accessories/products/fw3a-f...
wle
wle's picture
Last seen: 9 hours 43 min ago
you can do that with rope
google ‘constrictor knot’
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
xevious
xevious's picture
Do you know of any good sites or videos for showing some excellent lanyard making?
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 15 hours 51 min ago
You can look at toykeepers changelog and test what added feature is in your light.
ahirshy
Last seen: 9 min 36 sec ago
Hank - USLight coincidentally started a thread asking the exact same question on the same day you did.
Assume you came across this already by now, but just in case you didn't here is a link for completeness in this Useful Information.
Summary:
anonymous_user wrote:
If your Andruil is new enough to have the version check, then you can access it by doing 15 clicks from off. It will blink the version number in the format YYYY MM DD.
https://www.youtube.com/watch?v=mrAM7HylEA8
Noir wrote:
For older Andúril versions that don't have the version check function yet, it's possible to determine the version with the help of the features it has.
Here is a very helpful post made by d_t_a which lists features and the firmware dates when they were introduced
Lumintop currently seems to be shipping lights with 2019-06-27 firmware, the FWxx lights that I bought in the last three months all came with that version (i.e. with reset function, but without version check function). I have had older lights, like my FW3C, that came with 2019-05-22 firmware, and of course the very first FW3A lights came with an even older firmware (without 2-level lockout).
d_t_a wrote:
atobe wrote:
It was added to Anduril after (Oct, 2019), FW3A was released in summer 2019 time frame I think. I don't think lumintop is doing new firmware on current productions either. So they should all have the same firmware.
I've tested FW3A with different Anduril versions -- I can't be too sure which exact Anduril firmware, but they are by trying out Anduril functions that were added.
Eg. my first FW3A doesn't have the manual/automatic memory toggle (I believe this is the 2019-05-22 firmware).
Next FW3A has manual/automatic memory toggle (so it's newer), but doesn't have the "factory reset" function.
The latest FW3A I ordered now has the "factory reset" function (via 13 clicks-hold), but doesn't have "firmware version check" function).
So it looks like Lumintop does install new firmware when it's available (as Toykeeper mentioned when I asked her). (Installed Anduril version may not always be the very very latest available firmware, but at least they do update it regularly)...
