FW3A mod thread. Post yours!
1241 posts / 0 new
contactcr
Last seen: 5 hours 34 min ago
Dragon driver is for mechanical switch too right?
treellama
Last seen: 5 hours 49 min ago
TrueRMS wrote:
treellama wrote:
contactcr wrote:
Since he is not sharing his code changes you are out of luck unless someone else knows how or you pay him.
He’s only required to share the changes with people who buy his light. Has someone who bought a custom light asked for the firmware source code?
I may be wrong, I’m not a open source license expert but I don’t believe that’s correct. I’m under the impression the moment he uses open source code for commercial reasons he must publicly release the code. It’s a share alike license.
It’s GPLv3, not share-alike. Here are a couple relevant FAQs:
https://www.gnu.org/licenses/gpl-faq.en.html#GPLRequireSourcePostedPublic
https://www.gnu.org/licenses/gpl-faq.en.html#CanIDemandACopy
Now, it gets more complicated if he’s complying by providing source through a written offer. You can read the other FAQs there, but I’m giving him the benefit of the doubt that he’s providing source code along with his lights.
f0xx
f0xx's picture
Last seen: 5 hours 24 min ago
That’s a good point, he might be providing the source code with his lights. Something something “innocent until proven guilty” comes to mind.
xevious
xevious's picture
Last seen: 2 hours 21 min ago
Well, all this talk about forcing the FW3A to take on aux LED’s… and I just got my GITD insert. Standard Green. VERY bright! I couldn’t get over how strong it is for the first 5 mins. Can even use as a moonlight mode. The GITD insert hangs on for a very long time as it wanes. Great step up from GITD tape on the inside wall. Still thinking I may give tritium vials a try. Drill in some grooves across the GITD insert. The way it fits under the optic, there’s quite a bit of clearance so you wouldn’t need to drill deep enough to submerge the entire vial thickness.
TrueRMS
Last seen: 1 month 1 week ago
Lexel board with green and pink led's, LDO and voltage monitor removed, 2kohm resistor.
High is still a bit bright but low is perfect and an added bonus is how it flashes one time low then the next high and so on (Idk if this is by design or not but it's cool as hell!)
MikeMacD
Last seen: 3 weeks 18 hours ago
Finally fixed my FW3A driver and added my Lexel Aux Board. I needed to replace the ATtiny85 chip after an unsuccessful flash. Thanks contactcr for the assistance! I was able to flash the chip by itself and then re-flow it onto the driver.
The Blue/Green one is on all the time
The “Fire” one can be on, off, or blinking.
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 42 min ago
Shrunk the FW3A battery tube (FW3A18350)
and I need to make it even shorter… Crying
KB1428 “Live Life WOT
Agro
Agro's picture
Last seen: 1 min 38 sec ago
KawiBoy1428 wrote:
Shrunk the FW3A battery tube (FW3A18350) and I need to make it even shorter… Crying !{width:100%}https://i.postimg.cc/m2NQmZYk/IMG-0930.jpg!
Wow. I dreamed about 18350 FW3A…
xevious
xevious's picture
Much like the Astrolux S43 has 18350 and 18650 tubes, I would also like to have an 18350 tube for the FW3A. Sometimes that little extra savings in length can make a nice difference. It’s a HUGE difference on the S43.
dragunbayne
Last seen: 1 month 3 days ago
Can you get 18350s with decent capacity?
Agro
Agro's picture
There are real 1100-1150 mAh cells from multiple rewrappers.
dragunbayne
That’s not bad. I probably wouldn’t mind a shorty tube.
DarkShot
DarkShot's picture
Last seen: 15 hours 51 min ago
While not short enough for an 18350 you might be able to fit in a 18500.
Looks great!
KawiBoy1428
Looks great!
Yep 18500 fit…… now the 18350 fits with a longer tail cap spring or stretch the stock spring.. small as I could go with out getting into the taper of the body..
Agro
Agro's picture
Maybe you could shorten the tailcap a bit?
KawiBoy1428
KawiBoy1428
No, it works fine with a longer BlueSword spring…2025lm is enough in this little guy.. Big Smile
I thought about cutting into the taper…making it shorter but the same diameter as the straight shank of the stock body… then a sharper angle…re-taper to blend it, but then it would be bare aluminum and I would have to blast and polish it and use it on one of my 2 bare aluminum FW3’s.. I wanted to see how it looked as a stock color… maybe on the next one..
cabfrank
Last seen: 5 hours 50 min ago
Obsess much, KB? Smile
Umpi2000
Last seen: 4 hours 24 min ago
Man that 18350 tube/light looks great! I want one!
Agro
Agro's picture
Making contact is one thing, shortening the light as much as possible is another. Wink IMHO you have the most awesome FW3A on the planet already but maybe it’s possible to improve it still? Smile
Maybe you could alternatively reduce taper depth?
KawiBoy1428
Only with options… got to have a plan “B” maybe even a plan “C”
KawiBoy1428
That would of been plan “B”…If I would of screwed up…….
daffyh67
Last seen: 1 week 1 day ago
I got a copper FW3C with working secodaries from JC,plus i have the normal CW version
The aux LED do ramp up/down, when put alongside my CW FW3 there isnt a lot of difference lumen wise but the tint is different due to LED swap
contactcr
daffyh67 wrote:
I got a copper FW3C with working secodaries from JC,plus i have the normal CW version The aux LED do ramp up/down, when put alongside my CW FW3 there isnt a lot of difference lumen wise but the tint is different due to LED swap
You should ask for the firmware source code and see if he is willing to give it to you.
Umpi2000
KB why don’t you do a GB with 18350 tubes? Wink
KawiBoy1428
I sent pic’s to NEAL..
MascaratumB
MascaratumB's picture
Last seen: 8 min 10 sec ago
And now we pray for them to listen our wishes Party Innocent
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Umpi2000
Awesome I’ll hold thumbs
DoubleU
Last seen: 4 months 4 days ago
BOO5TED wrote:
So, deep carry pocket clips. Anyone make them?
I’m not aware of any production clips. I’d be interested if anyone else knows of one.
I designed a clip and had it cut by a local waterjet company – unfortunately, I used the wrong material, it isn’t stiff enough. I’m not extremely happy with the shape either. I might remake one using stainless steel or a higher grade of titanium.
I have been using the clip from my Emisar D4 until I design a new version
dragunbayne
I’d love an 18350 tube.
@doubleu That clip looks pretty good!
