FW3A mod thread. Post yours!
1259 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 3 hours 49 min ago
Umpi2000 wrote:
KB the new beam profile is definitely better after your work, I may need to pick your brain So I can do this mod too
Agreed. The new quad beam profile looks better after working on it.
I’m not sure making this light a quad is any better than keeping it a triple though.
xevious
xevious's picture
Last seen: 2 days 18 hours ago
ToyKeeper wrote:
JaredM wrote:
I was thinking about bezel up carry and how to mod/make a clip work for this.
I’m curious. What is the appeal of bezel-up carry on a FW3A?
One thing I like about bezel up is that the light can be cap brim mounted for use as a headlamp. Smile
JaredM
JaredM's picture
Last seen: 13 sec ago
Good point. I don’t wear caps, but for those that do Thumbs Up
I’ve always preferred bezel down carry, and actually never have used a bezel-up clip. But with the FW3A’s lack of a deep carry clip plus the sensitive, lightly recessed, and large switch often results in accidental activation (without my knowledge mostly). Lockout works, but 5 clicks to turn on the light all the time hasn’t won me over yet. I either always forget to lock it out or when I do then I’m surprised that it isn’t turning on.That’s not to say I’m unhappy with it, as I’m still adapting to the UI and ergonomics.
My thoughts on bezel-up here is that I think the switch might actually be safer from accidental activation inside my pocket (definitely debatable) and if/when it does happen, I can see that it happened quickly. Ergo is a wash for me, either way is fine. Downsides (pun?) are the your lens/optic is exposed and that the direction of the body taper would be reversed relative to the clip.
In short, I’m curious Smile
cabfrank
Last seen: 8 hours 48 min ago
This for me too. It works great for grilling out in the evening.
djozz
djozz's picture
Last seen: 8 hours 21 min ago
I found that the muggle mode makes the FW3A very safe in my pocket, if activated accidentally, it never gets hot. And the brightness range is adequate for 95% of my EDC-needs.
djozz
djozz's picture
TK wrote:
I haven’t tried a SST-20 FA3 yet though. I might like that one.
I think that you do not like it because it is still a very clean white with nothing rosy in it. It is not green by itself but looks “green” next to the high CRI 4000K 219B, and even next to a (70CRI) 4000K Luxeon V.
JaredM
JaredM's picture
I always have the memorized mode set to the first flash in the ramp sequence, so it doesn’t get hot if it does turn on. That’s good for obvious reasons, but at the same time bad since it can drain a cell for hours before I notice.
djozz
djozz's picture
Yep, that is the downside. The FW3A draws about 600mA in maximum muggle, so if stuck in max it drains a 3000mAh cell in 5 hours.
Ryzbor
Ryzbor's picture
Last seen: 9 hours 54 sec ago
Tally-ho wrote:
You could also wait for Clemence’s triple for Nichia E21A LED that will show up in his store one day. Both will need an FW3A firmware modification to not burn LEDs.
Has he stated he’ll be making one for 100%? And wasn’t it supposed to be 21mm instead of 20mm? I’d love to see E21A’s in this light.
Has anyone measured the current draw with the 219 50% fet firmware Toykeeper made? Three E21A’s could handle around 6A max.
This will also happen with d240 4000K Nichia E21A’s.
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K to be modded with FA3 SST20, super rosy 3000K E21A Tiara and super warm 2000K Wizard Pro on it's way
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 26 min ago
Yep that too, I have a cute little Quark 123 that I modded that fits the “bill” perfectly.
. But also way back in the beginning of the FW3A thread, I asked if the clip could be bezel up mounted also, somebody said it couldn’t be done, the way the light was designed, I never forgot that…. Big Smile
KB1428 “Live Life WOT
KawiBoy1428
It’s not, hard to beat the stock light, it was something to do, thats all. I’ll probably have 5 of these FW3A’s when all is said and done, this one will be different then the rest.
KawiBoy1428
OK, fitting the optic and fitting the optic to the light engine were the most time consuming task’s.
KawiBoy1428
…..BBQ by Candle or Lightening storm… Thumbs Up
djozz
djozz's picture
Improved the grip and the looks of my FW3A with a piece of bicycle inner tire (narrow racing bicycle type).
PBWilson
Last seen: 1 hour 10 min ago
Nice!
Bike inner tubes are really helpful items. They can be used as large rubber bands and even firestarters (gross smoke, but it works). I’ve used an inner tube to clamp some laminates of wood for a project where clamps wouldn’t be practical.
cabfrank
Great idea, KB. I miss the summer storms of the Midwest anyway. I will probably look crazy, but I will give it a try.
christoph
Last seen: 11 hours 28 min ago
How hard is it to replace the optic? Do I have to keep the optic and lens still so as not twist off the wires? If so how is the best way to do that with a piece of tape?
Chris
djozz
djozz's picture
I replaced the leds so I had the optic (and board) off, and did not worry about twisting the ledwires because they come through the middle hole and seemed long enough to allow one or two extra twists around each other. Everything went well.
CRX
CRX's picture
Last seen: 4 hours 7 min ago
Detailed thread in the link.
JaredM
JaredM's picture
Nice work CRX. Good idea on the signal/inner body tube wrapping and lining. I’ve been using cells that have an extra clear layer of heat-shrink to take the rattle out of the batteries. The less the battery contacts scrub the better..
CRX
CRX's picture
Yeah I really don’t like battery rattle so usually line the battery tubes with thin sticky back felt if there is space or use the CF wrap if it’s a bit tighter.
CRX
CRX's picture
My optic was stuck in quite firmly by the legs, was a bugger to get out as it pulled up the MCPCB with it so be careful with that.
Firelight2
Replacing the optic in the FW3A isn’t hard. Simply unscrew and remove the bezel. The lens comes with it. The optic is then revealed on top of the star.
The only difficult part is that the top edge of the optic lines up with the top of the head. You’ll need a tool of some kind to reach under the edge of the optic to lever it up. I use a tool that looks similar to a dental pick for this. Just lever it up and work your way around the edges. The optic should come right out.
CRX
CRX's picture
This is true, they usually fall right out but what I’m saying is my one was fairly well stuck into the MCPCB.
Just be wary of that as it will not be the only one like that.
I have changed a few in my time Innocent
teacher
teacher's picture
Yeah, mine was stuck pretty good too… it did not come out easy. But it did come out…. with no broken legs to boot. Wink
CRX
CRX's picture
I actually had to hold down the MCPCB with a toothpick and pry off the optic, never had one that stuck before.
Lagittaja
Lagittaja's picture
Last seen: 2 weeks 4 days ago
The Carclo triple in my Jaxman E2L was stuck so hard that I had to resort to pliers. Believe it or not I didn’t break the optic.. So yeah, these things can be hard to remove.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 34 min ago
One of mine wanted to stick, and I think it was caused by flux in places where it’s not supposed to be. So it may be a good idea to clean the MCPCB if you open it up… or at least check to see if it’s clean.
CRX
CRX's picture
Yeah I want to check the head out anyway, possibly fit a Noctigon as these MCPCBs look a little rough.
G0OSE
G0OSE's picture
Last seen: 6 hours 8 min ago
Just found these on ebay – may be of use, just sticks right on! Comes in a variety of colours too LINK
