What charger would you recommend for my needs?
45 posts / 0 new
molitar
Last seen: 2 days 10 hours ago
Features I am focusing on is ability to test the mAh of the battery to determine life and the internal resistance.
1. Test battery life
2. Test battery charge
3. Test mAh of battery
4. Ability to support large cell like 21700 is a plus
5. Capability of LifePo is a plus
Prefer to stick around $50 or so. I actually looked at the more expensive MC3000 but that is way over kill for my needs. I need one that will support most versions of batteries as I am not one that can afford to buy multiple battery chargers so it has to be the best for what I can afford at this time that will last me a while.
Edited by: molitar on 05/08/2019 - 22:44
Virisenox_
Virisenox_'s picture
Last seen: 6 hours 21 min ago
Opus BT-C3100
It reads voltage and tests capacity and internal resistance. I don’t think it’ll fit 21700s though, and I don’t know if it can capacity test LiFePO4.
Reviewer for ThorFire, Olight, Sofirn, and others.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
Macka17
Last seen: 18 hours 35 min ago
I have several. Xtar VC2/VC4 In home.
Travelling.
LiitoKala Lii 202 2 cell.
It does ALL incl 20700 and Li-Po.
All Cheap .ALL never missed a beat, over 1 yr and several yrs of Regular usage.
I have over 30 Battery’s.
Chinese NAMED mfg. IS mainly, reliable Nowadays I find.
They don’t test. But read internal capacity. total voltage and Auto voltage charge level giving trip out voltage too.
I never bother about anything else. Just use battery till it reduces capacity.
Then dump and use another one.
I ALWAYS carry a spare for each torch when going out
for any time. It’s both easier and gives peace of mind.
If the weight of a couple of these battery’s give you a problem.
I reckon somebody got a problem.
Mishanchik
Mishanchik's picture
Last seen: 39 min 45 sec ago
SkyRC MC3000 or Miboxer C2-4000 ( 2 cell charger )
will34
will34's picture
Last seen: 5 hours 35 min ago
SkyRC MC3000 +1
20700 and 21700 fits nicely. Very accurate mAh reading vs opus chargers.
molitar
I thought of the MC3000 but from what I read their is not really a working just put battery in and let it charge option. My mother who I support that lives with me probably would not be able to just plug in AA or AAA batteries and have them charge with no effort. I love complex stuff as I am into computers big time and have setup my own HTPC using a Logitech Harmony Remote but for a charger I need to consider that my mother can just insert and it charges for her.
RelakS
Last seen: 2 min 28 sec ago
will34 wrote:
SkyRC MC3000 +1
Even the protected ones?
I can’t imagine, how even the unprotected fits, as not all the pins can be moved to the end of the charger. At least on my MC3000.
fmc1
Last seen: 1 week 5 days ago
I would not rule out an MC3000 because you are worried about a non tech person using it. Just assign the charge programs for the batteries they are going to charge to one of the short cut keys. Then it becomes a two key press operation to charge the batteries. The current firmware allows for 8 short cut key assignments. I made up a cheat sheet for my wife and she uses the chargers all the time. I think by now she has the key press sequence memorized. I set them up to be up+1 is AAA white, up+2 is AA white and up+3 is AA black. Also unprotected 21700’s fit fine. I don’t own any protected 21700, however for sure I would not count on them fitting.
Frank
molitar
Frank
Is there a good video or review that explains the MC3000? I checked out Youtube but all useless they mention Modes: Dummy; Simple; Advanced but do not explain what any of these modes are. I keep seeing mention of a cheat cheat but I don’t even understand why a cheat sheet is needed just how complex is this unit?
RelakS
The user guide has its flaws also. I will have take notes when to click, when to press (long click) a button …
In short:
Dummy mode: only NiMH and LiIon. You can set up in the settings the charging properties, after that you show in the batteries, and it will charge them.
Simple and Advanced: you can create programs to charge the batteries: chemistry, charging/discharging current, etc. Simple means you can change less settings. In this mode, you put in your batteries, select the program you like per channel, and press start to charge.
The difficult part is to find the settings for the programs you need. After you set up the programs, it is almost dead simple to use it.
molitar
RelakS wrote:
The user guide has its flaws also. I will have take notes when to click, when to press (long click) a button … In short: Dummy mode: only NiMH and LiIon. You can set up in the settings the charging properties, after that you show in the batteries, and it will charge them. Simple and Advanced: you can create programs to charge the batteries: chemistry, charging/discharging current, etc. Simple means you can change less settings. In this mode, you put in your batteries, select the program you like per channel, and press start to charge. The difficult part is to find the settings for the programs you need. After you set up the programs, it is almost dead simple to use it.
Wow.. if they have BT capability why don’t they have a config dump and just have default configs users can download that support all types? Seems they are wasting the capabilities of this unit.
RelakS
Stop … right … there Sad
The BT is a joke. You just get an animation, instead of a visualisation how much you battery charged. Let alone, that sometimes you can’t even connect to the charger.
Maybe, I will take a closer look on that app, but it is not the best. Same for the windows program. I use the DataExplorer instead, to monitor, what happens in the charger.
This is a very capable charger, but the user interface in the charger, through BT or usb is a joke sometimes.
molitar
Ok MC3000 is out my mother is 82 years old and to press more then one button to start charging is too much.. Especially if it’s so expensive and they have not improved on the UI or set default battery charging.
So focusing on the main 3 of my requirements the others were just a plus and not absolutely necessary.
LiitoKala Lii-500
Miboxer C8 or C4-12
Opus BT – C3100 V2.2
Xtar Dragon VP4 Plus
These are all chargers I can purchase in US either from BangGood or Amazon. I want to purchase from US either Amazon or a site that uses Paypal for payment. So if the MC3000 or Dragon did not exist what charger would you order that has the most of the features for the money?
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 25 min ago
From the US?
As I’ve said before, the Folomov A4:
https://www.illumn.com/folomov-a4-intelligent-rapid-charger-li-ion-lifep...
Or the C4-12:
https://www.amazon.com/Universal-Battery-Charger-Miboxer-Rechargeable/dp...
Both are great chargers, and if the MC3000 weren’t available, I’d go with either of them, and probably the A4, since it has a more intuitive multi-button UI and support for LiFePO4.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
Mishanchik
LiitoKala Lii-500
Miboxer C8 or C4-12
From your list of interesting:
1. “Upgrade” Miboxer C4-12 with Li 4.35 and LiFePO4 ( The old version has a bunch of children’s sores with charging slots and springs )
2. Miboxer C8
3. Xtar Dragon VP4 Plus
molitar
LiitoKala Lii-500
Miboxer C8 or C4-12
2. Miboxer C8
Ok will order the Miboxer C4-12 then. Thanks for the advice.
Mishanchik
Buy only new version – “Upgrade C4-12” with two yellow button!!!
Old version have frequent problem with springs, dying third slot, not support: 21700 protected, LiFePO4, Li 4.35
molitar
Ok got it. BTW what is the difference in the C4 v3 and the C4-12 they both look exactly the same. Are they the same but maybe just a different numbering for Amazon as on Amazon I only find the C4 v3.
Thanks
Mishanchik
https://ru.aliexpress.com/item/Miboxer-C4S-C4-C4-12-C8-Smart/32911743024...
This is the only place where I found a new “Upgrade C4-12”
dekozn
Last seen: 1 week 13 hours ago
Get a analyzing charger for yourself and a cheap trustable charger for your mother. I hardly use my opus cause it’s a big noisy block, I replaced it with gryfalcon 88 for just charging my cells. Even though the gryfalcon has 8bays as opposed to 4 it still looks smaller and makes a lot let noise then my opus. A Littokala can be bought pretty cheap depending on the amount of bays.
RobertB
RobertB's picture
Last seen: 11 hours 25 min ago
Virisenox_ wrote:
“Opus BT-C3100’:https://www.banggood.com/Opus-BT-C3100-V2_2-4Slots-LCD-Display-Smart-Int...
The Opus BT-C3100 fits unprotected 21700’s just fine
RobertB
RobertB's picture
BlueSwordM wrote:
From the US?
Or the C4-12:
Neither one of those is an analyzing charger
flydiver
Last seen: 9 hours 37 min ago
You* REALLY* do want an analyzing charger. If you don’t now, you WILL later, I guarantee it.
There is no ‘perfect’ charger. Decide what is important, pick a charger and go on.
molitar
What is the difference in an Analyzing charger? I thought they all did the same the C4-12 and Opus BT. But if that is not the case the only one that I see that qualifies in my price range, found in US would be the Opus BT-3100 V2.2 as I can get that on Amazon.
Pete7874
Pete7874's picture
Last seen: 2 hours 59 min ago
Analyzing charger can more accurately measure cell capacity
by using a discharge test.
Opus 3100 can do that. Miboxer c4-12 cannot.
flydiver
An analyzing charger will charge > discharge > the charge the battery and give you the capacity determined from DISCHARGE. This is the only accurate way to measure capacity.
Lii-500, Zanflare C4, and the Opus BT-C1000 are analyzing chargers.
The main advantage of the Opus is more control and options for charging and discharging. It has some ‘quirks’ that some people dislike. But, it IS more flexible, more powerful, and has more charging options.
A ‘charge only’ charger cannot do this.
The Miboxer C4-12 appears to be only a charger, but a good one. It’s fine if you don’t really want an analyzing charger. But I think you will.
BlueSwordM
See, the problem is that almost all analyzing chargers aren’t actually all that good.
They use resistor based dischargers, meaning current drawn goes down as voltage goes down, meaning capacity can easily be overread.
flydiver
Got a better SIMPLE/REPRODUCIBLE way? What other ways are there to discharge accurately?
I assume you mean, “not all that good” at discharging? The charging is NOT in question?
molitar
That is a good question there. OK comparing the LiitoKala Lii-500 and the Opus BT 3100 v2.2 I have opted for the Opus and ordering it from Amazon. It is the same price as on BangGood but I get it delivered in 2 days Smile Opus supports more types and the larger battery sizes so that will be the charger I order. I appreciate the advice and assistance and the explanation of what an Analyzer/Charger is.
BlueSwordM
No, charging isn’t in question. They charge fine.
Get something like this:
https://www.ebay.com/itm/DC-12V-Battery-Capacity-Tester-Battery-Life-Int...
And a battery holder like this:
https://www.ebay.com/itm/Plastic-Battery-Holder-Storage-Box-Case-for-1x-...
These work quite well, and you can test capacity very accurately, along with internal resistance.
flydiver
? Looks like a resistor to me.
One * rating. Not encouraging.
