[Sofirn headlamp]SP40 was added 3000K and 4000k color now
58 posts / 0 new
Jackie
Last seen: 23 hours 44 min ago
SP40 update news: as many customers request, we add 3000K and 4000K color temperature in SP40 now, 100 pieces assembled this time, welcome if you are interested in.
Link: SP40
The first own design headlamp from Sofirn is available now on Aliexpress-SP40
It is an EDC light could used as a headlamp or a flashlight, compaitible with 18350 battery by using the replace battery tube, USB rechargeable.
Specification:
CREE XPL LED with a lifespan of 50,000 hours
Working Voltage: 2.8V-4.2V
Battery Options: One 18650 Li-ion battery
Dimension: 108mm (length)*25mm (head diameter)
Weight: 63gram (without batteries)
Mode Memory
Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 55℃ to prevent overheating
Power Indicator: The LED indicator on side switch blinks in green for 5 seconds if remaining battery power is over 30%. When the indicator turns to red, battery juice is below 30%. Flashing red light indicates low power – replace or recharge battery ASAP
USB input:5V1A
Operation Instruction:
The switch controls all flashlight functions as follows:
Short click to turn on, another click to turn off.
While the light is on, the side switch to cycle through modes: Low→Mid→High
Double clicks to activate Turbo mode, one click to return last mode.
Click to know more:https://www.aliexpress.com/item/33014058575.html?storeId=2933049&product...LED-Headlamp-Cree-XPL-1200lm-18650-USB-Rechargeable-Headlight-18350-Flashlight-4-Modes-with&spm=2114.12010611.8148356.11.28b95223Cq8qDw
Edited by: Jackie on 07/18/2019 - 04:36
bmengineer
bmengineer's picture
Last seen: 3 hours 13 min ago
What do you do to cycle the modes? Hold?
Find all my reviews of flashlights and more gear at www.bmengineer.com
M3CSL
M3CSL's picture
I like the 18350 adapter/tube.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
Nooner
Last seen: 5 hours 40 min ago
Tailcap magnet?
I’m guessing no. It’s not mentioned.
Paul321
Paul321's picture
Last seen: 6 days 18 hours ago
I would like Sofirn to produce a AA / 14500 headlamp. Without a built in charger.
Paul-
Jackie
it will included in the package
Jackie
Nooner wrote:
Tailcap magnet?
no magnet Crying
Jackie
Yes, hold press cycle the modes
Nooner
Jackie wrote:
Nooner wrote:
Tailcap magnet?
no magnet Crying
I still want one Smile
Jackie
Nooner wrote:
Jackie wrote:
Nooner wrote:
Tailcap magnet?
no magnet Crying
Thanks, here is a code coupon for SP40 if you want Big Smile this valid for Aliexpress APP, from 8th to 15th, May, scan to get and use it when purchase, if any problem in using, contact with the customer service ,they may help adjust the order amount by hand
This is the link for coupon too: https://www.aliexpress.com/store/selected-sale-items/2933049.html?es=sq0...
bikenber73
bikenber73's picture
Last seen: 2 days 11 hours ago
When the flashlight is using the 18350 tube will it fit in the silicone lamp holders on the headband?
It looks like it would be too short.
In order to use it as a headlamp you would have to use the 18650 tube.
Thanks
Scallywag
Scallywag's picture
Last seen: 2 days 5 hours ago
Brand new light. Outdated Micro-USB Crying
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Jackie
Thanks
Yes,it fits quite well.
GeraldL
Last seen: 10 months 2 weeks ago
Hi, can I get more info for this light?
Is it CW or NW? What’s the colour temperature?
What are the lumen levels for low mid high and turbo? Is there a moonlight mode?
Will future versions have TIR lens and a magnetic tailcap?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 8 hours 47 min ago
Usually, those XP-L HD Sofirn uses will come with a CCT between 5350K and 5750K, so a bit on the coldwhite side. But I cannot tell for sure what they are using here. I would be surprised if they used a warmer tint than usual. Modes on the SP40 are: 5lm (Low), 90lm (Medium), 450lm (High) and 1,200lm (Turbo).
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
bikenber73
Ordered!
gchart
gchart's picture
Last seen: 5 hours 37 min ago
I can’t wait to try this guy out. Nice UI, temperature regulation, two battery tubes… sounds great!
GeraldL
Thank you for your reply! Pretty nice mode spacing but I wish it had ramping, and a moonlight mode for up close use since its a headlamp. Might be still get one
Serlite
Last seen: 56 min 34 sec ago
Seconded! But I’m also happy to see this new entry to the budget 18650 headlamp market. Probably going to be my first decent headlamp, now that I got the feel for a cheap one with the Boruit D10.
Barkuti
Barkuti's picture
Last seen: 2 hours 57 min ago
Why is USB micro-B outdated?
USB micro-B is a pretty widespread standard, compact AND inexpensive. An USB type-C connector is bigger, more complex and more expensive, without real advantages here besides reversibility.
In the past I replaced some USB micro-B male connectors for a sloppy friend in a DIY power bank with a permanently attached micro-B output cable, they can be bought rock bottom cheap with shells (and I've seen cheaper).
On the other hand, USB type-C male connectors: 5x pieces, 10x pieces. Without Facepalm shells.
Of course the above is for comparison purposes, just made the type-C thing search out of curiosity. It serves as comparison because as it is understandable the female part cost is thereabouts.
I could say a chair or even the wheel are outdated. I like outdated stuff. Wink
Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
vietnamreviews
Last seen: 5 hours 27 min ago
It’s great for only $ 20
Scallywag
Scallywag's picture
Devices are pushing the usb-c standard for a variety of reasons, and adoption is picking up. I have less and less need for micro-USB and have fewer and fewer of the cables hanging around. I wouldn't want a new light, which I'd expect to last years, to end up being my last darn micro-USB device.
Barkuti
Barkuti's picture
Kindle
Kindle's picture
Last seen: 8 hours 20 min ago
Yes because an additional dongle is an awesome solution.
Barkuti, it’s ok to let go of your serial port mouse too.
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 55 min ago
Actually, it’s not too good of a comparison.
USB-C is superior in every way compared to micro-USB.
PS2 is still slightly better in terms of latency and lower power requirements.
And yeah, why would you want a dongle? More ways to break the port.
LarryLumens
What are the specs for the battery package option? Looks like a good deal for only $3 more.
Give me thrower or give me pizza.
Barkuti
Barkuti's picture
Well people, this headlamp has been designed with a  USB micro-B input port. I can understand all sorts of scaremonger reasons against, but in all honesty it is not my problem. I think and believe different. Nothing is random fellows. My ports do not break, I keep them fit and clean. If yours do, address the cause and/or fix the problem.
The headlamp could also been fitted with a standard Innocent ∅3.5 × 1.3mm DC female plug, it could also have Big Smile worked with it. So, you can consider yourselves fortunate it uses a nowadays' more widespread and standardized USB micro-B connector. 0K, no more fuel to this fire of yours.
Have fun and be happy.
Smile
Mon, 05/13/2019 - 02:16
Wratz
Can’t say for sure until tested, but Sofirn’s batteries are usually pretty good. Nothing crazy awesome, but for the price you can’t beat it.
BlueSwordM
3000mAh 18650.
Probably a 6A cell.
Barkuti
Barkuti's picture
LarryLumens, according to this test data:
Plus this:
Source: Henrik's 18650 comparator @ lygte-info.dk
Edited.-
Despite Henrik's graph would probably match better if the NCR18650BL cell were have been tested on the newer 4-wire battery holder test station, capacity still does not match even if cell curve shape does.
So it is not an NCR18650BL. There are cells Henrik still have not tested, the one Sofirn is rewrapping could be some 3100mAh 0.2C rated cell from some known manufacturer like an NCR18650A, or from another OEM.
Take care Thumbs Up
Mon, 05/13/2019 - 06:30
Jackie
the battery is a 3000mah 18650 battery
