Test/review of LG 21700 M50 5000mAh (Grey)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 hours 29 min ago
DSC_4597
Official specifications:
  • Nominal Energy: 18.20Wh (5013mAh at nominal voltage)
  • Minimum Energy: 17.60Wh (4849mAh at nominal voltage)
  • Nominal voltage: 3.63V
  • Nominal shipping SOC: 30%
  • Standard charge current: 1455mA (0.3C)
  • Charge cut-off: 4.2V 50mA
  • Standard discharge: 907mA (0.2C)
  • Discharge cut-off: 2.50V
  • Cycle life: 500 cycles to 80% of Wh min.
  • Maximum pulse discharge power: 80W for 10sec
  • Maximum discharge current: 7275mA (1.5C) in temperature range 5°C ~ 60°C
LG%2021700%20M50%205000mAh%20(Grey)-info
This is a high capacity 21700 cell with about 5000mAh, the cell is not for high current.
DSC_4598DSC_4599
DSC_4600
LG%2021700%20M50%205000mAh%20(Grey)-Capacity
The two cells are well matched.
LG%2021700%20M50%205000mAh%20(Grey)-Temp-15.0
The battery gets fairly warm at 15A
It looks like I have a problem with my temperature sensor.
LG%2021700%20M50%205000mAh%20(Grey)-Temp-20.0
The defect temperature sensor made the B battery fail permanently, it got too hot.
LG%2021700%20M50%205000mAh%20(Grey)-CapacityTimeHours
LG%2021700%20M50%205000mAh%20(Grey)-Energy
LG%2021700%20M50%205000mAh%20(Grey)-PowerLoadTime
LG%2021700%20M50%205000mAh%20(Grey)-TripCurrent
LG%2021700%20M50%205000mAh%20(Grey)-Charge
Conclusion
This is a one of the best high capacity batteries.
Notes and links
The batteries was supplied by batteridoktorn.se for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Agro
Last seen: 1 hour 45 min ago
Actually the highest capacity 21700 up to 10A discharge…which covers most cases of sustained flashlight use. Smile
BTW your table of all cells misses capacity measurements of this at 0.2A.
Thanks HKJ!
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 hours 50 min ago
Maybe Molicel's M50A will match or surpass the LG M50. But Molicel is probably cheating as the M50A's diameter is 21.7mm, i.e. larger than or at least as large as the inner diameter of many battery tubes of 21700 lights. Wink
HKJ
HKJ's picture
I know, but something went wrong with one of the cells and i do not have a full curve. The table building software excludes data if the two cells in a test do not match.
Superstocker
Superstocker's picture
Last seen: 3 hours 6 min ago
Thanks HKJ!
wolfdog1226
wolfdog1226's picture
Last seen: 11 hours 47 min ago
Thanks HKJ.
The voltage curves are basically identical w/ the Samsung 50E
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
RelakS
Last seen: 2 hours 38 min ago
HKJ, what software do you use to draw these diagrams? I haven’t found it on your website even if it is mentioned.
HKJ
HKJ's picture
My own software, it used a library called JFreeChart: http://www.jfree.org/jfreechart/
All my tests are saved as CSV files and then I use the above to draw the charts from the CSV files.
KevinZA1988
KevinZA1988's picture
Last seen: 43 min 10 sec ago
This looks like the cell I found when I took the wrapping off my Rofis 21700 protected cell. Hmmmmmm….
Acebeam L16, Acebeam EC50 GEN III, BLF Q8, BLF A6, Convoy L2, Convoy L6, Convoy C8+ (custom), Convoy S3 (custom), Emisar D4, FW3A, Jaxman E2L, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65.
RelakS
Thank you!
The CSV part is OK, but Excel/LibreOffice does not support more than two Y axis…
shadockan
shadockan's picture
Last seen: 3 days 6 min ago
Lux-Perpetua wrote:
Maybe Molicel’s M50A will match or surpass the LG M50. But Molicel is probably cheating as the M50A’s diameter is 21.7mm, i.e. larger than or at least as large as the inner diameter of many battery tubes of 21700 lights. Wink
The Moli M50A is a 20A battery. Moli will have less voltage drop … so it will later reach the cut-off point
It is not correct to compare different batteries …..
