[Review] YLP Gryphon G18 ( Triple XP-G2 , Rechargeable ) - Nicely regulated :)
6 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 9 hours 44 min ago
The Gryphon G18  was sent to me by YLP for review,
You can also visit YLP's BLF thread to get a coupon code: http://budgetlightforum.com/node/66157
The light arrived in a nice black cardboard box.
A short description of the flashlight's features is listed in the back side of the box.
Both the flashlight and the accessories are seated inside foam for added protection.
The accessories included are an adjustable wrist band, a replacement o-ring, a replacement charging port cover and a metal clip.
The flashlight comes with a black matte anodization and some curling around the body and tail.
As seen, it's e-switch operated, with the swtich mounted on the head.
Opposite the side switch, one finds the microUSB charging port which is protected by a rubber flap.
The e-switch is very tactile and is covered by a vivid orange boot.
The indicator LED installed into it lights up while charging.
The polished aluminum bezel helps protecting the triple optics.
By default, the flashlight comes with 3 x 4000K XP-G2 emitters.
The tint of the flashlight is probably the best I have seen produced out of an XP-G2.
It's worth noting that the head/body assembly is glued together.
For maximal efficiency, the driver is using a metal tab as the positive contact.
The tails' threads are anodized and square cut.
The tail includes a heavy duty copper spring as well as strong magnet.
The built-in charging interface is using a regular microUSB port.
My tests showed the the maximum charging current is around 1A.
It's very convenient that the manufacturer also included a 18650 cell with the flashlight.
After further inspection, the cell is a Samsung 26E.
The cell comes with built-in protection and it's button top.
After a couple of full charge-discharge cycles, the capacity of the battery turned out to be 2784mAh which is more than the manufacturer's rating.
User Interface
The G18 uses one of the simplest and most convenient e-switch firmwares.
Here's all the supported actions:
Turn on/off: Single press.
Mode cycle: Long press (Low > Mid > High > Low > ... )
High: Double press from anywhere.
Moonlight: Long press while off.
Strobe: Double click and long press from anywhere.
Mode memory can be toggled on and off.
Performance
In order to get my measurements I used the included Samsung 26H cell.
Here's each power level along with the current draw and light output.
I also measured the parasitic drain at 29μΑ, which is excellent.
And here's G18's High compared to my other flashlights:
My measurements showed that indeed the flashlight can output its rated brightness.
Regulation
Here's a graph I created after running the flashlight on Turbo for 43mins.
The flashlight was left standing during the test - no cooling was applied.
High mode is retained for 8 mins and afterwards the flashlight steps down to 45%.
As with all YLP flashlights, the G8 is very well regulated.
It's worth noting that the flashlight didn't turn off at the 43 min mark, I just run out of time Big Smile
During the test, the head never got too hot to touch / handle.
It's pretty safe to assume that medium is fully sustainable for the whole span of the battery.
Todo: Add indoor / outdoor pictures
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
Edited by: bilakos10 on 05/19/2019 - 11:49
oakheath
Last seen: 24 min 12 sec ago
looks like a great flashlight, did you do any beamshots? be nice to see them.
bilakos10
bilakos10's picture
I will try to capture some beamshots tomorrow Smile
Big_Sam
Big_Sam's picture
Last seen: 10 hours 8 min ago
Thanks for the review, it looks like a great light!
Giveaways running until 31st Jan: http://budgetlightforum.com/node/71149
Lightbringer
Lightbringer's picture
Last seen: 6 min 35 sec ago
Damn, that’s the second YLP that looks quite good!
oakheath
Big Smile can’t wait, been trying to find English reviews on Youtube but no luck. May well being buying this have the Unicorn 1.0 and love it.
