Folomov EDC C2
34 posts / 0 new
Agro
Agro's picture
Last seen: 34 sec ago
Folomov EDC C2
Folomov has released a new light with E21A powered by 14300 cell. The cell features USB charging circuit so it’s probably regular 14250 with a circuit adding 5 mm. Smile
http://www.folomov.com/en/content/?140.html
54.4 mm length, 18.5 mm diameter.
UI is a bit saner than that of their previous lights.
I really like it. Smile
Edited by: Agro on 05/15/2019 - 14:53
bmengineer
bmengineer's picture
Last seen: 7 hours 49 min ago
What are you seeing that’s different than their other UI?
Find all my reviews of flashlights and more gear at www.bmengineer.com
Agro
Agro's picture
Direct access to moonlight.
wle
wle's picture
Last seen: 13 hours 6 min ago
Yeah i have the EDC C4 and the UI is TERRIBLE!
4 levels, L M H T M L —if you want to go down one level you have to cycle 5 times
it goes to strobe if you try it too fast, also
long press for on, and also for off
(i see this new one continues the up/down annoyance with one less step – L M H M L)
wle
saypat
saypat's picture
Last seen: 2 hours 42 min ago
I like it. How much?
mrheosuper
Last seen: 28 min 54 sec ago
14300 cell?, why?, can they make it fit popular 14500 cell?
Forgot my pen
LightObsession
Last seen: 44 min 49 sec ago
I thought that the 18650S had direct access to moonlight?
I returned my 18650S shortly after I received it, because I didn’t like the wave mode sequence, and mine didn’t always go to the last used mode from moonlight – often went from moonlight to Turbo, regardless of what mode it was in when turned off.
I’ll be watching for reviews of this little light to see what users think of it.
LightObsession
I looked at the linked web page:
It appears that the UI might be exactly the same as the 18650S. This means that I most likely won’t even try it.
I really like the mode spacing, but the run times on High and Turbo are pretty anemic.
Agro
Agro's picture
I missed that, I only looked closer at their EDC lights. So it’s not a news.
The wavy mode switch doesn’t bother me much – though I don’t see the point of it. I dislike mode memory more – even though I do see its point. But that’s a common misfeature.
Agro
Agro's picture
But then it would be a light with mediocre performance, mediocre UI and mediocre price for its class. Big Smile
Now it’s probably the only rechargable light in the 14250-14300 class. And the one with the best LED. And has moonlight. It suddenly becomes a quality offering. Big Smile
Scallywag
Scallywag's picture
Last seen: 11 hours 13 min ago
Identical length to Olight S1 mini? S1 mini is slightly fatter, but I'd pick it every time over using a 14300/14250 cell
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
LightObsession
The light weight, small size, proper clip orientation for hat brim use and high CRI emitter make it tempting to try for hat brim use.
The main obstacles to my purchase of this light are the UI and sucky run-times at High and Turbo.
Another concern is that in the pictures, the clip looks like it might have to be opened up a bit at the deep end in order to allow thicker seams at the top of some jeans pockets.
Tixx
Last seen: 10 hours 23 min ago
WOW! 98 CRI
LightObsession
Tixx wrote:
WOW! 98 CRI
That probably accounts for the dismal run times.
HONDARIDER
HONDARIDER's picture
Last seen: 3 hours 41 min ago
I have 2 18650S’s and switched the LED to an XP-L Hi. It does have direct access to Moonlight (Long press from off) and even though I am not a fan of the ascending and descending UI, it’s not the worst I have ever used. The size of the light is what I like the most and the XP-L Hi helps with heat and adds a little throw. The 219D is horrible in that light.
I didn’t even know that an 18300 cell existed. 18500 or 18350 would make more sense.
Edit- I would also like to add that Folmov’s customer service is very good. Took a couple of weeks but the issue I had with my 18650S was resolved by them sending me a new tail cap assy. I was extremely happy with them.
Agro
Agro's picture
It’s not 18300. It’s 14300. Mostl likely constructed out out 14250 and protection circuit which lengthens it to 14300.
saypat
saypat's picture
it will be a bit pricey
Blackbeard
Blackbeard's picture
Last seen: 1 min 52 sec ago
I’m surprised they didn’t fold up shop after that 18650s hand burner / tint shifter fiasco
Geuzzz
Geuzzz's picture
Last seen: 35 min 25 sec ago
Was tempted until I saw the strange cell format and UI.
Olight s mini is still the best extremely small flashlight after all these years. EDIT: only if you change the led of course
Agro
Agro's picture
This is much slimmer than any 16340 light. Which – for me – is precisely the point.
Geuzzz
Geuzzz's picture
Sound great for you than. Are you going to order? I hope you will like it.
Agro
Agro's picture
Not sure. Depends on price and reviews. And magnet strength – due to the lack of attachment point I would need to hang it on my neck by the magnet. Smile
steel_1024
steel_1024's picture
Last seen: 22 hours 23 min ago
Nichia E21A R9080CRI
FOLOMOV EDC C2
Sorry for my poor english.
Tally-ho
Tally-ho's picture
Last seen: 22 min ago
I’m really impressed that they went with a high CRI Nichia E21A and all the more with one with low CCT. Thumbs Up
A pity that the UI isn’t as impressive.
LightObsession
I received mine about 20 minutes ago, messed around a bit and put the battery on to charge – charge indicator in switch was red.
It’s a cute little light and I kind of like it.
Construction quality seems quite good.
LED is well centered.
UI BIG SURPRISENOT WAVE MODE SEQUENCE!!!
Mode sequence is L-M-H-L-M-H in my sample. That caught me off guard and it took me a few cycles to figure out what was going on. I guess they listened to the negative feedback about the Wave mode sequence and made adjustments.
Direct access to low and turbo are as expected.
The clips is actually quite snug – not sure if it will fit on my thicker hat brims.
Three quick clicks for lock-out doesn’t seem too cumbersome. I haven’t tried loosening the tailcap for lock-out. Switch is proud of the light tube and is easily activated, so lock-out seems like a good idea.
Definitely a bright little light on Turbo.
I haven’t done any testing of the CRI, yet. I’ll mess around more after the battery is fully charged.
saypat
saypat's picture
LightObsesson, appreciate your thoughts on this light. I’m interested in one. Meager run times on that tiny (240 mAh) cell however.
LightObsession
An additional note on lock-out:
1/8 turn or less of the tail cap locks it out securely.
JASII
Last seen: 3 weeks 5 days ago
Thanks for the info. Thumbs Up
Tom6
Last seen: 10 hours 12 min ago
What about 6000cd?Is it a thrower?
Agro
Agro's picture
No, it’s definitely a flooder.
LightObsession
The Folomov EDC C2 is definitely NOT a flooder.
My sample has a very intense hotspot. So intense that I’m considering applying DC-Fix to soften it up a bit.
Definitely more of a thrower than a flooder.
