Quick question about reflowing an XHP70.2
Hello guys, I've searched the forum and found some info, but i am still a bit confused. I want to reflow an XHP70.2 LED from arrow on a 20mm MCPCB.
The arrow listing says max forward voltage is 12.2V. If i understood correctly i can reflow that emmiter to that board, and the voltage should be 6V? Or i should try to find and emmiter that shows max forward voltage 6V?
Thanks a lot!
You can reflow this emmiter to led4power board and Vf will be near 6V.
I understood correctly then, thanks!
