FIREFLIES is an emerging flashlight manufacturer.
The first flashlight launched the ROT66 with 9 high-CRI LEDs.
Please refer to:
Fireflies ROT66, Born for fans of flashlight
then……
Look at the trend of 21700 lithium battery
Also introduced two flashlights using the 21700 lithium battery E07, PL47, are well received
The characteristics of the FIREFLIES flashlight are not only the design but also the appearance.
The most important thing is the rich operation interface.
People who use custom gear shifting and first contact with firefly flashlights may feel too complicated
However, as long as you have a little patience to understand the UI architecture, you will love this flexible interface.
FIREFLIES family portrait
Black carton packaging, golden hot stamping
Boxed content: hand rope, holding clip, waterproof ring, 18650 turn 21700 conversion tube
Appearance is similar to E07, higher height, more heat sink
Power Indicator
Use a 6 degree lens with illumination angle
Tail cover
Detachable same color clip
7 ultra-deep heat sinks
Use 21700 lithium battery, can be converted to use 18650 lithium battery
(Please do not use a power battery that discharges more than 20A)
Exquisite chocolate-like texture of the barrel, strengthen the hand feel
4-eye power indicator
Beautiful deep recessed heat sink
Tail cap
Use SST40W N5 5700K LED
SST40 close-up
Gold-plated spring
Driver
Provide refresh firmware contacts (requires special tools)
Head thread
Tail thread
Luminous angle 6 degree lens (concentrated light)
Lens front
LED PCB
Moonlight
Outdoor test (four level + Turbo)
Scene light
L1: 20 lumens
L2: 100 lumens
L3: 500 lumens
L4: 1000 lumens
Turbo: 2300 lumens
Animation
Thanks for watching
Sorry for my poor english.
Nice! Thanks for the very detailed pictures again.
I see the same “new type” SST-40 leds, with diagonal dot-pattern on the die, that Lexel had questions about in another thread. Either a design change from Luminus, or a copied chinese led with apparently very good performance.
link to djozz tests
Very beautiful pictures, thanks
Emisar D4 Cyan Photos
Convoy S2+ triple & Solarforce P1D quad Nichia R9080 with copper pills
For sale: Nichia 219B sw45k R9080 & 219C 5000k R9050
Nice-looking and seemingly nice-performing light. Adding it to my bucket list.
Thank you for your unboxing. The pictures are great, particularly the size comparison with the E07. I already own two E07s, which I love.
So, I was wondering where you see the E01 fitting into the FF lineup, other than its lower price point.
In other words, why would anyone with an E07 be interested in owning the E01? (It appears taller than an E07. I was kind of hoping it would be more pocket friendly than the E07, but from a size standpoint, it doesn’t appear to be.)
I would be interested in your perspective, since you own both lights.
Maybe I’m dumb, but why does the star say Cree XM-L when it’s supposed to be a Luminus SST-40?
Thank you for the beamshots, can you do a comparison beamshot with something similar. like the Emisar D1 (I know is reflector instead of optic) for reference?
Thanks!
Because both the XM-L2 and SST-40 use the 5050 footprint and crees are way more popular so thats what the mcpcb makers put on their boards.
I particularly like this:
… because it makes the E01 a great dev host. I made good use of it while adjusting thermal regulation code recently. This graph shows a before/after of how that went:
But that doesn’t matter to most people. It also works well as, um, a flashlight.
Will you put FF E01 on the FSM list?
or a full Anduril?
Thanks for this, mine is coming
I'm ThatCrazyFlashaholic 67
Yes, I just got delayed while working out the details of the source code release. I need to merge the E01 branch and publish it.
It’s easy to reflash if you have the right pogo pin adapter, but difficult otherwise.
I merged everything and put a build online:
http://toykeeper.net/torches/fsm/anduril.2019-06-01.ff-e01.hex
Fwiw I found my E01 pretty simple to flash with an soic clip.
Desolder led wires
Push led- wire down into hole
Use small poker tool to push out driver
Flip driver over in place and attach clip to flash.
You DON’T have to mess with the switch wires at all and no components on board interfere with the clip!
I built anduril for the PL47 target, the ROT66 target will work too but the ramp shape will be off. I need to update one of my E07’s back to an UTD pl47 build asap, (it’s ramp is visibly nonlinear after I loaded a ROT66 based hex onto it).
I have been thinking about getting one of these… I am now convinced I need to do it.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
I got the confirmation that the cross pattern is definitely an original Luminous devices, directly bought from the manufacturer
I see they removed the aux programming pad as it’s not needed to disconnect the aux board for flashing
the PL47 has it too but you cant get to it
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: TA based drivers NarsilM or Bistro OTSM 17-22mm, S42, L6, Q8, MF01, SRK, TN42 / Narsil based buck driver for 20-30mm MF01/02, TN40/42, GT, MT09R / Remote switch tail DD board with FET
Aux boards: Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
It's funny because it looks just like an XM-L2, on a Cree XM-L board to boot.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Also Atmel MCUs changed the markings recently, first being thought it’s a Chinese fake, reason Microchip bought Atmel
Likely also production of new MCUs in China now so spotted first on Chinese drivers
Its a year now and still MCUs from Mouser show old markings probably will change too until they run out of stock
[Sale]
Who’s adapter and what pogo pins do we order? Links please?
HQ ProgKey – Universal Driver Programming Key
I don’t get it.
They may be afraid of burning out the SST40, which can burn its bond wires around 9A. It hits max output around 6A iirc
I think this will be my next lantern.
Ordered the E01 and just received it the other day. Didn't have time to test it but it doesn't work, maybe someone can help figure what could be the problem?
(just fast play through the video since it's about 1 minute long)
what might be the issue? (I am reporting to the seller, but would like to know what might be the issue in case I'm doing something wrong)
What battery u using?
Battery discharge shud be no more than 10A or you could fry the emitter.
I used Liitokala Lii-40A 4000mAh 21700, not sure of the Amps rating of this battery.
Unfortunately, I couldn’t source any 10A 21700 battery in our country, and foreign stores do not ship batteries to my country (not economically anyway, higher than $20-$50 shipping from abroad)
(The other 21700 batteries I currently have are the Sofirn 4000mAh 21700 from Sofirn flashlights).
As there’s no flash on inserting the battery my guess would be either no power to the LED or a faulty LED.
I’ve just tried to replicate the problem on my E01 and can’t.
Just to be sure there are 2 things to try:
1- Before you put the battery in make sure the head is tightened properly onto the body, then insert the battery and tighten the tail cap to complete the connection. (It’s possible to loosen the head while still having a connection, while i can’t replicate your issue while doing this, if your battery is slightly too long for the head to tighten properly once the battery is inserted there’s the smallest of chances it’s having an effect.)
2- Try your Sofirn battery. The issue with potentially damaging the LED is only on full power, so as long as you don’t go into turbo you won’t have the potential to damage the LED. Certainly, just seeing if the LED flashes when the battery is inserted will not damage the LED, it doesn;‘t flash at full power. (I think it flashes at the default mode of 350ma, which is the maximum output of the 7135 and the maximum regulated mode.)
If still nothing i’d say it’s an LED/power to LED issue.
Edit: Forgot to say, all 4 switch LEDS are constantly lit so only tell you when the battery is connected, they’re no indication of what the driver’s doing.
It looks like the main LED is broken or disconnected.
The button LEDs are hardwired to power, so they’re on whenever a battery is inserted. They don’t respond to anything else. It’s not like the other FF products, which can blink.
Hi,
I just bought a fireflies e01 and a ffe07.
It was broken and they are sending me a new head for free.
In the meantime I’ve realised it’s not compatible with my 21700 batteries because they are 30a and this driver has a maximum of 10a. I have some old 18650 batteries, but I plan on using them for bikepacking (one for me one for my girlfriend) and weight matters, so I would like to carry only the 21700 30a ones and I would like both flashlights to be compatible with them.
I’ve already taken it apart and the driver is 24mm in diameter.
Which driver could I use with the same LED (I already bought a replacement) that fits in, is compatible with the side switch and can handle the 30a batteries?
About the modes, I like the anduril full version from the e07. It would be cool to have something similar
I’m definitely getting the feeling that I am the odd one out but: are there any plans to make a Ti/Cu version? It’s a question of personal taste (of course) but I think the E01 is the prettiest of them all. Plus I am not a believer in multi-led lights. And last but no least, I’m (a bit) colorblind so I’m not advocating to change anything else but the material of the shell.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
