Eneloop lite AAA BK-4LCCE 550mAh (Blue)
Official specifications:
Nominal voltage: 1.2V
Minimum Capacity: 550mAh
Cycle life: up to 3000 cycles.
Low self discharge: 70% after 5 years
Maximum temperature raise at different discharge currents: 1A:+2,4°C, 2A:+5,1°C, 3A:+6,8°C, 5A:+8,0°C
Low capacity, low self discharge AAA batteries.
Capacity is around 550mAh, depending on load and the two cells matches.
Pulsing 1A on/off makes it possible to calculate the internal resistance during discharge. H means current on, L means current off, measurements are done just after switching the current.
Conclusion
The batteries looks like very good quality, but the capacity is low. They are rated for more cycles than regular eneloop.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
