[M4D deal ACTIVE] LiitoKala Lii-500S groupbuy
155 posts / 0 new
WalkIntoTheLight
Last seen: 2 months 20 hours ago
teacher wrote:
Yeah, I have one or two that go to 4.22 V, batteries immediately off the charger. But they drop quickly. Bad or not bad… I really don’t worry about it. Much higher… I might.
The valid range is 4.15v – 4.25v. But, I like it to be on the lower end of that range. It’s sometimes tough to tell, exactly, since (as you say) cells will drop their voltage 10mV or 20mV pretty fast when they’re done charging.
Most of my chargers seem to result in voltages around 4.18v when I take them off the charger. So, I suspect they’re actually being charged to 4.20v at the point of termination. Most chargers usually terminate the CV phase when they’re only putting in about 100mA of charge to the cell to hold it at 4.20v.
Windsurf
Windsurf's picture
I found this thread b/c I already own a Lii-500 charger and wondered if there was a newer version. So I have a couple of questions for those who have received the Lii-500S.
I have a problem with my Lii-500 charging 16340 batteries. There isn’t enough spring tension in the rack and so often the battery doesn’t register. Have they fixed this issue on the Lii-500S?
I see the Lii-500S like the Lii-500 doesn’t charge all 4 bays at full charge. When only 2 bays are used they get full power but when 4 bays are full they step down the charge.
I own a couple of Xtar 18700 batteries and they fit in the Lii-500 but it is tight.
I also own a Nitecore D2 which used to charge to my batteries to 4.22 but on the newest 3000+ 18650s and 1100+18350s it only charges to 4.20. But if I put them into the Lii-500 they only sit in the charger for less than a minute and it registers 4.22 and then shows finished. I can’t explain why the D2 doesn’t go to 4.22 on these newest batteries.
Thanks
Old Mate
Last seen: 2 months 1 day ago
My early model lii 500 always shows 4.22 on the screen but only shows 4.19 – 4.18 on my DMM. The measurement must be under load.
Old Mate
Pete7874
Pete7874's picture
Last seen: 6 hours 24 min ago
M4D M4X wrote:
yes – PROMO sales do deactivate other codes – usually my codes do work after those sales…
It says coupon expired.
HONDARIDER
HONDARIDER's picture
Last seen: 1 month 1 week ago
I’d like to get one also. Been waiting for the sale to end so I can use the GB code.
Edit-Code expired when I tried also.
M4D M4X
M4D M4X's picture
Last seen: 17 min 16 sec ago
I request a new deal
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
specialk
Last seen: 2 hours 57 min ago
Hi M4d M4x. Is there a new coupon available? Or do we have to wait for the banggood current sale for the charger to end first.
M4D M4X
M4D M4X's picture
yes
we need to wait after that my code works again
(if not I request a new)
varbos
Last seen: 18 hours 5 min ago
hasddie293 wrote:
Liitokala Lii-500S in Thai language I think…
Personally not a big fan of negative LCDs, they are more difficult to read. Plus that beep every time a button is pushed seems super annoying. I hope it can be turned off.
HONDARIDER
Did Banggood extend their sale? Knew I should have ordered this when it first started. Going to take forever to get this charger.
JoeRodge
Last seen: 3 weeks 2 days ago
I’m waiting also, roar!!!
HONDARIDER
Guess we will wait till the 12th.
mattlward
mattlward's picture
Last seen: 4 days 19 hours ago
I wish they had not dropped the 300ma mode. I use this for 10440’s as I would hate to hit them with 500ma. Have not decided yet if I will try this one or not.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Relampago
Relampago's picture
Last seen: 22 hours 6 min ago
Got mine! I like it. I didn’t know about the negative display but it’s not a dealbreaker. So far so good, fits the 26650s pretty good.
“Electricity is really just organized lightning”
― George Carlin
kuoh
Last seen: 4 hours 36 min ago
Got mine today as well. The display is very readable even at a shallow angle when the backlight is on, but when it’s off, you can barely see anything. I wish it could leave the backlight on constantly or only go 50% rather than completely dark. I also got the cheaper LII-S4 and it’s not battery polarity sensitive, while this one is.
KuoH
HONDARIDER
Banggood is not going to relinquish this sale so that the discount code will work. Was supposed to end on the 12th. guess they are selling a lot of them at $25.
xevious
xevious's picture
Last seen: 1 day 11 min ago
I’m bummed I missed the discount deal… $21.99 is a nice price. Can’t find it any lower than $29.99. I’m not in a hurry so will wait. Hopefully someone will bump the topic with another good price later on.
TrueRMS
KuoH
A small resistor should fix that. I’ve seen people do it on chargers before. Place it between the backlight FET’s drain and source. When the charger commands the back light on you have full brightness, when it doesn’t you have partial brightness (depending on resistor value).
teacher
teacher's picture
Are you a member with M4D M4X?? If not go HERE and get signed up. Then check out his deals.
Just be sure not to share the Codes or prices.
Check out the new Liitokala Lii – S6 charger too. 6 Bay charger it is. Thumbs Up
6 bays 1000 mA / 3 bays 2000 mA
xevious
xevious's picture
I am, but I was foiled by the brand misspelling thing… Liitokala, Liitokaala, Liiitokala, LittoKala, etc. I found the 500S on the “Littokaala” now. Thanks!
I think I might go for the 6 bay one, as I prefer tactile buttons instead of touch-sensitive ones.
Pete7874
Pete7874's picture
The only 500S coupon I’m seeing on his website is the one that he publicly stated in the original post of this thread, and it has been dead for quite some time now.
teacher
teacher's picture
Yep…. Thumbs Up … That was why I suggested he check out the new Lii-S6.
Martin’s Lii 500S code won’t be valid until either the Sale Ends or he requests a New Code from BG.
kuoh
Keep in mind the 500S does discharge testing, while the S6 I presume like the S4, only charges batteries.
KuoH
M4D M4X
M4D M4X's picture
 I try to get a new deal
€dit
Code works again!
leftdisconnected
Last seen: 3 hours 15 min ago
teacher wrote:
specialk wrote:
I have it already. I want a charger that can discharge batteries.
This one can discharge batteries.
It seems silly to add this, but I meant to say it a month ago Wink . I found it somewhat humorous that LiitoKala released a Lii-500S charger that will discharge cells just weeks after I purchased the old Lii-500 that doesn’t. I needed that feature, spent many months searching for a cheap charger with a discharge mode, and would have paid the few dollars extra to get it.
Fast Test on the old charger is simply useless; no idea what it could be good for. Oh well Beer . That’s how it usually goes and glad that they replaced that function with a useful one on the new version.
I’m not a fan of the new display, though it seems to be a trend with some Chinese companies lately to use reverse LCD’s. It doesn’t seem too bad in the photos, though.
Thanks to Martin for the deals.
RobAllen
Pete7874
Pete7874's picture
You found an original Lii-500 that does not have a discharge test (nor test) function? That’s a first.
teacher
teacher's picture
Hmmmm… Like Pete7874 said above, if you truly found a Lii 500 that does not have the discharge test function; it is an absolute first.
All Lii 500’s have the Discharge Test function. It is the ‘NOR’ Test.
The ‘FAST Test’ you mentioned above shows how many mA the cell accepts during charging.
The ‘NOR Test’ (Discharge Test) is more accurate showing true battery capacity.
Nisei
Last seen: 1 week 10 hours ago
Still (or again) on sale at Banggood so the code won’t work. This is the very first time I’m wishing a sale would end so I can order and save some cash Big Smile
BTW, the code has to be entered during checkout in the coupon code entry field right?
Nisei
M4D M4X wrote:
Hello my dear friends!
Here is my next groupbuy for you:
LiitoKala lii-500S for US$ 21.90
Thank you so much!
Flashdeal has ended and the code is working again.
Ordered!
jacc
Last seen: 44 min 41 sec ago
Hi all, can I ask a silly question? Any idea why this unit doesnt come with a LiFePo charging and discharging test like the Miboxer C4000 or the Opus BT-C100 ?
Really waiting for one.
