W30 White Laser Flashlight Throwing 2408 Meters
54 posts / 0 new
ACEBEAM
ACEBEAM's picture
Last seen: 4 days 3 hours ago
Here ACEBEAM W30 BLOS (Beyond-Line-Of-Sight) white laser light comes for you. This unique illuminator generates a high concentrated single output of 500 lumens beam, and its beam can reach remarkable beam distance of 2408 meters away. The high-drain 21700 5100mAh USB rechargeable battery provides a runtime of 1 hour 45 minutes. The convenient USB charging function allows to charge the battery timely. An 18650 battery adapter is also included for wider battery options. The battery indicator tells the battery voltage status at any time any where. The included Red filter adds to versatility of the W30. Moreover, W30 can be used as a diving light with a depth under water 100 meters.
ACEBEAM W30 MORE FEATURES “:http://www.acebeam.com/w30
sales@acebeam.com
Outdoor Illumination Expert
www.acebeam.com
Agro
Agro's picture
Last seen: 2 min 31 sec ago
When will you produce a zoomie?
ACEBEAM
ACEBEAM's picture
We will produce zoomie light in the near feature.
sales@acebeam.com
www.acebeam.com
Agro
Agro's picture
A LEP zoomie? Smile
Redlyne22
Redlyne22's picture
Last seen: 17 hours 48 min ago
Agro wrote:
A LEP zoomie? Smile
YES!
Sometimes being a newb is the best part of a hobbie
djozz
djozz's picture
Last seen: 17 min 41 sec ago
What is the beam intensity of the 4000K and the >90CRI version?
wle
wle's picture
Last seen: 9 hours 17 min ago
So, does it come with a tripod and telescope, to hold the light still, and see the target 1.5 miles away?
wle
djozz
djozz's picture
It does illuminate stuff closer by as well Wink
I think that the beam is not that different from the BLF GT, illuminating a smaller area (about 5 times smaller in area) a bit brighter, but I still think it can be a useful illumination. I have seen the illumination that the Maxabeam gives (up to 12 Mcd), even that one can be applied as a useful beam without telescopes and such.
wle
wle's picture
just saying
if the beam angle is smaller than the angular resolution of the eye, then – well i have lasers already – they are pretty bad flashlights ! Smile
Starkm32
Starkm32's picture
Last seen: 6 hours 27 min ago
Any sightings of Smile Price?
dmsoule
Last seen: 1 hour 57 min ago
Looks fantastic. Also interested in specs for the high CRI and 4000K varieties.
dmsoule
MSRP $286.30. http://www.acebeam.com/w30
djozz
djozz's picture
wle wrote:
just saying
The angular resolution of a healthy human eye is about 30cm at a km, we are not there yet Smile
komeko
komeko's picture
Last seen: 2 hours 14 min ago
HKE has a price of 259$
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
hank
hank's picture
Last seen: 2 hours 41 min ago
So is this laser as in “Light Amplification by Stimulated Emission of Radiation” or is it laser as in “tactical teeny weenie narrow spot flashlight”?
The_Driver
The_Driver's picture
Last seen: 11 hours 39 min ago
It's a laser phosphor system using a real blue laser.
BOMBAY
Last seen: 1 hour 6 min ago
lenght 119,1 mm ? probably a mistake in the specification
Enderman
Enderman's picture
Last seen: 24 min 50 sec ago
wle wrote:
just saying
Lasers have speckle and are also monochromatic which makes them very bad for illumination.
This is not just a laser, it is laser phosphor, basically a higher intensity LED with a laser diode instead of a regular blue diode.
It is laser pumped phosphor.
AnhTran
Last seen: 1 month 1 day ago
What would be the situation where someone need a >90 CRI laser?
Agro
Agro's picture
It’s not a CRI90 laser, the laser used here has negative CRI. It’s CRI90 phosphor.
And this item is not a laser. It is a flashlight.
Lexel
Lexel's picture
Last seen: 2 min 29 sec ago
there are Whitelight lasers with continous spectrum using special fibres
Saphire laser with a lot pulse width compression
the pulses are way shorter than a single wavelenght so its also white (but such pulses are extremely hazardous for any eye)
will34
will34's picture
Last seen: 1 day 3 hours ago
I have absolutely no need for this kind of beam, but would love to see some beamshots.
blueb8llz
Last seen: 5 hours 59 min ago
A lep zoomie is something I would be interested in.
SKV89
Last seen: 1 hour 50 min ago
What is the intensity of the 4000k and CRI 90 version? Also what is the color temperature of the CRI 90 version? I’m really looking forward to this. The previous laser lights on the market were measured at less than 200 lumens so this one might actually make it the first practical LEP flashlight and might be my first LEP flashlight. LOL
Also, any chance the zoomie will use the Oslon HX Boost? It will be the most powerful zoomie in the world.
Rexlion
Last seen: 1 day 7 hours ago
+1. Must… have… beamshots! (pant, pant)
AlexGT
AlexGT's picture
Last seen: 6 hours 14 min ago
Here you go…!
***Not a real beamshot but I bet it will look something like this…!!!*** Silly Wink
Agro
Agro's picture
AlexGT wrote:
Here you go…!
So true. Smile
SKV89
I think it will look like the BLF GTvn Oslon Black Flat
JamesB
Last seen: 9 hours 3 min ago
Correct me if i’m wrong but with a 1.8° beam the spot should be around 3 meters in diametre at 100 meters distance.
will34
will34's picture
Simulated beamshot
twisted raven
Last seen: 3 hours 4 min ago
There was an actual beamshot posted elsewhere on the forum some guy made his own topic about it.
