Test/review of Fujitsu AA HR-3UTHC 2450mAh (Black) 2019
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 50 sec ago
DSC_7129
Official specifications:
  • Voltage: 1.2V
  • Energy: 3Wh
  • Nominal capacity: 2.45Ah
  • Typical capacity: 2.55Ah
  • Weight: 30g
  • Cycle life: 500 cycles.
  • Low self discharge: 85% after 1 year
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-info
Maximum temperature raise at different discharge currents: 1A:+1,0°C, 2A:+3,0°C, 3A:+5,2°C, 5A:+10,5°C, 7A:+15,8°C, 10A:+21,6°C,
This is a retest, I have tested these batteries before.
DSC_7109 DSC_7110
DSC_7130 DSC_7131
DSC_7132
DSC_7133
DSC_7134
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-Capacity
The two cells tracks nicely and capacity looks good.
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-CapacityTime
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-CapacityTimeHours
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-Energy
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-PowerLoadTime
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-CurrentTest
Fujitsu%20AA%20HR-3UTHC%202450mAh%20(Black)%202019-Charge
Fujitsu%20AA%20HR-3UTHC%202450mAh%20%28Black%29%202019-Pulse-1.0A-30-30-0.7V-IR
Here I pulse a 1A current to measure internal resistance during discharge.
Conclusion
This looks like good quality NiMH batteries.
Notes and links
I am replacing my NiMH charger test batteries, they are from 2016 and some of them has a fairly high internal resistance. Some of the bad chargers I have tested have probably increased the deterioration rate of them. These will replace the EneloopPro, but I except to still use a EneloopPro as a example of an old cell.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
arow55
Last seen: 3 weeks 3 days ago
Do you test nimh right out of the box? They say using them a few times increases capacity.
Henk4U2
Henk4U2's picture
Last seen: 14 min 26 sec ago
Henrik, thank you for performing this test. Thorough as ever.
Question; isn’t this the good-old Eneloop Pro (bought them in 2011) with another wrapper?
Or do you think (or know) that this is more of a fine-tuned version of that golden oldie?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
HKJ
HKJ's picture
Henk4U2 wrote:
Question; isn’t this the good-old Eneloop Pro (bought them in 2011) with another wrapper? Or do you think (or know) that this is more of a fine-tuned version of that golden oldie?
I would expect them to be the same as the current generation Eneloop Pro
Pete7874
Pete7874's picture
Last seen: 5 hours 20 min ago
Thanks for the review. Your measured capacity aligns with what I saw on my cells purchased from Newegg at the beginning of this year, tested with my Opus C2400.
Superstocker
Superstocker's picture
Last seen: 13 hours 23 min ago
Thanks HKJ!
will34
will34's picture
Last seen: 3 hours 23 min ago
Thanks for the review, these look really nice.
