Test/review of Ansmann AAA 1100mAh (Silver-blue)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 13 min ago
DSC_8061
Official specifications:
  • Nominal capacity: 1100mAh
  • Minimum capacity: 1050mAh
  • Maximum continuous current: 3000mA
  • Standard charge: 110mA
  • Quick charge: 330mA
  • Fast charge: 1100mA
  • Recommended charge termination: 0..5mV, 0.8..1°C/min, 45-50°C
  • Trickle charge current: 10..50mA
  • Continuous overcharge:
  • Self discharge: >60% remaining after 28days at 20°C
Ansmann%20AAA%201100mAh%20(Silver-blue)-info
Maximum temperature raise at different discharge currents: 1A:+0,1°C, 2A:+0,1°C, 3A:+0,1°C, 5A:+0,1°C
This is high capacity cells from Germany
DSC_7695 DSC_7696
DSC_8062 DSC_8063
DSC_8064
DSC_8065
DSC_8066
Ansmann%20AAA%201100mAh%20(Silver-blue)-Capacity
The two cells match fairly well.
Ansmann%20AAA%201100mAh%20(Silver-blue)-CapacityTime
Ansmann%20AAA%201100mAh%20(Silver-blue)-CapacityTimeHours
Ansmann%20AAA%201100mAh%20(Silver-blue)-Energy
Ansmann%20AAA%201100mAh%20(Silver-blue)-PowerLoadTime
Ansmann%20AAA%201100mAh%20(Silver-blue)-CurrentTest
Ansmann%20AAA%201100mAh%20(Silver-blue)-Charge
Ansmann%20AAA%201100mAh%20%28Silver-blue%29-Pulse-0.5A-10-10-0.7V-IR
Internal resistance measured by pulsing 0.5A on/off.
Conclusion
These cells are some of the highest capacity AAA cells, but because these cells are not low self discharge they are best used for equipment that uses some power and is used frequently.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
flydiver
Last seen: 2 days 10 hours ago
Thank you for checking these out.
One of the main problems I’ve found with this kind of very high capacity NiMh (AA/AAA) is the internal resistance goes way up in short order, capacity goes down, and self-discharge becomes a problem. Simply won’t buy this type of cell anymore.
arow55
Last seen: 5 days 7 hours ago
Do you test nimh straight from the package or cycle a few times to get more mah?
HKJ
HKJ's picture
I cycle one time, then I start from the lowest current.
arow55
Agree.
Superstocker
Superstocker's picture
Last seen: 3 hours 33 min ago
Thanks HKJ!
